Polk Audio Monitor 70 upgrade - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 32 Old 08-13-2010, 02:33 PM
Davesatdoasisbar's Avatar
For a 7.2 surround if you did 70s in front and cs2 for center what are recommendations for the sides and rears?
Taking into account I would like to mount the sides on the walls. If I opted to free stand the sides what is the recommendation?
The rears must be on a stand as there basically no back wall.
Receiver will be Onkyo 1007.
Davesatdoasisbar is offline
post #32 of 32 Old 08-14-2010, 07:48 PM
Bump - anyone?
And if you are wondering how I picked these speakers its because of the deal that seems to available on them as they are being discountinued.
With that said I am open to selection but I couldn't spend anymore than what this set up would cost. Once I find out what pieces I would be using then I will have a base $$.
I know this set up doesn't include a sub but I'm taking it on thing at a time.
Reply Speakers
