speakers and amp compatibility? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-13-2010, 03:23 AM - Thread Starter
jjonmon's Avatar
Hi there
I was wondering if anyone could about some info about speakers and amp compatibility?
The speaker spec goes like this
speakers 902i
Sensitivity 89db
Frequency response 55Hz - 22Hz
Impedance 4 - 8
Drive units 1 x 130 (5.25") aluminium CPC mid/bass driver 1 x 125 (1") aluminium dome tweeter
Crossover 1st order with DVP HF
Recommended amplifier power 15 - 100 watts
Magnetic shielding yes
speaker (H x W x D) 290 x 165 x 265mm (11.4 x 6.5 x 10.4")
Weight 5kg (11lbs)
speakers 905i
Sensitivity 90db
Frequency response 60Hz - 22Hz
Impedance 4 - 8
Drive units 2 x 130 (5.25") aluminium CPC mid/bass driver 1 x 125 (1") aluminium dome tweeter
Recommended amplifier power 15 - 120 watts
speaker (H x W x D) 165 x 485 x 200mm (6.5 x 19.1 x 7.8")
Weight 7.5kg (16.5lbs)
TEAC AG-10D amp
Amplifier Section Output Power (Stereo, 0.2 % THD, 20 Hz to 20 kHz, 6 &) 100 W + 100 W
Surround Output Power (0.7 % THD, 1 kHz, 6 &, only one channel driven) . . . . . . . . . . . . . . . . . . . . . . . . . 125 W per channel
Total Harmonic Distortion. . . . . . . . . 0.09 % (at 95 W, 1 kHz, 6 &)
Audio Input Sensitivity/Impedance. . . . . . . *LINE: 200 mV/47 k&
Output Level/Impedance (TAPE REC) . . . . . . . . . 200 mV / 2.2 k&
Frequency Response . . . . . . . . *LINE: 20 Hz - 50 kHz, +0 / -3 dB
Signal-to-Noise Ratio. . . . . . . . . . . . . . . . . . . *LINE: 90 dB (IHF-A)
Tone Control . . . . . . . . . . . . . . . . . . . . . . . BASS: ± 10 dB at 100 Hz
TREBLE: ± 10 dB at 10 kHz
Digital Audio Section
Sampling Frequency . . . . . . . . . . 32 kHz, 44.1 kHz, 48 kHz, 96 kHz
Digital Input Level . . . . . . . . . . . . . . . . . . COAXIAL(75 &): 0.5 Vp-p OPTICAL(660nm): -15 dBm to -21 dBm
I am not sure what all the spec means and there is one I am defiantly not sure about, is the speaker Ohms 4-8 OK for amp at 6 Ohms? Does the speakers range from 4-8 covering the 6 Ohms? Not sure how the Ohms work.
Also could anyone tell me if the amp is compatible with the speakers in general?
thanks for any help
jjonmon is offline
post #2 of 5 Old 12-13-2010, 04:25 AM
maxcooper's Avatar
Quoted: 13 Post(s)
Yes, those speakers are compatible with that amp.
Speakers typically have an impedance rating that they are "4 ohm" or "8 ohm" or whatever, but almost all speakers have different impedance at different frequencies. For example, look at the first graph on this page, which is a graph of impedance vs. frequency for the Magico Q5 speakers:
http://stereophile.com/content/magic...r-measurements
Your speakers have a specified rating of "4 - 8 ohms", which is a bit odd, but I suspect the manufacturer is just trying to say "these speakers work with amps that can handle 4 or 8 ohm speakers".
Pretty much all home electronic amps work fine with 8 ohm speakers. Some amps also work with 4 ohm speakers, and some even work with 2 ohm speakers. Some amps, like your amp, are rated at 6 ohms, which typically inflates the power rating a bit -- the same amp will deliver more power into 6 ohm speakers than it would into 8 ohm speakers, so the amp manufacturer specifies the power rating into 6 ohms to make it sound more powerful than if they posted the power rating into 8 ohms. For example, look at the last chart on the following page, which shows a beefy amp that will deliver 365.1 watts into 8 ohms and 669.8 watts into 4 ohms:
http://stereophile.com/content/krell...r-measurements
This stuff can be a bit tricky to understand, but the bottom line is that your speakers will work fine with your amp.
-Max
maxcooper is offline
post #3 of 5 Old 12-13-2010, 05:38 AM
CatsTide's Avatar
good stuff max...not my question but i learn a lot by reading others threads.
CatsTide is offline
post #4 of 5 Old 12-14-2010, 12:22 PM - Thread Starter
jjonmon's Avatar
Thank you for maxcooper for the reply
The links are very useful, but I have not read them properly yet, need to spend some time on them as I am not very technically minded. But its good to know the speakers are OK with this amp.
Thanks again
jjonmon is offline
post #5 of 5 Old 12-22-2010, 04:59 PM - Thread Starter
jjonmon's Avatar
Hi again
I hopping someone could help as I am not sure about some settings on my amp. This is the page I would like to know about
http://www.fixya.com/support/p172059...-31862/page-42
Do I consider my speakers small or large, not sure my self any help please
thanks
jjonmon is offline
Reply Speakers
