JBL Pro 3677 Have arrived!!! - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 53Likes
post #631 of 697 Old 09-08-2016, 08:57 AM - Thread Starter
cdy2179's Avatar
Quoted: 732 Post(s)
Liked: 425
I understand, I prefer my speakers without XT32 myself but all ears and rooms are different.
Been running without xt32 engaged for the last few days. It actually still sounds great and I don't miss anything at all. having multiple rows this may be a better option.
cdy2179 is online now
post #632 of 697 Old 09-28-2016, 01:39 PM
Quoted: 20 Post(s)
Liked: 2
Hello!
Hi CDY
hope all is well!
I received my HST 18 subs (2) to go with JBL 3677's and are ready to be placed.
Do I need to place the driver facing towards the wall? What do you recommend?
Also, I am unable to connect Inuke 6000 to any software that is mentioned in these forums? Any manual steps that I can follow? I am using Marantz Sr70009
Thanks for your time.
dwales77 is offline
post #633 of 697 Old 09-29-2016, 05:48 AM
frankie2075's Avatar
Quoted: 453 Post(s)
Liked: 108
Anyone's input on 3677 vs DIYSG F15. Around the same price but much more labor. But dynamics? Better extended highs? Resolution? Midbass?
frankie2075 is offline
post #634 of 697 Old 09-29-2016, 06:16 AM - Thread Starter
cdy2179's Avatar
Quoted: 732 Post(s)
Liked: 425
Originally Posted by dwales77 View Post
Hi CDY
hope all is well!
Just face drivers and ports into the room. Here's some info on sub setup.
The Behringer website has software to interface with the inukes.
Compilation of Multiple Sub setup info
post #635 of 697 Old 09-29-2016, 12:46 PM
Quoted: 20 Post(s)
Liked: 2
Thanks!..As always wealth of info.
cdy2179 likes this.
dwales77 is offline
post #636 of 697 Old 09-29-2016, 03:29 PM
notnyt's Avatar
Quoted: 2160 Post(s)
Liked: 1985
The output from the 3677 tracks the x curve. The fusion 15 does not. If you can EQ the 3677 flat, they'll be fairly similar.
If you can build, no reason not to go with the fusion 15.
notnyt is offline
post #637 of 697 Old 09-29-2016, 03:47 PM
Quoted: 34 Post(s)
Liked: 1
are these jbls easily mountable?
i wanna mount them behind an AT screen.
azizk5 is offline
post #638 of 697 Old 09-29-2016, 03:54 PM
notnyt's Avatar
Liked: 1985
If you're referring to the 3677s, you'll need to build some kind of shelf. They're not light.
notnyt is offline
post #639 of 697 Old 09-29-2016, 04:47 PM
DrDyna's Avatar
Quoted: 109 Post(s)
Liked: 64
The big yummy waveguide is nice too.
DrDyna is offline
post #640 of 697 Old 09-29-2016, 05:07 PM
Quoted: 34 Post(s)
Liked: 1
any recommendations on material and mount?
azizk5 is offline
post #641 of 697 Old 09-29-2016, 05:23 PM
Umar_Naseer's Avatar
Quoted: 21 Post(s)
I used small tables from ikea. I've got an acoustically transparent screen so they're out of sight. The center sits on my Captivator 1400.
Umar_Naseer is offline
post #642 of 697 Old 09-29-2016, 05:38 PM
notnyt's Avatar
Liked: 1985
I'd consider flipping the middle one or raising the sides so that the waveguides are all at the same height.
NWCgrad likes this.
notnyt is offline
post #643 of 697 Old 09-30-2016, 08:28 AM
Quoted: 453 Post(s)
Liked: 108
So if there was no building involved with the f15 wouldn't it be a better speaker then the Jbl? Bigger wave guide no xcurve. Better fq response?
post #644 of 697 Old 10-01-2016, 04:47 AM
DrDyna's Avatar
Quoted: 109 Post(s)
Liked: 64
I haven't heard the 3677, but I've got the F15. I don't think there's much a 3677 would do that these won't, they're fantastic.
I'd be willing to wager the directivity is better, even.
I would be happy to be proven wrong if someone has a set of 3677 to loan me for a weekend
DrDyna is offline
post #645 of 697 Old 10-01-2016, 06:38 AM
Quoted: 453 Post(s)
Liked: 108
Do you have the new version?
Where are you located?
post #646 of 697 Old 10-01-2016, 06:56 AM
DrDyna's Avatar
Quoted: 109 Post(s)
Liked: 64
I have whichever version was shipping earlier this year.
About 1300 miles from you
DrDyna is offline
post #647 of 697 Old 10-01-2016, 04:08 PM
Quoted: 453 Post(s)
Liked: 108
Think you might have the V2
Shoot!
post #648 of 697 Old 10-01-2016, 04:37 PM
DrDyna's Avatar
Quoted: 109 Post(s)
Liked: 64
Shoot!
Deez one.
DrDyna is offline
post #649 of 697 Old 10-02-2016, 06:35 AM
Quoted: 453 Post(s)
Liked: 108
Deez one.
Yes those would be them! Awesome!
post #650 of 697 Old 10-04-2016, 06:14 AM - Thread Starter
cdy2179's Avatar
Quoted: 732 Post(s)
Liked: 425
Here's how I mounted mine.. and yes 3677s now sit there.
Another Build Thread with no name!
post #651 of 697 Old 10-04-2016, 06:18 AM - Thread Starter
cdy2179's Avatar
Quoted: 732 Post(s)
Liked: 425
I'd think the biggest difference post EQ would be the woofer. Both being crossed where they are handling at least half the vocal range. Not to mention mid bass. JBL is know to be extremely smooth and have great midbass. Now I have not heard the F15 but I know a guy who had DIY QSC 2150s said they were better than his F15s and he even did a blind test with family members and all agreed.. and the 3677 to my ears is extremely similar to the 2150s I had.
post #652 of 697 Old 10-04-2016, 07:54 AM
Quoted: 453 Post(s)
Liked: 108
I like having a 3 way speaker. When I had my 1099s but just wanted more midbass impact and a little more extension. I looked at the 2150s they interest me but there's not info on them that I can find. 4722 looks like the go to speake. But I really don't want to spend almost 4g. 3677 seems great but I wonder how it does with music?
post #653 of 697 Old 10-04-2016, 08:15 AM
Quoted: 21 Post(s)
Hey Frankie - I'm in Virginia, if you want to listen to the 3677s.
post #654 of 697 Old 10-04-2016, 08:56 AM
Quoted: 453 Post(s)
Liked: 108
Thank you sir but that's a bit far
post #655 of 697 Old 10-04-2016, 09:33 AM - Thread Starter
cdy2179's Avatar
Quoted: 732 Post(s)
Liked: 425
A 3 way speaker is not an advantage. The best speaker if it existed would be a single driver with no crossover points.
From GTGs on AVS with 1099s and Frankenstein 2150s (was using a single 12" driver which handles 500hz and down) I'd say it's a lateral move although the 2150 wasn't in a baffle wall as intended but in two GTG the pretty much went back and forth. Once the 2150 is in a baffle wall midbass and bass down to 30hz will make you question if you need a sub as it will violate the room with extreme tactile bass.
As for music there's tons of info on this thread..including the Andrew Robinson reviews on YouTube.
1rst review
follow up review
There's also this site which I linked to earlier in thread.
http://www.lejonklou.com/forum/viewt...9f24&start=100
Now I think they've falling off their rockers thinking an outboard crossover is doing anything and I'm pretty sure any changes they heard was due to the drivers breaking in.
post #656 of 697 Old 10-04-2016, 09:45 AM
Liked: 0
It's hard to tell by the pictures but I would put the blame on JBL. All the speakers I have purchased have used wide Styrofoam corners on the speakers which allows a lot of mishandling by UPS without damage. Packing has really improved over the years but not to the extend that UPS can't destroy a shipment once in a while.
KaydenBen is offline
post #657 of 697 Old 10-04-2016, 09:49 AM - Thread Starter
cdy2179's Avatar
Quoted: 732 Post(s)
Liked: 425
Hmm.. the only issue would be over half the vocal come from the woofer. Flipping it gets the woofers even farther apart. I'd try moving the sub and getting another table or flipping the sub on its side getting all 3 in line.
post #658 of 697 Old 10-04-2016, 10:52 AM
Quoted: 453 Post(s)
Liked: 108
1rst review
https://www.youtube.com/watch?v=1pvBC0msHUQ
follow up review
https://www.youtube.com/watch?v=5hHZOUFY-xw
I seen those reviews with Andrew. I know there's more of the Jbl reviews. But I don't see much about QSC? I have to see if I can find the GTG thread again. Was the 2150 clones of the original. Or he tweaked it?
post #659 of 697 Old 10-04-2016, 11:03 AM - Thread Starter
cdy2179's Avatar
Quoted: 732 Post(s)
Liked: 425
Same exact wave guide assembly just different woofer. So basically the same as OEM from 500hz and up. Of course I owned OEM 2150s.
post #660 of 697 Old 10-04-2016, 11:21 AM
Quoted: 453 Post(s)
Liked: 108
I just started reading that other forum hat you posted and seen you owned the 2150s. And you went back to the Jbls. Why? Do you still have the JBLs and how do you like them today? For movies and music?
Reply Speakers
