Definitive Promonitor 1000: How to replace Tweeter? Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-17-2010, 07:11 AM - Thread Starter
chinna_n's Avatar
Hi,
I posted this in Definitive Speaker thread, but no one responded. It is too long I guess(703 Pages)
I recently got Definitive Promonitor 1000 front speakers with, Procenter 1000, BP1 rears. Few days ago I observed the tweeter in one of the Promonitor 1000 is not working.
I tried to open the speaker to take it out and check/replace tweeter, but even after removing all front screws I could not pull out the front half/plate to take out the tweeter(As if it is glued).
I was wondering how to replace tweeter, if someone can provide some help. I looked around and did not find any guide to replace tweeter, but if there is a thread already, please provide link to that.
Highly appreciate quick help.
Chinna, WA, USA
chinna_n is offline
post #2 of 4 Old 11-17-2010, 12:21 PM - Thread Starter
chinna_n's Avatar
Come on. No one ever replaced tweeters on these before?
Chinna, WA, USA
chinna_n is offline
post #3 of 4 Old 11-17-2010, 12:47 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Why not call up Definitive Technology. You are going to need their help any way to figure out specifically which tweeter is in there
I have replaced tweets on other speakers. Generally it involved some screw drivers and soldering iron
crazyrob425 is offline
post #4 of 4 Old 11-17-2010, 04:21 PM - Thread Starter
chinna_n's Avatar
I am pretty familiar in the process in general for these things. This in particular, it is not moving even after removing all relevant screws. I want to be cautious, and if there is any special process needed for this specific speaker.
As I said, it seems as if it is glued in addition to the screws. I do not want to scratch trying to use too much force. May be there is some simple way.
Will see if Definitive can help.
Chinna, WA, USA
chinna_n is offline
Reply Speakers
