JBL Pro 3677 Have arrived!!! - Page 21 - AVS Forum | Home Theater Discussions And Reviews
 33Likes
post #601 of 614 Old 08-10-2016, 01:36 PM
Umar_Naseer's Avatar
Quoted: 14 Post(s)
Liked: 5
Originally Posted by cdy2179 View Post
Have you run xt32 on them? It'll get rid of the Xcurve and make them nice and flat to around 15k.
But yeah... they are an insane value.
I have a Marantz SR7007 so I used XT. It did a great job.
Umar_Naseer is offline
post #602 of 614 Old 08-10-2016, 06:16 PM
Quoted: 14 Post(s)
Liked: 5
Some more pictures.
post #603 of 614 Old 08-11-2016, 04:32 AM - Thread Starter
cdy2179's Avatar
Quoted: 574 Post(s)
Liked: 329
Looking good. Can you toe the mains in toward the center of the listening area? Like any speaker they really open up with a little tweaking. I'd try aiming them at the center headrest to start with.. maybe even a little more toe in.
Also You really need to get them up some.. the screen frame is smack dab between the two drivers.. I'd lift them up off the floor so the entire speakers are behind screen.
cdy2179 is offline
post #604 of 614 Old 08-11-2016, 08:07 AM
Quoted: 14 Post(s)
Liked: 5
Thanks for the suggestions. I'll be building stands soon.
cdy2179 likes this.
post #605 of 614 Old 08-11-2016, 09:39 AM - Thread Starter
cdy2179's Avatar
Quoted: 574 Post(s)
Liked: 329
Sure thing!
Be sure and give a detailed review after you've had enough time to break them in and lived with them for a little while.
They take quite a while to break in. Just play them at moderate volume when you're not home etc. They get smoother and smother as time goes on.
cdy2179 is offline
post #606 of 614 Old 08-22-2016, 07:52 PM
Quoted: 14 Post(s)
Liked: 5
I got the 3677s up off the floor and towed in. I let Audyssey do it's thing and they sound even better now! I am powering them with 3 channels from an Emotiva XPA-5. The only thing is that Audyssey sets the 3677s to -12. Anyone else experience this?
post #607 of 614 Old 08-22-2016, 10:31 PM
Skylinestar's Avatar
Quoted: 894 Post(s)
Liked: 149
That's normal as the 3677 is highly sensitive.
Skylinestar is offline
post #608 of 614 Unread 08-24-2016, 05:23 AM - Thread Starter
cdy2179's Avatar
Quoted: 574 Post(s)
Liked: 329
So this weekend I decided to do the Insulation Mod I did on the first trio of 3677s I had. As I've said before JBL does a really bad job of lining the cabinets. I bought some of the cheap r13 cut for wall cavities wrapped in plastic. Cut 2 pieces to 30" per cabinet. Made a thin cut down the plastic and removed the plastic so I had just insulation. Removed the CD and placed it on top of the cabinet. Removed the woofer and disconnected it. Ran each piece of insulation up through the woofer cutout and into the top. Do not remove the JBL lining.. you're just laying the r13 over it. Put about 4 staples in it and did the other side.
As I've said before the 2035hpl is very similar to the 2226 and r13 seems to be the insulation of choice in the 4pi and the DIY world in general. It definitely makes it even smoother and takes care of resonance. I mean the woofer is responsible for the majority of the vocals. This is a 20 minute mod to do all 3. I'd say it's a must!
Bare places
The lining is maybe 1/2".
As seen in the pics the lining job by JBL is quite pathetic. Super thin and just bad all around. Kinda odd being the cabinet is very well built as well as everything else about the speaker.
ID:	1620361   Click image for larger version
ID:	1620369   Click image for larger version
cdy2179 is offline
post #609 of 614 Unread 08-24-2016, 09:03 AM
storm028's Avatar
Will Roxul fibreglass or poly fill do instead of the R13? Not sure if I can get the R13 locally.
My LCRs arrived days ago. Here's a bad mobile pic of them sitting in the temporary setup until my new place is ready. They really made the screen looked tiny! Hopefully they will eventually end up behind a baffle wall. Meantime, I'll find time to prop some Vibrapod feet under.
storm028 is online now
post #610 of 614 Unread 08-24-2016, 09:08 AM
JBL Pro Cinema Advocate
Molon_Labe's Avatar
Quoted: 1626 Post(s)
Liked: 1716
No they make your subs look small
Molon_Labe is offline
post #611 of 614 Unread 08-24-2016, 09:14 AM
storm028's Avatar
Haha... the 2 pandas are sitting on the 8340s. But you are damn right! The S1 Cap on the right does look diminutive in comparison too
post #612 of 614 Unread 08-24-2016, 09:17 AM
Molon_Labe's Avatar
Liked: 1716
I didn't know those were your surrounds. That would make them little subs...lol
post #613 of 614 Unread 08-24-2016, 09:56 AM - Thread Starter
cdy2179's Avatar
Quoted: 574 Post(s)
Liked: 329
Glad those aren't your subs.. .
As for Roxul.. I'm sure it would work however the fluffy insulation is made for 3.5" wall cavities so it's thicker and extends lower in frequency. It's also looser and won't effect cavity size really. It's just regular insulation used between wall studs and should be easy to find for under $20 at any Lowe's, Home Depot etc. The fluffy is used to line and stuff boxes because it works very well. Don't stuff the box by the way.. just line the back and sides.
storm028 likes this.
cdy2179 is offline
post #614 of 614 Unread Today, 06:42 AM
Quoted: 83 Post(s)
Liked: 9
Roll off at 12khz? What is that like with music, especially high hat-driven music like jazz?
DefTech ProCinema 1000 L/R/SL/SR
DefTech ProCinema 2000 C
DefTech Supercube III
Denon AVR790
Oppo PM-3
GIK bass traps and absorption
sunPin is online now
Reply Speakers
