Pioneer's Speaker Genius Hits Low Price Point - Page 201 - AVS Forum | Home Theater Discussions And Reviews
 87Likes
post #6001 of 6425 Old 08-19-2014, 04:37 PM
Quoted: 256 Post(s)
Liked: 41
Originally Posted by niccolo View Post
Those look promising, thanks!
I think I saw these recommended before for the Pioneer bookshelf speakers: http://www.amazon.com/SANUS-SYSTEMS-...speaker+stands
Warner2Bruce is offline
post #6002 of 6425 Old 08-19-2014, 04:53 PM
wdeydwondrer's Avatar
Quoted: 30 Post(s)
Liked: 27
Have those for my parent's Sony bookshelves which are about the size of the c22 on end. They've never had a problem with them.
wdeydwondrer is offline
post #6003 of 6425 Old 08-20-2014, 06:28 AM
Quoted: 203 Post(s)
The Sanus is also a big improvement on looks.
justdiscovering is offline
post #6004 of 6425 Old 08-20-2014, 07:13 AM
Bond 007's Avatar
Quoted: 2371 Post(s)
Liked: 1907
But theyre not adjustable and 31" is probably too short for surrounds.
Bond 007 is offline
post #6005 of 6425 Old 08-20-2014, 07:27 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Originally Posted by justdiscovering View Post
Yea you're right, I'll try and fiddle woth the f12 in the mean time, my living isn't that big, so I don't need a show stopper of a sub, maybe I can get the f12 to where I need it.
Minidsp sells some great digital eqs for just over $100 that could be used to tune up your sub if the system tuning options of your AVR aren't up to it.
Products like this one can take a lot of angst out of optimizing subwoofers. Its like headphones, I don't know why there is so much heavy breathing about subs when the differences among a lot of them can be tuned out with a good eq.
arnyk is offline
post #6006 of 6425 Old 08-20-2014, 04:16 PM
Quoted: 256 Post(s)
Liked: 41
As long as the 31 inches cleared his listening area why wouldn't they be alright?
post #6007 of 6425 Old 08-20-2014, 05:22 PM
niccolo's Avatar
Quoted: 139 Post(s)
Liked: 39
I currently have my surrounds' tweeters at ear-level, just as one would want a front speaker. But my impression is that surrounds are supposed to be quite a bit higher, to create a more diffuse sound rather than firing right at the ear. But since the tweeter is more sensitive to position than the woofer, this doesn't entirely make sense to me. Maybe others will weigh in.
Benq W1070 projector w/ Chief RSM mount with custom interface bracket
119" Da-Lite Cinema Contour with High-Contrast (gray) Da-Mat screen
Denon X2000 receiver fed by Panasonic DMP-BDT210 Bluray player
Focal Chorus 700-series towers and center, JMLab Tantal 500-series bookshelf rears
Rythmik FV15HP sub
niccolo is offline
post #6008 of 6425 Old 08-20-2014, 06:52 PM
Nikwasi's Avatar
Quoted: 88 Post(s)
Liked: 89
I have my FS52 surrounds elevated 16" off the floor, which puts them well above seated ear level. They sound better and seem to equalize better at that height. I run my surrounds a little on the hot side, too.
Nikwasi is offline
post #6009 of 6425 Old 08-20-2014, 07:09 PM
Pentothal's Avatar
What did you use to elevate them off the floor?
Pentothal is offline
post #6010 of 6425 Old 08-20-2014, 07:17 PM
Nikwasi's Avatar
Quoted: 88 Post(s)
Liked: 89
I'm using wrought iron plant stands. Yes really. They're just the right height and plenty stable. The stands and the bottom portion of both surrounds are mostly hidden behind furniture so nobody notices, and even if they did I wouldn't care. Sound comes first.
Guerilla audio!
Nikwasi is offline
post #6011 of 6425 Old 08-21-2014, 05:54 AM
redfive's Avatar
Quoted: 36 Post(s)
Quick Review
I picked up a pair of Dennis Murphy's Affordable Accuracy BS-22 Mods, and I have been pleasantly satisfied with them. The purchase price for them was 165 plus shipping, and I have them hooked up to an old Pioneer Elite AVR in my bedroom.
I would say they have a nice laid back sound that image pretty well. The mid-bass can sometimes get a bit "busy" (congested might be a better term?), but they are enough quality to separate good and bad recordings pretty easily. I'd definitely recommend them to someone looking for a small setup.
I'm wanting to listen to his modded towers as well at 275 a pair now.
XBL : SAVIOUR KING
redfive is offline
post #6012 of 6425 Old 08-21-2014, 06:47 AM
Quoted: 203 Post(s)
Originally Posted by redfive View Post
Quick Review
What's molded about them?
post #6013 of 6425 Old 08-21-2014, 06:48 AM
Quoted: 203 Post(s)
Quick Review
What's modded about them?
post #6014 of 6425 Old 08-21-2014, 08:43 AM
Hspecialist's Avatar
Crossovers, upgraded tweets, and if I recall some enclosure dampening. Smoother response and enhanced resolution.
Brian in Bakersfield...
Hspecialist is offline
post #6015 of 6425 Old 08-21-2014, 10:39 AM
redfive's Avatar
Quoted: 36 Post(s)
Here's the link to the Philharmonic website :
http://philharmonicaudio.com/folio-m...ages/AALS.html
I've always really liked the Vifa tweeter.
XBL : SAVIOUR KING
redfive is offline
post #6016 of 6425 Old 08-21-2014, 10:56 AM
coli's Avatar
Quoted: 203 Post(s)
Liked: 42
Has anyone found speaker stands that put the BS22 at the right height for surrounds, are relatively stable, and not too pricey?
Concrete blocks
coli is offline
post #6017 of 6425 Old 08-24-2014, 07:43 AM
butie120's Avatar
Quoted: 340 Post(s)
Liked: 68
Back on sale on Amazon for the typical sale price. Bookshelves and a tower go for $87 while the center goes for $67. Not the best price we've seen lately, but still good.
butie120 is offline
post #6018 of 6425 Old 08-24-2014, 04:22 PM
Nikwasi's Avatar
Quoted: 88 Post(s)
Liked: 89
I finally relented and ordered a pair of Sanus short stands for my surrounds since I found a decent price with B&H. That does not reflect a change in my bad attitude toward speaker stands, however. Now I have to find some vegetation to occupy the plant stands. Kudzu maybe?
Nikwasi is offline
post #6019 of 6425 Old 08-24-2014, 08:17 PM
Quoted: 30 Post(s)
Liked: 27
Plastic plants, less maint.
Nikwasi likes this.
post #6020 of 6425 Old 08-24-2014, 10:48 PM
dynfan's Avatar
Well I needed something for my theater room to play "temporary duty" while I work on my next upgrade. Earlier this year I sold off my Dynaudio Contour setup and I picked up a paid of FS52's and a C22 from Best Buy today. They had the 52's for $90.99 on sale through the end of August and the C22 for $69.99. The bonus us that they will price match Amazon Prime and so I got them for $86.99 and $66.99.
I set them up in my theater and they are amazing for the money. I am feeding them way more power than they are rated for but I have them crossed over properly and will be easy with the volume control.
My initial impressions are that the tweeter and midrange performance are just fantastic for the $! They are articulate and perhaps a little laid back. Overall the image pretty darn good too.
The lower bass region performance certainly isn't anything to write home about but as other's have said, a quality sub and crossing them over actually improves the mid-bass punch.
So far I am happy with my purchase and and happy to have a functioning theater room again!
dynfan is offline
post #6021 of 6425 Old 08-24-2014, 10:49 PM
dynfan's Avatar
FWIW Best Buy will price match Amazon Prime. Their policy is that as long as it is an Amazon direct price they will match. Just did it today on a set.
dynfan is offline
post #6022 of 6425 Old 08-28-2014, 12:58 PM
Sparky1017's Avatar
FWIW-
Pioneer's website has the entire 5.1 set listed (SP-PK52FS) for $354.99! That's a pair of bookshelves, center, 2 floorstanders, and 8" sub!
I printed and price matched at the local BB. Cannot wait to try these babies out!
Sparky1017 is offline
post #6023 of 6425 Old 08-28-2014, 01:54 PM
Nikwasi's Avatar
Quoted: 88 Post(s)
Liked: 89
Pictured: One of my FS52 surrounds mounted on a Sanus NF18B stand, speaker base removed. Height from floor to top of speaker 51".
Name:	FS52 stand.jpg
Nikwasi is offline
post #6024 of 6425 Old 08-28-2014, 02:58 PM
Quoted: 30 Post(s)
Liked: 27
That looks..... interesting.
post #6025 of 6425 Old 09-13-2014, 08:01 PM
Quoted: 256 Post(s)
Liked: 41
What is everyone using for stands for the 22's as surrounds? I mentioned the Sanus 31 inch ones but it seems those may not be high enough... I should mention I have an 18 month old.
post #6026 of 6425 Old 09-14-2014, 01:07 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
I had the Sanus stands, and when my son started crawling I got rid of them.
Warner2Bruce likes this.
GusGus748s is offline
post #6027 of 6425 Old 09-14-2014, 06:24 AM
Bond 007's Avatar
Liked: 1907
Yeah. I was gonna say that with an 18 month old you should look into wall mounting them. Maybe put them on a couple of end tables.
Bond 007 is offline
post #6028 of 6425 Old 09-14-2014, 10:22 AM
butie120's Avatar
Quoted: 340 Post(s)
Liked: 68
Speakers on sale at Newegg. Bookshelves for $79, tower for $79, and center for $69.
butie120 is offline
post #6029 of 6425 Old 09-14-2014, 10:30 AM
Nikwasi's Avatar
Quoted: 88 Post(s)
Liked: 89
Disclaimer regarding my FS52s mounted on the 18" Sanus:
Stability is very good but not excellent using blu-tack and carpet spikes. They are plenty stable for my home environment, where there are no young children or circus dogs and only the occasional 2.5 earthquake. I would not recommend this configuration for everyone (obviously).
Do my surrounds sound better elevated to 51 inches? Yes!
Nikwasi is offline
post #6030 of 6425 Old 09-14-2014, 12:20 PM
Quoted: 256 Post(s)
Liked: 41
I had purchased these a while back but never got around to having them mounted: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Anything else I should consider before I work on getting them mounted or that I should know prior to?
Reply Speakers
Pioneer Andrew Jones Sp Fs52 Flr Stand Loudspeaker , Pioneer Andrew Jones Designed Bookshelf Loudspeakers Sp Bs22 Lr , Pioneer , Speakers Subwoofers , Speaker Systems , Pioneer Sp Bs41 Lr 130 Watt Rms 2 Way Speaker , Elite Vsx 31 A V Receiver
