Pioneer's Speaker Genius Hits Low Price Point - Page 192 - AVS Forum | Home Theater Discussions And Reviews
 91Likes
post #5731 of 6441 Old 07-16-2014, 05:36 AM
Bond 007's Avatar
Quoted: 2654 Post(s)
Liked: 2104
Originally Posted by pezgod View Post
I guess there's that too. I was worried about messing up the sound of the speaker by drilling into it!
Wont bother it if you use short screws and place them properly.
Bond 007 is online now
post #5732 of 6441 Old 07-16-2014, 10:25 AM
pezgod's Avatar
Quoted: 52 Post(s)
I think I'll probably end up going with this
http://www.amazon.com/gp/product/B00...5525584&sr=1-1
and just pointing the speakers directly at each other. The speakers are a bit larger than the platform (Suitable for speakers no larger than 5.9 inches x 7.87 inches (15cm x 20cm) on the side for shelf, while these are ~ 7.13in x 8.44in), but I plan on putting some heavy duty velcro on there to keep everything in its place! The couch is on the rear wall, so they will be mounted just below the ceiling on the rear wall, facing each other over the couch. I have heard some people say to angle the speakers at the listener, and others say to keep them straight. I know that mount will work, so I might as well just go with that and hope it sounds good! It does swivel 360 deg, so I can play around with that and bouncing it off the rear/side walls and whatnot! It should at least sound better than the current setup I have (speakers on my tv!)
pezgod is offline
post #5733 of 6441 Old 07-17-2014, 04:37 AM
Bond 007's Avatar
Liked: 2104
I vote for angling them at the listener.
Look at "Blutack" at Amazon. Holds the speaker really well. Not as permanent as velcro and leaves no adhesive residue on anything.
post #5734 of 6441 Old 07-17-2014, 07:17 AM
wdeydwondrer's Avatar
Quoted: 30 Post(s)
Liked: 27
3m command strips work well to
wdeydwondrer is offline
post #5735 of 6441 Old 07-17-2014, 12:46 PM
pezgod's Avatar
Quoted: 52 Post(s)
I just had a wonderful Idea!!!!!!! I have at my disposal a Laser cutter!! http://www.epiloglaser.com/products/...ser-series.htm
I'm going to draw something up and laser cut some wood to make an angled bracket that I can mount on top of that swivel mount I posted before. I figure I can net myself about an 15-18 degree angle. AND I can make my bracket match the shape of the speakers perfectly! I can then screw that bracket into the mount, and I'm good to go with a nice secure bracket...that fits on my wall!
pezgod is offline
post #5736 of 6441 Old 07-17-2014, 01:49 PM
Quoted: 256 Post(s)
Liked: 41
Anyone here compared these to the Infinity Primus line? Those are a couple I am debating between and there seems to be some mixed information about which are better. My use will be mainly movies and TV.
Warner2Bruce is offline
post #5737 of 6441 Old 07-17-2014, 02:28 PM
barhoram's Avatar
Quoted: 167 Post(s)
Liked: 37
After reading all of the great reviews on these speakers, I picked up a set (LCR) of the towers "just in case" for my home theater. They sat new in their boxes for months, but just recently, someone made me an offer I couldn't refuse on my existing Paradigm setup. I dropped these in until my new $peakers came in, and I was really pleased. Now granted I've got a pretty good sub woofer, but honestly, after playing around with their location a bit (actually more flexible because they are smaller) and running EQ, I can't really tell much of a difference between $360 worth of FS52s and $6K+ worth of Paradigms in the front! My wife (didn't know the paradigms were gone) actually asked if I had dome something new as the theater sounded much better....
Pick up 3 matching ones with a sub and give it a try!
Nikwasi likes this.
I don't really like talking about my flair
barhoram is offline
post #5738 of 6441 Old 07-17-2014, 02:41 PM
Quoted: 256 Post(s)
Liked: 41
I want to make sure I am understanding you correctly. Are you 3 52's as the front right, center, and front left? What is the subwoofer you are using? No 22's for the rears?
post #5739 of 6441 Old 07-17-2014, 02:45 PM
barhoram's Avatar
Quoted: 167 Post(s)
Liked: 37
Correct. 3 FS52s behind an AT screen with a Velodyne DD15 sub. I kept the Paradigm surrounds. The wood in the signature series just look gorgeous on my theater walls...and they are the only speakers you see.
barhoram is offline
post #5740 of 6441 Old 07-17-2014, 03:51 PM
Nikwasi's Avatar
Quoted: 88 Post(s)
Liked: 89
I love the sound of three FS52s up front. Unfortunately that won't work for me right now because my TV sits on a stand that is too low to place a tower front/center. (I'm running FS52 rears because I want to avoid stands or wall mounts.) And your advice about the sub is spot on. Adding a truly competent subwoofer to the mix makes these speakers glow. When I upgraded to an SVS (SB-2000) the overall sound improved to such a degree, it seemed as though I had bought all new speakers.
Nikwasi is offline
post #5741 of 6441 Old 07-17-2014, 04:20 PM
Quoted: 256 Post(s)
Liked: 41
What sub did you have before the SVS SB-2000?
post #5742 of 6441 Old 07-17-2014, 04:29 PM
Nikwasi's Avatar
Quoted: 88 Post(s)
Liked: 89
Klipsch Synergy 12.
Nikwasi is offline
post #5743 of 6441 Old 07-18-2014, 11:28 AM
pezgod's Avatar
Quoted: 52 Post(s)
Spent all last night making up my template. Cut the wood today with the laser! (that thing is awesome!) Here's my final outcome! Unless I measured incorrectly, this should JUST BARELY miss my ceiling!
ID:	168361   Click image for larger version
pezgod is offline
post #5744 of 6441 Old 07-18-2014, 01:20 PM
crakarjax's Avatar
Quoted: 56 Post(s)
Cool! Might as well make your own speakers while you are at it
crakarjax is offline
post #5745 of 6441 Old 07-18-2014, 05:31 PM
Nikwasi's Avatar
Quoted: 88 Post(s)
Liked: 89
Here's an anecdote for everyone invested in quality audio:
This morning, for reasons I won't annoy you with, I saw an ear/nose/throat specialist for the first time in my life. As part of the exam, the doctor offered to clean my ears (though I wasn't there for a hearing problem). "Why not?" I answered, and doc proceeded with a quick, painless flush. He informed me afterwards that my right ear was, in the language of his specialty, "gunked up." Ewww!
Voila, when I returned home and switched on some music, I noticed immediately that the audio balance seemed much improved. Upgrade! And I hadn't spent a dollar (on audio equipment, that is).
Moral of story: No matter how much you spend, no matter how much you tweak, your system is only as good as your ears.
Bond 007 likes this.
Nikwasi is offline
post #5746 of 6441 Old 07-19-2014, 06:20 AM
pezgod's Avatar
Quoted: 52 Post(s)
if I could get better quality for cheaper i would!! Those stands though were made from $3 worth of MDF board I had leftover from a birthday present I made for my wife!
also... I'm not an electrical engineer or audio engineer, so id have no clue where to even start!!!
pezgod is offline
post #5747 of 6441 Old 07-19-2014, 09:47 PM
BuddTX's Avatar
Quoted: 110 Post(s)
Liked: 83
I would start here!
http://www.avsforum.com/forum/155-diy-speakers-subs/
BuddTX is offline
post #5748 of 6441 Old 07-24-2014, 06:02 AM
afrogt's Avatar
Quoted: 1435 Post(s)
Liked: 982
Pioneer One Day Sale at Fry's
Fry's has a one day sale on Andrew Jones speakers. Ends today Thursday 7/24. In Store Only!
FS-52 $69 each
BS-22 $70/pr
C22 $50
The also have the first series speakers on sale too.
FS-51 $130/pr
BS-41 $99/pr
C21 $59
SW-8-K 8" Subwoofer $80
Name:	Pioneer Sale 072414.PNG
Afro GT
afrogt is offline
post #5749 of 6441 Old 07-24-2014, 08:21 AM
butie120's Avatar
Quoted: 646 Post(s)
Liked: 126
FS-52 $69 each
BS-22 $70/pr
C22 $50
FS-51 $130/pr
BS-41 $99/pr
C21 $59
It's times like these I wish I lived near a Frys. Sweet deal.
butie120 is online now
post #5750 of 6441 Old 07-24-2014, 09:03 AM
BGLeduc's Avatar
Quoted: 1858 Post(s)
Liked: 1676
FS-52 $69 each
BS-22 $70/pr
C22 $50
FS-51 $130/pr
BS-41 $99/pr
C21 $59
I continue to be amazed that there remain Series 1 speakers still in the retail pipeline.
BGLeduc is offline
post #5751 of 6441 Old 07-24-2014, 09:13 AM
roknrol's Avatar
Quoted: 32 Post(s)
Liked: 38
Dang. Wish Amazon would price match the CS22 today ....
roknrol is offline
post #5752 of 6441 Old 07-24-2014, 09:24 AM
Quoted: 256 Post(s)
Liked: 41
You can try the "submit a lower price" option on the product page on amazon.
post #5753 of 6441 Old 07-24-2014, 09:54 AM
roknrol's Avatar
Quoted: 32 Post(s)
Liked: 38
You mean the "tell us about a lower price" feedback option? Huh. Never tried that.
OK. Gave it a go.
roknrol is offline
post #5754 of 6441 Old 07-24-2014, 10:02 AM
rc05's Avatar
Quoted: 152 Post(s)
Liked: 87
A few of the times Fry's ran this promotion, Amazon lowered their prices too after a few hours it seemed
rc05 is offline
post #5755 of 6441 Old 07-24-2014, 10:22 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Someone probably submitted it. On any product page, you can notify Amazon of a lower price somewhere else.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #5756 of 6441 Old 07-24-2014, 10:42 AM
roknrol's Avatar
Quoted: 32 Post(s)
Liked: 38
That's why I love this forum. I'm always learning stuff!
Anyway, I submitted it so we'll see what happens.
roknrol is offline
post #5757 of 6441 Old 07-24-2014, 10:42 AM
Nikwasi's Avatar
Quoted: 88 Post(s)
Liked: 89
This Fry's deal is the same type of in-store promotion that led Amazon to lower their price on the FS-52s to $60 last December, if only for a few hours. It might have been a mistake on the part of Amazon, but I'm glad I happened to be online at the time.
Nikwasi is offline
post #5758 of 6441 Old 07-24-2014, 11:58 AM
cel4145's Avatar
Liked: 3002
It's always worth a shot.
cel4145 is offline
post #5759 of 6441 Old 07-24-2014, 01:10 PM
ClawAndTalon's Avatar
Quoted: 421 Post(s)
Liked: 283
I'm just going to say that these Pioneer speakers (at full price) are the best deal in home audio. That said, this Frys sale is a steal.
Seriously I think you have to spend about 800-1000 on a speaker pair to get something better than these.
One man's opinion and all that.
ClawAndTalon is offline
post #5760 of 6441 Old 07-24-2014, 02:01 PM
Nikwasi's Avatar
Quoted: 88 Post(s)
Liked: 89
Last night I was doing some system checking. In the process I switched my front FS52s to basic stereo mode; no subwoofer, surrounds or center. I had forgotten how good they sound as stand-alone, full range speakers for music even at high volume levels. Yeah!
Nikwasi is offline
Reply Speakers
Pioneer Andrew Jones Sp Fs52 Flr Stand Loudspeaker , Pioneer Andrew Jones Designed Bookshelf Loudspeakers Sp Bs22 Lr , Pioneer , Speakers Subwoofers , Speaker Systems , Pioneer Sp Bs41 Lr 130 Watt Rms 2 Way Speaker , Elite Vsx 31 A V Receiver
