How is this 5.1 speaker + reciever combo - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-14-2010, 01:52 PM - Thread Starter
.enigma.'s Avatar
http://www.newegg.com/Product/ComboD...t=Combo.552941
Klipsch HD 500 and ONKYO HT-RC260
I was also considering the same receiver with this speaker set - http://www.newegg.com/Product/Produc...82E16882290174
Any opinions on those options or any other better options. Id like to stay under 600 dollars.
EDIT: I also like this set as well (Denon 591BA)- http://www.amazon.com/Denon-DHT-591B.../dp/B003H04Q7S
.enigma. is offline
post #2 of 5 Old 11-14-2010, 01:58 PM
pistonengine's Avatar
The klipsch I've listened to I've liked, but some people think the tweeters are too harsh. IMO, better bang for the buck going for 2.1 for music. If this is for home theater, you need a center speaker as well.
IIRC I've listened to that exact set of Klipsh and I liked it. The subwooferhas 2 8" drivers and is really tight, but not very deep.
pistonengine is offline
post #3 of 5 Old 11-14-2010, 02:04 PM - Thread Starter
.enigma.'s Avatar
It will be for home theater
Ive also heard people say that the highs are harsh, i think ill probably end up having to listen to it in person before i buy it
.enigma. is offline
post #4 of 5 Old 11-14-2010, 02:15 PM
Always the best. Just remember speakers will never sound as good in your home as they do in a proper display (unless you've treated your home). I also advise buying used, off of craigslist or ebay. Just make sure you actually listen to the setup before exchanging money.
post #5 of 5 Old 11-14-2010, 02:21 PM
sholling's Avatar
Denon 591 vs Onkyo rc260 is a wash. Both are excellent budget receivers. The Onkyo more power but the Denon has a better version of Audyssey room correction so pick the one that means more to me. As far as the speakers go none are going to be all that great because the satellites and subwoofers are so anemic but they are a start. Speakers are so subjective that I'd try to find them at a Best Buy and listen and see which you like better.
sholling is offline
Reply Speakers
