Pioneer's Speaker Genius Hits Low Price Point - Page 202 - AVS Forum
 26Likes
post #6031 of 6037 Old 09-14-2014, 12:07 PM
Bond 007's Avatar
Quoted: 301 Post(s)
Liked: 852
Originally Posted by Warner2Bruce View Post
I had purchased these a while back but never got around to having them mounted: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Anything else I should consider before I work on getting them mounted or that I should know prior to?
Those are the exact ones I use for my speakers. They are made for square speakers but should work fine with the Pioneers. Get some BluTack and use it to help keep the speakers stuck to the mount.
Bond 007 is online now
post #6032 of 6037 Old 09-14-2014, 12:52 PM
Quoted: 127 Post(s)
Liked: 5
That's good to know. I'm not familiar with the BluTack. Do you just apply it over the whole bottom of the speaker?
Warner2Bruce is online now
post #6033 of 6037 Old 09-14-2014, 02:20 PM
Bond 007's Avatar
Quoted: 301 Post(s)
Liked: 852
No. Since the bottom of the speaker is bigger than the mount base you would be able to see it on the speaker. Cover the mount base with it and then put the speaker on it. That way it will never be seen.
It holds really well and will not leave any residue or marks on the speaker. To remove the speaker you just gently pry it up from any corner with a screwdriver or puddy knife and remove slowly.
And, of course, use the clamps on the mount.
My speakers weigh more than the Pioneers and I have the mounts angled all the way down. They havent moved the slightest in about 2 years.
Its a good idea to check the screws every once in a while to make sure the clamps havent loosened any. After about a month I checked them and they had lossened slightly.
post #6034 of 6037 Old 09-17-2014, 08:01 AM
Quoted: 127 Post(s)
Liked: 5
Thanks for clarifying and the tip! Before I have the 22's installed with that VideoSec speaker clamp I would like to know if there is much of a difference between the 22's and these speakers that are already ceiling mounted in my home: http://www.retrothing.com/2011/06/minimus-speaker.html
post #6035 of 6037 Old 09-17-2014, 08:28 AM
Bond 007's Avatar
Quoted: 301 Post(s)
Liked: 852
No specs listed at that link but I think its safe to say it will be a noticeable upgrade.
post #6036 of 6037 Old 09-17-2014, 09:09 AM
Quoted: 127 Post(s)
Liked: 5
Not sure if this helps: http://murphyblaster.com/content.php?f=minimus.html
I am sure you are right but wonder if they would serve well as a 6th and 7th speaker if I kept them ceiling mounted but moved them back some.
post #6037 of 6037 Old 09-17-2014, 12:13 PM
Bond 007's Avatar
Quoted: 301 Post(s)
Liked: 852
Judging by the description they dont handle volume well. They would probably just muddy up the overall sound of your system. Try it and decide.
Reply Speakers
Pioneer Andrew Jones Sp Fs52 Flr Stand Loudspeaker , Pioneer Andrew Jones Designed Bookshelf Loudspeakers Sp Bs22 Lr , Pioneer , Speakers Subwoofers , Speaker Systems , Pioneer Sp Bs41 Lr 130 Watt Rms 2 Way Speaker , Elite Vsx 31 A V Receiver
User Tag List
