Pioneer's Speaker Genius Hits Low Price Point - Page 206 - AVS | Home Theater Discussions And Reviews
 34Likes
post #6151 of 6158 Old 02-14-2015, 10:15 AM
webada's Avatar
Hi Guys,
I have a pair of BS22 as my main L/R, C22 for center and its 8" sub. I live in a nyc apartment and don't have a lot of space. I am looking for a pair of surround to mount on back of the wall where my sofa is. The BS22s are too large and not a WAF....
I'm looking to see if anyone has paired a different brand for their surround.... some of the options I'm thinking of are: Cambridge Audio minx, boston acoustic cubes, etc....
Something of a lifestyle cube speakers...
My alternative is to replace my entire speakers with lifestyle cube speakers if mix match isn't a good thing....
Anyone in the similar situation and have found a good alternative for the surrounds?
Thanks in advance
webada is offline
post #6152 of 6158 Old 02-14-2015, 10:33 AM
LastButNotLeast's Avatar
Quoted: 441 Post(s)
Liked: 369
It is not as important to "timbre match" the rears to the mains. Surround sounds are usually ambient and not critical. I use in-walls with my first gen Pios and it's fine. Better ones, of course, are more desirable just on principle.
You DON'T want to replace your mains with cubes.
M.T.Nest and charmerci like this.
Downloadable FREE demo discs:
http://www.avsforum.com/t/1475769/de...ently-authored
Did you really need to quote that entire post in your reply?
LastButNotLeast is offline
post #6153 of 6158 Old 02-14-2015, 05:45 PM
webada's Avatar
Thanks for your advice. I didn't really want to part with the pioneers, they are really excellent consider the price. I was gunning for a set of B&W until I demo'ed both.... for 80% performance for 1/5 of the price...
now on to search for a WAF surround....
webada is offline
post #6154 of 6158 Old 02-14-2015, 06:15 PM
Gov
Gov's Avatar
Quoted: 44 Post(s)
Liked: 141
You have a PM
Main HT Room: Panny TC-P65VT60 (calibrated by Chad B), Denon AVR-4311, Comcast X1 DVR, Apple TV3, Sony BDP-S5100, Speakers: Ascend Acoustics Sierra Towers, Sierra Horizon and HTM-200SE, Dual Power Sound Audio XV15 Subwoofers
Basement HT Room: Panny TC-P58V10 (Black Level Restored!), Denon AVR-E300, Comcast X1 STB, Sony BDP-S590, Speakers: Wave Crest Audio HVL-1 (L/C/R), Pioneer SP-BS 22 (Surr) and Power Sound Audio XV15 Subwoofer
Gov is offline
post #6155 of 6158 Old 02-18-2015, 10:09 PM
Liked: 0
Not sure if it has been covered yet, but I have noticed that the center speaker of the 2nd gen sounds a bit different than the bookshelves in my system. I kinda want to try a BS22 for the center on it's side, but would this mess up the dispersion characteristics?
Pint4Me is online now
post #6156 of 6158 Old 02-19-2015, 02:49 PM
Quoted: 42 Post(s)
Can anyone recommend some speaker stands they are happy using with the BS-41s (or equivalent)?
pitpat is online now
post #6157 of 6158 Old 02-19-2015, 02:54 PM
Bond 007's Avatar
Quoted: 541 Post(s)
Liked: 925
I would say yes. If you're gonna use a bs22 for center mount it vertically. If you can't do that use a c22.
Bond 007 is offline
post #6158 of 6158 Unread Today, 09:54 PM
Liked: 0
Yep, it may be worth a try. They are so inexpensive, that it would probably be just fine to repurpose them if needed. I will see what I can do to get another pair in and report back.
Reply Speakers
Pioneer Andrew Jones Sp Fs52 Flr Stand Loudspeaker , Pioneer Andrew Jones Designed Bookshelf Loudspeakers Sp Bs22 Lr , Pioneer , Speakers Subwoofers , Speaker Systems , Pioneer Sp Bs41 Lr 130 Watt Rms 2 Way Speaker , Elite Vsx 31 A V Receiver
