Need help w/ 7.1 speaker placement (first post) - AVS Forum | Home Theater Discussions And Reviews
Old 07-18-2010, 05:31 PM - Thread Starter
iwrlja's Avatar
Hi,
I have an Onkyo 7.1 HTIB. We moved recently, and the living room already has a TV built in to the wall with a stereo sound system. So I decided to put our 52" tv in the den and set up the 7.1 htib system there.
I'm having a bit of trouble deciding what to do with the rear and side surround speakers though. I included pictures of what I thought I would do. Keep in mind the wall to the right hand side of my desk is actually a sliding glass door with about 8" of dry wall lining the top.
Before I moved, I had the rear speakers mounted on stands that only came up to ear level when seated. I'm trying to wall mount all my surround speakers this time and was planning on tilting all the speakers 30 degrees down.
Before I drilled holes on the wall I wanted to make sure that the speaker placement isn't too high.... The side speakers can be adjusted lower, but rear speakers can't because of the sliding doors.
Also, I'm a little concerned on whether or not the rear speakers are too far from my seats compared to the side speakers.
Any help would be much appreciated. Oh and the face of the front speakers are on level with the face of my bookcases unlike the rough design I drew. Thank you
iwrlja is offline
Old 07-19-2010, 03:53 PM - Thread Starter
iwrlja's Avatar
Any help guys?
The speakers are just lying on the floor waiting to be mounted.
I looked through the forums for similar issues, but there seemed to be conflicting opinions on how high is too high for surround speakers.
Thanks again in advance
iwrlja is offline
Old 07-19-2010, 04:21 PM
sdurani's Avatar
Quoted: 4507 Post(s)
Liked: 2913
Your placement angles fine for the surrounds. You'll hear good side vs rear separation in the surround field, which is the hallmark of a properly configured 7.1 set-up. You can bring the side speakers a bit lower, but not low enough to bump your head against. Most speakers sound best on-axis, so tilting them down will help. How far are you sitting from the rear wall and how far apart are the rear speakers?
Sanjay
sdurani is online now
Old 07-19-2010, 06:24 PM - Thread Starter
iwrlja's Avatar
Thank you for the response.
From the rear, I will be about 4'8" away. I was actually a little confused on how far apart the rear speakers needed to be from each other.
I was thinking about a sofa length (depicted in the picture) apart.
That made me question whether or not I should point the rear speakers around 10 degrees towards the center of the sofa (or whether or not it even mattered).
The system is a HT-S6100, and I think I'm mostly going to be listening with Dolby Pro Logic IIx.
iwrlja is offline
Old 07-19-2010, 10:24 PM
sdurani's Avatar
Liked: 2913
With your seating about 5 feet from the back wall, I would spread the rear speakers about 6-7 feet apart. The separation allow you to hear stereo imaging behind you. (Whether you're listening using PLIIx or discrete 7.1, the rear speakers will be stereo, not dual-mono.)
Sanjay
Old 07-20-2010, 01:47 AM - Thread Starter
iwrlja's Avatar
Thanks a bunch for your response.
Would you tilt the speakers towards the middle of the sofa as well?
iwrlja is offline
Old 07-20-2010, 02:01 AM
sdurani's Avatar
Liked: 2913
I would. Like I said earlier, speakers usually sound best on-axis, so it helps to point them towards the listening area.
Sanjay
Old 07-21-2010, 06:57 PM - Thread Starter
iwrlja's Avatar
Thanks again for your help!
iwrlja is offline
