Pioneer's Speaker Genius Hits Low Price Point - Page 204 - AVS Forum
 32Likes
post #6091 of 6094 Old 12-09-2014, 07:56 AM
Gov
Gov's Avatar
Quoted: 27 Post(s)
Liked: 118
Picked up some SB22's and matching center for basically a song from Amazon. I have them mated up to a Denon E300 and Dayton Sub-1200 subwoofer. For the money I am completely astonished at how good they sound!! These speakers are definitely the real deal and sound much much better than they cost. I will be recommending these for people looking for speakers on a tight budget for sure.
A 4" woofer on these, really How did Jones do it???
Panny TC-P65VT60 (calibrated by Chad B), Denon AVR-4311, Comcast X1 DVR, Apple TV 3, Sony BDP-S5100, Ascend Acoustics Sierra Towers (mains), Horizon (CC) and HTM-200's (Surr), Dual PSA XV15 Subwoofers!!
Gov is offline
post #6092 of 6094 Old 12-09-2014, 11:07 AM
GusGus748s's Avatar
Quoted: 78 Post(s)
Liked: 602
You can get even better sound if you do this mods: http://www.audiokarma.org/forums/sho...d.php?t=610820
Media Server: UnRaid Server: 15TB of storage and growing :).
http://www.avsforum.com/lists/display/view/id/8599
Home Theater Set Up:
http://www.avsforum.com/lists/display/view/id/8597
GusGus748s is offline
post #6093 of 6094 Old Yesterday, 11:35 AM
Kurtz9's Avatar
Quoted: 30 Post(s)
Hey guys, I tried searching but didn't find much.... trying to figure out ceiling mount options for the BS22s...
I'm upgrading an older Onkyo HTIB 7.1 system... I've already replaced the front towers and center with FS52s and a CS22 respectively... the side and back surrounds are still the Onkyos though as I haven't yet found a reasonable way to mount the BS22s in their place.
Currently the Onkyos (physically much smaller and capable of having screws drilled into them) are mounted sideways on the side walls using a U-shaped metal bracket just slightly wider open than the speaker is long with a screw in the top and bottom of the speaker... and the rears are mounted from the ceiling behind the center couch angled downward using the same sort of brackets.
I've seen some wall-mount clamp/shelf options that might work for the sides... but there's no way whatsoever we can do anything other than ceiling mount for the rears.... the back wall is another 20 feet behind (the living room is open to the kitchen)- and we can't put stands there- apart from pets knocking them over it'd directly block the path through the living room to the backyard doors.
So anybody got a good solution for this? Thanks.
Kurtz9 is offline
post #6094 of 6094 Old Today, 03:09 PM
AJCxZ0's Avatar
Liked: 39
AJCxZ0 is online now
Reply Speakers
Pioneer Andrew Jones Sp Fs52 Flr Stand Loudspeaker , Pioneer Andrew Jones Designed Bookshelf Loudspeakers Sp Bs22 Lr , Pioneer , Speakers Subwoofers , Speaker Systems , Pioneer Sp Bs41 Lr 130 Watt Rms 2 Way Speaker , Elite Vsx 31 A V Receiver
