Definitive ProCinema+Denon 1908 Speaker Levels - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 09-15-2010, 11:01 AM - Thread Starter
ndcdfm1's Avatar
Trying to fugure out the best speaker db level config for a room thats probably 13x20. I'm not getting that awesome surround theater sound and I'm thinking that it's my speaker levels. My blu ray player is my PS3 and I have it on bitstream rather than linear. Most movies are in the correct Dolby format when I play them-just looking for some help with optimal db levels for all speakers and sub-w.
ndcdfm1 is offline
post #2 of 9 Old 09-15-2010, 12:40 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Honestly they best thing you can do is run the receivers auto programing, Audyssey MultiEQ.... It will do all the hard work for you. Generally the recommend level for calibration is 75db. Check your crossovers set
Awesome sound comes from awesome speakers so what are your speakers? Do you have the smaller or larger pro cinema system?
Do you have a fat or slim PS3?
crazyrob425 is offline
post #3 of 9 Old 09-15-2010, 06:15 PM - Thread Starter
ndcdfm1's Avatar
I have pro cinema800 and ps3 is slim. I'm not quite a noob at this but what is the crossover set?
ndcdfm1 is offline
post #4 of 9 Old 09-15-2010, 07:09 PM
AvGeek07's Avatar
try crossover of 80hz,not sure if your speakers can handle 80hz also try 100 hz etc. Do you know the specs of the speakers?
AvGeek07 is offline
post #5 of 9 Old 09-15-2010, 07:50 PM
Quoted: 443 Post(s)
Liked: 337
Cross-over setting...
Have you run Audyssey that your receiver has? Have you checked the settings it used? What are the settings it choose?
post #6 of 9 Old 09-16-2010, 08:49 AM - Thread Starter
ndcdfm1's Avatar
Yes, I tried the audessy but was not thrilled with the speaker output. The speakers can definitely handle 80-100 hz. I think that part of the problem is that I have the front speakers plugged into the receiver instead of the sub w.
ndcdfm1 is offline
post #7 of 9 Old 09-16-2010, 09:01 AM
Blasst's Avatar
Quoted: 66 Post(s)
Liked: 64
Come post your questions in the main ProCinema thread and we can help you out there.
http://www.avsforum.com/avs-vb/showthread.php?t=863945
Blasst is offline
post #8 of 9 Old 09-16-2010, 01:02 PM - Thread Starter
ndcdfm1's Avatar
Cool will do. Thanks for the re-direct.
Thread ended.
ndcdfm1 is offline
post #9 of 9 Old 09-16-2010, 01:40 PM
Quoted: 443 Post(s)
Liked: 337
That was a noted issue with the ProCinema600 but not the 800.
Cross-over should be set to 100hz for left and rights, and the center has a crossover of 80hz
How did Audyssey set the level to your subwoofer. I know they usually turn it way down.
Have you checked the calibration Audyssey did? can you write all the settings it set. That is the only way we can help you
Reply Speakers
