Pioneer's Speaker Genius Hits Low Price Point - Page 193 - AVS Forum
 12Likes
post #5761 of 5772 Old 07-25-2014, 05:48 PM
Quoted: 69 Post(s)
Liked: 0
Anyone using anything to raise the 52's a bit? Also curious if everyone is using the Sewell deadbolt banana plugs for the speakers?
Warner2Bruce is online now
post #5762 of 5772 Old 07-26-2014, 08:38 AM
wdeydwondrer's Avatar
Quoted: 16 Post(s)
Liked: 25
I use the deadbolts with no problem. The 5 way on the back of these speakers seems a bit short in depth inside, but they still work no problem. Best banana plug I've ever had.
And I also have my 52s raised. I just built about a 4 inch box and laminated it since I work in a cabinet shop, lol. Filled it with sand and set it there under the speaker. Haven't had any problems /shrug
wdeydwondrer is offline
post #5763 of 5772 Old 07-26-2014, 08:37 PM
Ari David's Avatar
Does anyone have a suggestion for a ceiling mount solution for the SP BS 22-LR?
I'm looking to mount the speaker so it faces straight down
Ari David is offline
post #5764 of 5772 Old 07-26-2014, 08:52 PM
Bond 007's Avatar
Quoted: 130 Post(s)
Liked: 826
Mount some netting on a hook and put the speaker inside the netting.
Bond 007 is offline
post #5765 of 5772 Old 07-27-2014, 11:13 AM
Quoted: 69 Post(s)
Liked: 0
Anyone using/used these speakers in a room my size? If so, how do you like it?
post #5766 of 5772 Old 07-27-2014, 06:16 PM
LGTWHIT's Avatar
If I'm not mistaken and your drawing is to scale, you are sitting quite close to the TV and you have a lot of space behind you. I just bought the bookshelfs for my basement and I'm sitting about 11ft away from TV. Paired with the Dayton 12" sub I am more than impressed. So impressed I'm moving my blue ray player downstairs from my $3k setup upstairs. Cost downstairs full setup was $630 including receiver. Got the Amazon deal a couple months back woot woot! So crystal clear and great balance with all types of music and movies. Wait for a sale and buy them!!
LGTWHIT is offline
post #5767 of 5772 Old 07-27-2014, 06:28 PM
Quoted: 69 Post(s)
Liked: 0
I'm about 20 feet from the TV. I actually already have a pair of 52's (got them for $89 for a pair), the CS22 center, and a pair of 22's (my total for all was about $237). Just not sure of my purchase. I also picked up the Infinity 363 towers for $107 each. I'm coming from a Bose Accoustimass Series 3 Series IV speaker system with some ceiling mounted very generic rear surrounds.
I have a Denon X2000 I am going to be using to power whatever I decide on and will be pairing with the Outlaw LF-1 Ex subwoofer. Just want to be sure that whatever I settle on is a definitive step up and not end up disappointed.
post #5768 of 5772 Old 07-27-2014, 08:35 PM
Bond 007's Avatar
Quoted: 130 Post(s)
Liked: 826
Easiest way to find out is to hook em up.
Bond 007 is offline
post #5769 of 5772 Old Yesterday, 11:13 AM
coli's Avatar
Originally Posted by Bond 007 View Post
Quote:Originally Posted by AJCxZ0
He worked for Pioneer, too.
330 lbs each! Tell me thats a typo.
For the best sound, you want a immovable speaker.
coli is offline
post #5770 of 5772 Old Yesterday, 12:29 PM
Bond 007's Avatar
Quoted: 130 Post(s)
Liked: 826
If you want the best sound dont get a pair of 22s. Dont know how thats significant to the netting idea though.
BGLeduc likes this.
Bond 007 is offline
post #5771 of 5772 Old Yesterday, 02:12 PM
Quoted: 69 Post(s)
Liked: 0
I understand that. But, don't really want to unbox them without knowing for sure or without having a good idea.
post #5772 of 5772 Old Yesterday, 04:26 PM
Quoted: 16 Post(s)
Liked: 25
Unboxing doesn't void any warranty or change your ability to return these speakers. Also fairly simple as you just pop it open, slide off the 2 pieces of styrofoam, and you're ready to go. It'll probably take you longer to hook the speaker wire up than to unbox them.
From everything I've learned though, the 52s and the 363 are in the same relative category, the only real difference being a difference in how the upper range sounds to each person. The mids seem to be the same to most people, and the bass is moot for you as you'll be using a sub. So Bond basically boiled it down for you, just need to hook them up and compare in your room.
Reply Speakers
Pioneer Andrew Jones Sp Fs52 Flr Stand Loudspeaker , Pioneer Andrew Jones Designed Bookshelf Loudspeakers Sp Bs22 Lr , Pioneer , Speakers Subwoofers , Speaker Systems , Pioneer Sp Bs41 Lr 130 Watt Rms 2 Way Speaker , Elite Vsx 31 A V Receiver
User Tag List
