JBL Pro 3677 Have arrived!!! - Page 27 - AVS Forum | Home Theater Discussions And Reviews
 69Likes
post #781 of 802 Old 08-16-2017, 12:07 PM - Thread Starter
cdy2179's Avatar
Quoted: 792 Post(s)
Liked: 481
Originally Posted by notnyt View Post
wat?
the 8350s and 9310/9300 are awesome. The scs8 too.
I should add that I've only owned the 8340a and 8330a. Both were quite bad IMO, probably worst speakers I've owned. The others I haven't had in my room to demo. I have not heard the ones you mentioned.
As for the "wat". If that's referring to timbre matching they aren't even close. None of the drivers are the same.. not even close and sound worlds apart. To even be slightly timbre matched you have to use very similar if not identical drivers. To really be timbre matched they have to be completely identical speakers, all with room treatments that handle reflections in a similar manner to give a like response at the seats to keep the timbre in tact. There's a lot more to it than just using the same speakers but without that .. good luck. That doesn't mean it's not enjoyable. My HTM-12 aren't identical to my 10 volt 10lx speakers.
Timbre differences are easily audible while playing pink noise while at the MLP.
cdy2179 is offline
post #782 of 802 Old 08-16-2017, 12:12 PM - Thread Starter
cdy2179's Avatar
Quoted: 792 Post(s)
Liked: 481
Originally Posted by Molon_Labe View Post
The SCS series aren't bad. What do you not like about them? I would like to hear some Volt 8/10s as surrounds and do an A/B. After having 4722's as surrounds, they all suck but the 4722's surrounds just took up too much real-estate. I should have bought 3677's as surrounds.
As I said above I should have clarified I was speaking of the surrounds I've owned in the 8 series Cinema line often matched with the 3 series and screen array cinema speakers. I've owned the 8340a and 8330a. The volt 10lx is far superior. I'm not sure about the SCS series, I haven't owned them but have heard good things.
cdy2179 is offline
post #783 of 802 Old 08-17-2017, 01:20 AM
Liked: 1
Originally Posted by MICROTECH85 View Post
You know, a large percentage of a movie's soundtrack comes through the center. Quite frankly if you can only have one jbl 3677, the center is the best place to put it. Of course it is ideal to have matching screen channels but it won't kill you not to. the jbl 3677 is so good with dialog. that is its specialty really. It would however be a major issue to have a 3677 as a left channel and a home speaker as a right. However, having said that, there is a big difference in sensitivity from the 3677 to an average home theater speaker. You will likely have a volume level difference of around 13db. You will likely never run your 3677 past 5 watts if your within 10 feet of the speaker. check out this website link to crown audio to get an idea of the the power levels you need and the difference in output between two different sensitivity rated speakers. http://www.crownaudio.com/en/tools/calculators
MICROTECH85
When the 3677 will arrive (as center) I plan to use it with 2 svs ultra bookshelfs as L+R , which are 87db , all with Denon avr 2313, no external power amp(-which I understand its not needed).
do you think its a problem, I mean the part you wrote about volume differences ?
wolverin1 is offline
post #784 of 802 Old 08-17-2017, 04:32 AM - Thread Starter
cdy2179's Avatar
Quoted: 792 Post(s)
Liked: 481
Originally Posted by wolverin1 View Post
MICROTECH85
You'll use trims in the AVR to adjust for the sensitivity differences so at the seats their levels will be the same. The only issues would be if you cranked it loud enough to run out of power for the SVS. The JBL would remain crystal clear as it doesn't need much power at all but the SVS wouldn't have enough to keep up nor could it even if you had an external amp as it can't handle the power to keep up with the JBL even if the JBL remained on the AVR. Remember the JBL will require 10x less power roughly. Under moderate level listening you'll have no issues.
wolverin1 likes this.
cdy2179 is offline
post #785 of 802 Old 08-17-2017, 05:51 AM
Liked: 1
cdy2179
I never listen at too loud levels. even with 3 svs ultra as LCR the denon didnt seem to run out of air at higher volume and the sound was great. I guess that with a more efficient center the work load would be even better. I hope.
The local JBL rep informed me today that in about 2 month the 3677 will arrive ahhhh, the wait...
cdy2179 likes this.
post #786 of 802 Old 08-17-2017, 01:57 PM
Quoted: 16 Post(s)
Liked: 7
I typically listen to movies with dialog at about 67-70db. Every onece in a while i will go as high as 75db for dialog. My speakers rarely go above 90-95db peak. Subwoofer with low frewuencies needing eq to sp0ound equal to speakers volume will be over 10db higher at the lowest octaves so my sub will hit over 100db sometimes. So if you listen like me, you will rarely see the jbl 3677 use more than 2 watts. A home speaker with 88db sensitivty in my system would require 31 watts to have equal loudness to the 3677 at 2 watts. So like cdy said, if you listen loud, the home speakers could run out of gas. But yeah, set avr center channel to -10db, then set left and right channels to +1-3db as a base, then just make sure they are all equal loudness at listening position.
MICROTECH85 is offline
post #787 of 802 Old 08-18-2017, 02:56 AM
JeffAV's Avatar
Quoted: 21 Post(s)
Where have people purchased this? Any recommendations?
JeffAV is offline
post #788 of 802 Old 08-18-2017, 11:49 AM
Quoted: 16 Post(s)
Liked: 7
I bought mine online from a company called performance audio in utah. But to my knowledge JBL makes the 3677 to order which means no dealer inventory. Hopefully people can still buy them for a while. But jbl may not be making the 2035 anymore. If thats the case,they wont be able to make the 3677.
post #789 of 802 Old 08-18-2017, 01:54 PM - Thread Starter
cdy2179's Avatar
Quoted: 792 Post(s)
Liked: 481
JBL actually makes them in batches... not to order. They just don't have warehouses full so often you must wait for the next batch to come off the line to get them or you may get lucky and the current batch may not be completely spoken for. The first time I bought them I had them in 3 or 4 days.. the 2nd time about 2 weeks. It's the luck of the draw.
You can also get them at full compass. Price should be around $600 or a tad less drop shipped from JBL.
cdy2179 is offline
post #790 of 802 Old 08-18-2017, 02:04 PM
notnyt's Avatar
Quoted: 2772 Post(s)
Liked: 2556
Don't think they make them anymore at all
notnyt is offline
post #791 of 802 Old 08-18-2017, 03:08 PM
Molon_Labe's Avatar
Quoted: 2243 Post(s)
Liked: 2405
My supplier said they still are, but I think this will be the last production run. It appears its the end of an era. It was a good, long run.
cdy2179 likes this.
Molon_Labe is offline
post #792 of 802 Old 08-22-2017, 04:44 AM - Thread Starter
cdy2179's Avatar
Quoted: 792 Post(s)
Liked: 481
I do like the idea of the new line array's coming out for smaller theaters. Those could be some great alternatives.
cdy2179 is offline
post #793 of 802 Old 08-23-2017, 10:24 PM
Skylinestar's Avatar
Quoted: 1207 Post(s)
Liked: 225
Highlighted by @MICROTECH85 , the 3677 is officially vintage. It's no longer listed in the Pro Cinema 3000 series site.
It's weird that the 3678 is still there.
Skylinestar is offline
post #794 of 802 Old 09-14-2017, 08:53 AM
JeffAV's Avatar
Quoted: 21 Post(s)
How will three 3677s as LCR work just off the floor (sound isolation), roughly 12' from listening position?
(And any thoughts comparing to Klipsch RP280 with matching center, surrounds, and upward firing Atmos.)
JeffAV is offline
post #795 of 802 Old 09-14-2017, 11:02 AM
kbarnes701's Avatar
Quoted: 6824 Post(s)
Liked: 5260
Mine work *perfectly* like that. Set so the centre of the horn is at ear height and 11.6 from the MLP. Every day they put a *huge* grin on my face.
K
kbarnes701 is offline
post #796 of 802 Old 09-14-2017, 04:56 PM
Davecraze's Avatar
Quoted: 184 Post(s)
Liked: 60
Has anyone actually had occasion to hear the new JBL 200 series replacements for the 3677? If so, what did you think as compared to the 3677?
http://www.jblpro.com/www/products/c...s#.WbsWrciGOUk
Davecraze is offline
post #797 of 802 Old 09-14-2017, 05:01 PM
Molon_Labe's Avatar
Liked: 2405
I don't think anyone here has them or has even heard them yet. I believe Mark Seaton was saying their desgin required even further imaging requirements than the previous generations. Are you looking to go with JBL Pro Cinema? I am selling my 4722n with the upgraded CDs. PM me if your interested, I can bring them to Dallas. I am in San Antonio
post #798 of 802 Old 09-14-2017, 05:08 PM
Davecraze's Avatar
Quoted: 184 Post(s)
Liked: 60
Unfortunately I only have 12 inches of depth behind my screen or I would likely already own your 4722s. I ended up with three way Klipsch heritage speakers over the 3677s (was tough decision) just because I was curious to try horn mid and horn tweeter LCRs.
post #799 of 802 Old 09-14-2017, 05:14 PM
Molon_Labe's Avatar
Liked: 2405
How you liking the Klipsch? I would like to hear the heritage speakers.
post #800 of 802 Old 09-15-2017, 07:21 AM
Davecraze's Avatar
Quoted: 184 Post(s)
Liked: 60
I have the Quartets and I like them alot for LCR. I cross them at 80hz so no need for larger Forte/Chorus. If I had more room behind the screen, I'd try La Scalas for LCR but with that much room back there, I'd probably also would have long bought JBL 4722s and been happy with them.
post #801 of 802 Old 09-16-2017, 05:29 AM
JeffAV's Avatar
Quoted: 21 Post(s)
K
Saw your room plans..looked like you have them off the floor on blocks. I don't have the ability to do that, they need to be directly on the floor. If that won't work well, will be looking into a Klipsch RP system (280, 450...).
JeffAV is offline
post #802 of 802 Old 09-16-2017, 06:46 AM
kbarnes701's Avatar
Liked: 5260
Yes I have them mounted so that the centre of the horn is level with my ears when in MLP. But if I stand up or sit down, I hear very little difference TBH so I am not sure how critical this is.
Reply Speakers
