Polk Audio Monitor 70 upgrade - AVS Forum | Home Theater Discussions And Reviews
post #1 of 32 Old 08-04-2010, 04:29 PM - Thread Starter
Traumahead's Avatar
Traumahead is offline
post #2 of 32 Old 08-04-2010, 04:32 PM
afrogt's Avatar
Quoted: 1432 Post(s)
Liked: 982
Sony's will be fine for surrounds.
Is this for home theater or music? If for HT are you getting a matching center for the Monitor 70's?
Afro GT
afrogt is offline
post #3 of 32 Old 08-04-2010, 04:47 PM
afrogt's Avatar
Liked: 982
CS2 is actually the matching center for your Monitor 70's.
http://www.newegg.com/Product/Produc...-212-_-Product
CS10 or CS20 would also work but actually made to match the TSi speaker line. Tsi is basically a Monitor series speaker in an upgraded cabinet.
Afro GT
afrogt is offline
post #4 of 32 Old 08-04-2010, 04:59 PM
afrogt's Avatar
Liked: 982
That's not small. perfect size for my your new Polks.
17 x 12 is slightly larger than my living room which has 4 tower speakers.
Afro GT
afrogt is offline
post #5 of 32 Old 08-04-2010, 05:09 PM
afrogt's Avatar
Liked: 982
I would NEVER recommend mounting a floorstanding speaker on the wall. That'll look diifferent having a 15" deep, 42" tall, 47lb speaker on the wall. at least it'll be a conversation piece once you figure out how to mount it.
Afro GT
afrogt is offline
post #6 of 32 Old 08-04-2010, 05:38 PM
crazyrob425's Avatar
Quoted: 445 Post(s)
Liked: 339
By mounting the M70 on the wall will destroy proper ear level of the speakers when you are seated on a couch
Its recommend the speakers tweeter be at ear level with you are seated on couch or chair
Mounting a Monitor 70 on a wall would not be innovated but it would land you the idiot of the year award
If you don't have the space for large speakers quality book sheleves with a quality woofer would do just as well
crazyrob425 is offline
post #7 of 32 Old 08-04-2010, 05:40 PM
palehorse's Avatar
Originally Posted by Traumahead View Post
Oh I am one innovative SoB. You'll see once I post this picture. Just come by and check this thread tomorrow.
But other than it looking weird, you don't think it would affect the audio aspect?
The 70's are already designed to output sound at an optimal height when placed directly on the floor. If you're looking to wall-mount speakers, then find a set of bookshelf speakers instead of the 70's.
Better yet, if floorstanders really aren't an option, buy three matching bookshelf speakers, and use them for the entire front soundstage...
palehorse is offline
post #8 of 32 Old 08-04-2010, 05:55 PM
Transmaniacon's Avatar
Quoted: 1586 Post(s)
Liked: 1394
Just know that you will be losing a lot of low end extension if you go with bookshelves over floor standers. For HT, its pretty crucial to have a sub woofer, so if you do go the bookshelf route, I add a sub to the list.
The Polk Monitor 40s and CS2 would be a nice front three if going the bookshelf route. I would suggest the BIC America F-12 sub to accompany them (in keeping the components at the same value level)
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #9 of 32 Old 08-04-2010, 10:24 PM
afrogt's Avatar
Liked: 982
by the looks of that picture, you're better off with wall mounted speakers. Go with one of the recommendations above like the Polk Monitor 40.
Afro GT
afrogt is offline
post #10 of 32 Old 08-05-2010, 02:24 PM
afrogt's Avatar
Liked: 982
No it doesn't matter. Your Onkyo 707 doesn't put out 125 Watts per channel anyway so it doesn't matter if the Monitor 70's can handle up to 270 watts since you have no source that can provide that kind of power.
Afro GT
afrogt is offline
post #11 of 32 Old 08-05-2010, 02:27 PM
EndersShadow's Avatar
Quoted: 629 Post(s)
Liked: 951
Well last night i was thinking about just getting 2 sets of the M40s and i just looked at them. They are only 125w. Am i shooting myself in the foot here? Thats a big step down from the 275w of the M70s.
Monitor 40s
http://www.newegg.com/Product/Produc...82E16882290202
I suggest perhaps looking at the LSi Bookshelves. Those speakers can take some serious wattage. There is a guy selling a set of LSI9's for 325 on the Polk site...they wont last long there....also Polk has an Ebay site you might find some deals on (like for the matching center)
My Setup | FS: Salamander Synergy 303, Outlaw LFM-1 sub, Sanus UF22 Speaker Stands, Nintendo Wii
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #12 of 32 Old 08-05-2010, 02:30 PM
afrogt's Avatar
Liked: 982
LSi9's are 4 ohm speakers. I wouldn't recommend getting those without some type of external amplification. They're very power hungry and I doubt the 707 will provide enough power to make them truly sing.
Stick with the Monitor 40's.
Afro GT
afrogt is offline
post #13 of 32 Old 08-05-2010, 02:33 PM
Quoted: 629 Post(s)
Liked: 951
Yeah, I forget if its rated for 4 ohms...I just know it was one of their higher lineup models......
If I had 325 bones for those I would be all over em.....
OP, I think 125 watts is fine for your fronts. Keep in mind most recievers really dont provide their full rated wattage to the speakers. They normally say at the back of the manual that its 90 watts per channel with two channels driven.
So if you get a external amp (later on) that does 125 watts with all channels driven then you will fine.
PS. I used Monitor 40's in my bedroom w/ a CS1 and a crappy Sony reciever for 2 years and was more than happy, so the 40's can be used as fronts with no issues at all.
Just make sure you get a good sub to fill out the bottom end of the spectrum
post #14 of 32 Old 08-05-2010, 03:29 PM
afrogt's Avatar
Liked: 982
don't worry about any external amps right now. You have no room for one! Get your monitor 40's and CS1 center. The 707 will be fine for your room.
Afro GT
afrogt is offline
post #15 of 32 Old 08-05-2010, 03:35 PM
afrogt's Avatar
Liked: 982
Well i mean how big are they? Like a car amp size or the size of another receiver? I've never even seen a home amp.
Bigger than your Onkyo 707 and will need room to breathe. The XPA-3 is 57lbs!
http://emotiva.com/xpa3.shtm
Afro GT
afrogt is offline
post #16 of 32 Old 08-06-2010, 01:31 AM
Quoted: 629 Post(s)
Liked: 951
WOAH! That's a big boy. Well, I never doubted you. I was just curious.
Guess its settled then M40s with the CS1 center. Should be a big improvement.
Yes it should. Any the beginning of your journey....to the dark side.....
post #17 of 32 Old 08-06-2010, 03:57 AM
DogEarz's Avatar
nice sony subwoofer ...isn't that an oxymoron? Just kidding! ;-)
Please keep in mind that the M40's are rear ported and need to have space behind them; don't push them up against the wall. And try to get them as far apart as you sit from them.
DogEarz is offline
post #18 of 32 Old 08-06-2010, 03:45 PM
Quoted: 445 Post(s)
Liked: 339
Got another question for you guys. I'm looking at these pictures and there are two sets of positive and negative connectors. Why two sets? And even if i did have two sets of wires to go to one speaker, what would they be for?
The speakers are for Bi-Wiring or Bi-Amping
http://www.brilliancehifi.co.uk/how-...e-speakers.htm
post #19 of 32 Old 08-06-2010, 03:57 PM
afrogt's Avatar
Liked: 982
leave the jumpers in place you'll be fine. Just connect to one pair or terminals.
Afro GT
afrogt is offline
post #20 of 32 Old 08-06-2010, 06:12 PM
Looneybomber's Avatar
Oh there's plenty of room for towers in there. Just push the mini fridge and computer over and you got it.
BTW, I like your office/man cave better. Sledgehammer are you serious!? Win!
5 Infinity Beta 20's all about 3ft from listening position with Infinity SW-12 sub and Pioneer VSX1014. I think the room is 12x14.
YID DIY
Looneybomber is offline
post #21 of 32 Old 08-07-2010, 02:02 PM
Quoted: 629 Post(s)
Liked: 951
Ok guys so I just got back from our local Furnature Mart and heres what I did. Polk Audio TSi200s for the front and TSi100s for the surround. They did not have the CS10 in stock but I would have gotten it if they did. Did i do good or did i screw myself by buying different surround speakers from the front ones????
They did not have any of the monitor series.
TSi200
http://www.newegg.com/Product/Produc...82E16882290097
TSi100
http://www.amazon.com/Polk-Audio-TSi.../dp/B00192KF12
You did fine and should enjoy that system very much. I would highly suggest though spending some serious cash on a good sub. This will make up for the areas those speakers will not work well in (bass)
post #22 of 32 Old 08-07-2010, 05:58 PM
afrogt's Avatar
Liked: 982
If your Sony sub is like my old SA-WM40 you can add some polyfil to help eliminate some of the boominess and tighten up the bass. A very cheap fix, maybe $5.
Alot of us did this several years ago.
http://www.nonsensicalgibberish.com/sony.html
Afro GT
afrogt is offline
post #23 of 32 Old 08-07-2010, 09:45 PM
Quoted: 445 Post(s)
Liked: 339
So should I mount the fronts the same place they are now or can i put them closer to the TV? I think I remember hearing that they should be far apart.
http://www.amazon.com/SANUS-SYSTEMS-.../dp/B00009WE15
post #24 of 32 Old 08-07-2010, 10:05 PM
Quoted: 629 Post(s)
Liked: 951
I like these mounts better....they are what I am using for my Monitor 40's and work great: http://www.amazon.com/Pinpoint-Clamp.../ref=pd_cp_e_0
Also drop some industrial strength velcro rather than use the included screws and you will be fine...
post #25 of 32 Old 08-08-2010, 06:37 AM
Quoted: 445 Post(s)
Liked: 339
So I'm doing a preliminary hookup of the fronts. Already creaming myself.
Also, just put in the order for the CS10. Correct me if I'm wrong but that is the matching center speaker right?
CS10 is the matching center.
post #26 of 32 Old 08-10-2010, 01:32 AM
mole''s Avatar
Monitor 70 for the fronts, Monitor 50 for the rears, Monitor 40 for SS and a CS2 for center and you will be set. ran a PSWi225 sub
i had this but am moving up to the RTi series now.
RTi12, RTi10 and a CSi5 with an Epik castle sub
mole' is offline
post #27 of 32 Old 08-10-2010, 11:32 AM
afrogt's Avatar
Liked: 982
Bump for an answer to my last question.
Also, new CS10 is here.
You'll be fine with the way the speakers are. Where is there room for bookshelf anyway?
How do they sound? It has to be way better than what you previously had.
Afro GT
afrogt is offline
post #28 of 32 Old 08-10-2010, 03:03 PM
Quoted: 445 Post(s)
Liked: 339
Cross-over should be 80hz for the Tsi200 and TSi100
post #29 of 32 Old 08-10-2010, 06:23 PM
afrogt's Avatar
Liked: 982
But are they capable of doing 60hz well? As well as a subwoofer? 80hz is better for those speakers, the specs may say 55hz but bass starts rolling off way before then. Let your subwoofer handle the lower frequencies because it'll do a better job than your bookshelf speakers. It'll also take a load off your receiver since it doesn't have to produce the lower frequencies.
The THX recommendation is also to cross your speakers at 80hz.
Afro GT
afrogt is offline
post #30 of 32 Old 08-10-2010, 07:23 PM
elminster79's Avatar
the crossover setting isnt an instant stopping point, its where it starts to roll off, so with an 80 setting it still plays below that, so if you set it lower then it usually ends up being too low
elminster79 is offline
Reply Speakers
