Why are new speakers flat? - AVS Forum
post #1 of 26 Old 07-23-2010, 09:34 AM - Thread Starter
Ippa's Avatar
Hi everyone,
I am not a happy owner yet of JBL ES90 speakers, big floorstanders with 8" woofers. My first system to build up.
I use Onkyo 807 with them, don't have other electronics yet and need more cables to make my plasma's audio to play through it.
The only way I was able to play them as of today, is FM radio.
The problem is the bass is so flat, even on max bass set up and different play modes by Onkyo. When it plays, I feel almost no air pressure when put my hand close to the woofers and its "membranes" display no visible motion like I saw on videos. My computer Bose (no pun intended) speakers play deeper bass.
I know they need time to brake in. They have played for days, it looks the same. I checked the polarity of wires. What's wrong? Is it just because of the radio? More time to brake in?
P.S. To make things not better, one of the speakers came a bit dented so I am going to exchange it.
Ippa is offline
post #2 of 26 Old 07-23-2010, 09:41 AM
marlin29311's Avatar
Do you have your receiver set to having the speakers as "large?" What is the crossover?
You may simply not have the receiver sending the lower frequencies to your speakers, which would be an easy fix.
Sharp AQUOS 46" LED (LC46LE700)
Pioneer VSX-9130 TXH-K
Paradigm Cinema Phantom
Xbox 360 Elite (GT: Redfox29311)
LG BD270 Bluray
All the Monoprice wires you can find
marlin29311 is offline
post #3 of 26 Old 07-23-2010, 09:48 AM
Looneybomber's Avatar
Yeah, if the "membranes" aka. "cones", don't move much even though you have it cranked, I think you have some wrong settings in your AVR.
YID DIY
Looneybomber is offline
post #4 of 26 Old 07-23-2010, 09:51 AM
afrogt's Avatar
Quoted: 76 Post(s)
Liked: 352
I'd say you don't have your system set up properly. FM radio isn't the best source either. At least play a CD when you get the chance.
Afro GT
afrogt is offline
post #5 of 26 Old 07-23-2010, 09:54 AM - Thread Starter
Ippa's Avatar
To Marlin:
I have not met any "large" word at the settings..
If you mean crossover with a subwoofer, I do not have it. That was the reason to buy speakers with big woofers, to possibly avoid buying a sub as I mostly listen to music.
If you mean crossover by its specs, it is
"500Hz, 3kHz – 24dB/octave; 12kHz – 18dB/octave".
Ippa is offline
post #6 of 26 Old 07-23-2010, 09:58 AM
brandonnash's Avatar
Liked: 24
The crossover in the receiver. Should be able to be moved from as low as 40 hz to as high as 200. If you're not using a subwoofer then when the option comes thru for setting the speaker size in the receiver set them to large and with no subwoofer so the bass is all funneled to your speakers.
brandonnash is offline
post #7 of 26 Old 07-23-2010, 10:07 AM - Thread Starter
Ippa's Avatar
Ok, it looks like the settings..
I tried all possible modes I could, - stereo, surround, etc..
The deepest audible bass comes from "surr sens mus" mode but with muddy highs, which improve on "stereo" but becomes much less bass.
Ippa is offline
post #8 of 26 Old 07-23-2010, 10:13 AM
eviltwincustoms's Avatar
These settings are the surround settings Or Stereo is turning off Surround and doing 2 Channel only.
When the OP say setting your speakers to LARGE, you need to go into your AVR's Calibration Menu and change the setting from Small to Large and turn the Sub off if it is on.
If you are not sure where this is located or dont have the Manual, my suggestion would be to go to the Amplifier Forum and find your AVR. The thread for your specific receiver will tell you what you need to do, to make this change.
Good Luck!
eviltwincustoms is offline
post #9 of 26 Old 07-23-2010, 10:15 AM - Thread Starter
Ippa's Avatar
Ohhh...
I didn't want to scare my neighbors so I have never cranked up all the way. I just did and the cones are jumping!!
Now, I can't listen that loud.. I read before that they like to play loud but not to that degree..
So need a sub anyway?
I will check crossover in the receiver.
Thanks everyone.
Ippa is offline
post #10 of 26 Old 07-23-2010, 10:20 AM - Thread Starter
Ippa's Avatar
Good Luck!
Thanks, I have not done "Audyssey MultEQ" if it is the same what you mean by calibration. I do have the manual but haven't got to it yet..
Ippa is offline
post #11 of 26 Old 07-23-2010, 10:49 AM
Ohhh...
YID DIY
post #12 of 26 Old 07-23-2010, 12:07 PM
In your manual, on page 51, it talks about how to change the various speaker settings. Page 85 discusses the different crossover settings for your speakers.
You should set them both to full rangeand turn off the sub as well.
The 807's maunal can be found here too:
http://onkyousa.com/model.cfm?m=TX-N...s=Receiver&p=d
LG BD270 Bluray
post #13 of 26 Old 07-23-2010, 02:26 PM - Thread Starter
Ippa's Avatar
Originally Posted by Looneybomber View Post
Do I look like that kitty?
Ippa is offline
post #14 of 26 Old 07-23-2010, 03:03 PM - Thread Starter
Ippa's Avatar
class=Receiver&p=d[/url]
Done that. Now fronts are "full band" and sub is "off" as well as others.
Makes difference.
Thank you.
Ippa is offline
post #15 of 26 Old 07-23-2010, 06:49 PM
Bone215's Avatar
he is listening to the FM radio, it isn't sending enough low frequencies for the speakers to reproduce
deeper than the deepest ocean
Bone215 is offline
post #16 of 26 Old 07-23-2010, 06:53 PM
ClarkeBar's Avatar
Now take the time to throw a proper Audyssey room calibration in and you should be good to go with very little adjustment. Depending on the room and the speakers, you may wish to still run the fronts as Large (Full Range) even with a sub. I have tried it both ways with my towers but am learning to like the Small setting with sub but with a lower 40Hz X-over. Give it time and experiment.
My life is an open book...wish I could read it and have it make sense.
ClarkeBar is offline
post #17 of 26 Old 07-23-2010, 07:18 PM - Thread Starter
Ippa's Avatar
Thanks, still not sure what Large or Small mean. No such words at my Onkyo settings.
Ippa is offline
post #18 of 26 Old 07-23-2010, 07:21 PM
Liked: 24
Large means that your speakers can handle the bass. depending on your receiver it will either send a full signal or most of the bass to the speakers and not subwoofer. you have no sub so you need to have it set to full or large. Small means the frequencies below the crossover are sent to the subwoofer only.
post #19 of 26 Old 07-23-2010, 07:22 PM
Bone215's Avatar
painful
Bone215 is offline
post #20 of 26 Old 07-23-2010, 07:32 PM
barryecohen's Avatar
Originally Posted by Bone215 View Post
painful
Agreed, far worse than 'Nails On Chalkboard'
So much media, so little time...
barryecohen is offline
post #21 of 26 Old 07-23-2010, 07:39 PM - Thread Starter
Ippa's Avatar
That's what I did. "Full band".
Ippa is offline
post #22 of 26 Old 07-23-2010, 07:40 PM - Thread Starter
Ippa's Avatar
Thanks, appreciate your sense of humor and support.
Ippa is offline
post #23 of 26 Old 07-23-2010, 09:21 PM
mjg100's Avatar
You are saying that you have your speakers set to full bandwidth and the cones still hardly move? If so what is your master volume level set to? Did you run auto setup?
mjg100 is offline
post #24 of 26 Old 07-24-2010, 12:00 AM - Thread Starter
Ippa's Avatar
I just did not crank them up enough before posting. When I did, they were moving well. I realized it then.
No, I did not run auto set up yet.
Ippa is offline
post #25 of 26 Old 07-24-2010, 04:57 AM
kmike's Avatar
If it's sounding better to you now and you've gotten familiar with changing settings, yoiu should run Audyssey....you will probably find that the sound is even better afterwards. If not, you can always turn it off but there's a reason that running Audyssey is the last step in "First Time Setup"
Afterwards, turning on Dynamic EQ will also help your bass response at lower listening levels.
Mike
_____________
I may be a rookie but I'm the expert at what sounds good to me.
kmike is offline
post #26 of 26 Old 07-24-2010, 10:03 AM - Thread Starter
Ippa's Avatar
Right, finally did that and it is a total new experience, even on FM radio. All range of frequencies is better, better stereo separation and, most important, it all works on lower listening levels.
Now I think I still need a sub..
Ippa is offline
Reply Speakers
User Tag List
