How to determine speaker size - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-26-2010, 08:45 AM - Thread Starter
laurandavid's Avatar
I just found out there is a place outside for a speaker. The speaker is old and owrn off so I can not read the back. How do you determine what size speker it is? Do you meausre the speaker itself or do you measure from side to side? It is a round one.
laurandavid is offline
post #2 of 7 Old 06-28-2010, 09:11 AM - Thread Starter
Anyone?
post #3 of 7 Old 06-28-2010, 09:29 AM
DonH50's Avatar
Quoted: 1792 Post(s)
Liked: 1325
Measure the diameter of the speaker element itself and that will get you in the ballpark.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #4 of 7 Old 06-28-2010, 09:43 AM
DonH50's Avatar
Liked: 1325
I assumed the OP had a mounted speaker and needed to replace it, restricting the size to what's there. Or is something else going on?
laurandavid -- What exactly are you trying to understand and do? Is it a single driver you are trying to replace, or an entire speaker system in an enclosure?
DonH50 is offline
post #5 of 7 Old 06-28-2010, 04:05 PM - Thread Starter
Just a single speaker. There is an enclosure that is screwed to the wall and inside there is one spaker. So the old speaker is worn off so can not see anything on the back that may tell me what it is. I measured from side to side, including the mounting area, and I get 8. The speaker itself is between to me looks like 6.5-6 3/4
post #6 of 7 Old 06-28-2010, 04:15 PM
ifor's Avatar
Quoted: 59 Post(s)
Liked: 72
can you post a pic of the enclosure?
is there a brand name somewhere on the enclosure?
ifor is offline
post #7 of 7 Old 06-28-2010, 04:24 PM
DonH50's Avatar
Liked: 1325
You want the size of the speaker itself. Sounds like it is probably a 6" speaker, but it might be an old 6.5" car speaker somebody put up. Measure the distance across mounting holes, then check some of the online places like Parts Express etc. to see if you can find one with the same dimensions. Or, take it out and to a friend or your local Radio Shack dealer.
You might be ahead just trashing the old speaker (enclosure and all) and picking up a new outdoor speaker to mount in its place. Do you know the wiring to it is good, and where it comes out?
DonH50 is offline
Reply Speakers
