Replace Infinity Interludes with Paradigm Monitors? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-20-2010, 10:08 PM - Thread Starter
thedv8's Avatar
My current setup:
2x Inifnity Interlude IL60 (front + sub)
2x Infinity Interlude IL10 (surround)
1x Infinity Interlude IL25c (center)
I bought this setup when I was in a house in California. I've since moved out to NYC where I'm in a shoebox apartment with an open living/dining/kitchen area that's about 250 sq ft (with 16 foot ceilings).
Not only are the speakers overkill, they also take up way too much space. I want a system that sounds at least as good as these but that takes up much less space. Here's what I was thinking:
2x Paradigm Monitor Atom v6 (or maybe the mini's?)
2x Paradigm Monitor ADP-190
1x Paradigm Monitor CC-190
1x Paradigm PDR-10
Would love to hear opinions from people who have experience with one (or better yet both) setup. Also if you have other suggestions for for a small footprint setup that sounds very good it would be great to hear from you too. Thanks!
thedv8 is offline
post #2 of 5 Old 08-14-2010, 04:14 PM
Braviageek's Avatar
I don't think you can do better than these speakers for the money. I own the Atoms, cc-190 and a pdr-8. They look great, are relatively compact, and the sound is tremendous. The only thing you might consider would be a different sub. The pdr-8 is perfectly adequate for my needs (some folks think it sounds better than the pdr-10), but from what you will read on this board there are probably numerous better sub options for power, depth and punch.
Braviageek is offline
post #3 of 5 Old 08-14-2010, 09:41 PM
Knucklehead90's Avatar
Quoted: 391 Post(s)
Liked: 335
Try moving the IL60s out of the room and give the IL10s and center a try - use the sub also. They should sound quite good in a small room. I've owned IL50s - IL40s & IL30s and still have the IL40s that I use in a 2 channel in the bedroom. I doubt I'll sell them any time soon.
It's hard to beat the Interlude speakers - it'll take lots of $s to match them and even more to surpass them. Is there any reason you don't like them besides the IL60s being quite large?
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #4 of 5 Old 08-15-2010, 09:13 PM - Thread Starter
thedv8's Avatar
Thanks guys, I ended up getting rid of the Interludes and got a pair of Paradigm Mini's for now. They obviously don't cover the range that the Interludes did, but I'd say the sound-stage is better, and they sound great even at lower volumes. Now I just need to find a sub... Any suggestions?
thedv8 is offline
post #5 of 5 Old 08-15-2010, 09:21 PM
RonaldoCombs's Avatar
Depending on your budget, Rythimik.
Ron
RonaldoCombs is offline
Reply Speakers
