Speakers for Onkyo TX-SR508 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-23-2010, 08:52 PM - Thread Starter
Will81's Avatar
Hi all, im seriously considering buying the Onkyo TX-SR508 and would like to initially get a pair of speakers and a sub woofer to go with it. I will later upgrade to 5.1 or even 7.1 but for now just the sub and front stereo will do for music and games. The main music style will be heavy metal (if that makes a difference) and have £500 to spend on them (not inc amp). Ive had a little look about but there is so much options with amp and speaker clarity and warmth etc and the combinations between them all! Can i get a few suggestions to start please?
Thanks all.
Will81 is offline
post #2 of 8 Old 08-24-2010, 10:37 PM
pronghorn/az's Avatar
Quoted: 20 Post(s)
Liked: 31
Onkyo and Paradigm are an excellent match. Give them a listen to.
Jeff
pronghorn/az is offline
post #3 of 8 Old 08-24-2010, 11:06 PM
jaymalya's Avatar
Looks like it does not have pre-outs (except for sub) - so in future if you looking for adding a separate amp or a new speaker with 4 ohm dips , you may be out of luck.
jaymalya is offline
post #4 of 8 Old 08-24-2010, 11:07 PM
jaymalya's Avatar
Also Audyssey 2EQ will not do anything for the sub
jaymalya is offline
post #5 of 8 Old 08-25-2010, 06:00 AM - Thread Starter
Will81's Avatar
Ok thanks pronghorn, ill check them out
Jaymalya, this is just my first step into some proper HT equipment so im just needing a kinda basic setup atm. If i need a new amp in future ill just outright buy a new one. Also, i have no idea what your speaking about with the 4ohm dips!
I was looking at some B&W 685's online and they seem to get some good writeups for speakers under the £500 mark. Anyone had experience with them?
Will81 is offline
post #6 of 8 Old 09-07-2010, 10:25 PM
zippo775's Avatar
You don't know what your talking about
zippo775 is offline
post #7 of 8 Old 09-15-2010, 06:41 AM - Thread Starter
Will81's Avatar
Hey again all. I just wanted to give you an update. After auditioning some speakers at a local(ish) store I ended up going for Dynaudio DM 2/6's. I think they sound awesome. Thanks again for everyone's help
Will81 is offline
post #8 of 8 Old 09-15-2010, 08:06 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
The Audyssey 2EQ doesn't do anything to adjust the subwoofer levels. You need Audyssey MultiEQ to get processing of the subwoofer.
Budget Denons have MultiEQ you need a onkyo tx-sr-70x to get that processor
crazyrob425 is offline
Reply Speakers
