Focal Chorus 8xx vs Monitor Audio RX - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 12-20-2010, 08:11 AM - Thread Starter
motoharu's Avatar
Hi,
I am planning on updating my ht system, so, decisions decisions..
Considering they will mostly be used for Cinema rather than music, what do you recommend?
I will make demo rounds from both brands and decide mostly accordingly, however some expert or educated opinions wont hurt.
Focal:
826V Front + 816V Back + CC800 Center + SW800 Sub.
or
Monitor Audio:
RX8 Front + RX6 Back + RX Center + RS W 12 Sub.
Will these sets do well for cinema experience, or should i look something with a THX cert. like Klipsch Ultra 2, which is almost twice as expensive than MA, or the THX wont matter "that" much?
As a receiver, i am planning on getting a Marantz 7005, or maybe, if there is a definite "no, no!!" comment from you for marantz, Onkyo 808, + it has THX which marantz do not..
My room is almost 5000fc, but sadly L shaped with a large opening on one side for other rooms and stairs to 2nd floor.
Thanx for the input..
motoharu is offline
post #2 of 17 Old 12-23-2010, 12:12 AM
karlsaudio's Avatar
Quoted: 138 Post(s)
Liked: 54
Well, I get Pinocchio in my pants when I listen to Focal products. MA is OK. As for recievers, also look to the Pioneer Elite VSX-32. Don't worry about THX certification. Although the Pio has it.
Go listen to both and choose the one you like best.
Good luck!
Sounds good!
AVR: Denon 1913
L/R: Polk RTiA1
Center: Polk CSi3
Sub: Polk PSW505
karlsaudio is offline
post #3 of 17 Old 12-23-2010, 12:18 AM
karlsaudio's Avatar
Quoted: 138 Post(s)
Liked: 54
Also, none of those subs go really deep. Check out Rythmik or Epik. Maybe even Hsu. And you might want to go with the smaller towers of the brand you pick because you will have the sub doing the dirty work below 60-80 Hz. The money you will save on this can go for a second sub. Which you might need in that room due to size.
Sounds good!
AVR: Denon 1913
L/R: Polk RTiA1
Center: Polk CSi3
Sub: Polk PSW505
post #4 of 17 Old 12-24-2010, 11:04 AM
karlsaudio's Avatar
Quoted: 138 Post(s)
Liked: 54
Did you go have a listen yet?
Sounds good!
AVR: Denon 1913
L/R: Polk RTiA1
Center: Polk CSi3
Sub: Polk PSW505
post #5 of 17 Old 01-06-2011, 11:29 AM - Thread Starter
motoharu's Avatar
I listened both and decided to go for Focals and bought them.
But still trying to choose a TV+Projector combo to start a little build at my cave..
The setup is:
836V Front
816V Back
CC800 Center
SW800 Sub.
and marantz SR7005 as receiver.
motoharu is offline
post #6 of 17 Old 02-09-2011, 09:40 PM
Kerman's Avatar
Are you happy with that setup performance? Im looking on Chorus 5.1 setup, 836v on fronts, CC800 and the only difference are the surround speakers, I'll go with the SR 800 V.
Im still debating on amp, on Elite SC-37, Denon AVR-4311 and Marantz SR7005. I like Ice Power amps on Pio, but heard this one may not pair very well with this speakers, becouse its bright nature. So Im leaning towards Marantz SR7005. Denon is well known as an amp which rocks on home theater setups.
I'll use the most for 80% Movies/games 20% Music. How good performs that setup for HT/games, and music?
Kerman is offline
post #7 of 17 Old 02-09-2011, 10:40 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1037
The panny AE4000 is a great projector that can be had for around 2K.
N8DOGG is online now
post #8 of 17 Old 02-09-2011, 11:17 PM
karlsaudio's Avatar
Quoted: 138 Post(s)
Liked: 54
How loud do you listen to stuff? The Denon 4311 or the Marantz should do OK but, if you want reference level (loud) dBs, you might want to consider separates. Or run external amps on those recievers.
Sounds good!
AVR: Denon 1913
L/R: Polk RTiA1
Center: Polk CSi3
Sub: Polk PSW505
post #9 of 17 Old 02-10-2011, 05:53 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
The Focal is neutral sounding and is good for all types of programs. Any
of those receivers will be fine.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #10 of 17 Old 02-10-2011, 08:12 AM
shodulik's Avatar
I would take the Focals over the Monitor Audio's in any application...for music, movies, elevator background noise, auctioneer's pa system, paperweight, firewood, etc...
Do not care for MA's at all.
shodulik is offline
post #11 of 17 Old 02-10-2011, 09:09 AM
karlsaudio's Avatar
Quoted: 138 Post(s)
Liked: 54
MAs aren't that bad. I finally got a chance to listen to the Silver line. Nice stuff!
Sounds good!
AVR: Denon 1913
L/R: Polk RTiA1
Center: Polk CSi3
Sub: Polk PSW505
post #12 of 17 Old 02-10-2011, 02:04 PM - Thread Starter
motoharu's Avatar
Its been more than a month but i still havent set up the system
Waiting for my curtains and equipment rack to arrive...
motoharu is offline
post #13 of 17 Old 02-10-2011, 10:43 PM
karlsaudio's Avatar
Quoted: 138 Post(s)
Liked: 54
Dude! I would be hooking up some of it to listen. Even if it was sitting on the floor!
Sounds good!
AVR: Denon 1913
L/R: Polk RTiA1
Center: Polk CSi3
Sub: Polk PSW505
post #14 of 17 Old 02-10-2011, 11:15 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Me too!
Who AM I
zieglj01 is offline
post #15 of 17 Old 02-11-2011, 06:29 AM
buddahead's Avatar
The MA RX-8 are considered one of the best speakers in its class for years.It does alot quite good for the price.I have compared them to many others and find them very open and livily.Great for Rock and Pop.I also love the Focal line.Both are great and anyone here who would put down either has never heard both.Lots of trolls here so take the advice here with a grain of salt.
buddahead is offline
post #16 of 17 Old 02-14-2011, 10:57 AM - Thread Starter
motoharu's Avatar
Started to hookup.
Trying to figure out the placement of units and how to tidy up the wires in the rack.
Tomorrow curtains are coming and the PJ screen and TV will be hang.
Electricity will be done wednesday and carpentry things on thursday.
Man its so close, can't wait.
I am still waiting for my PJ tho , hopefully this weekend, and center speaker stand next week..
motoharu is offline
post #17 of 17 Old 02-14-2011, 12:30 PM
karlsaudio's Avatar
Quoted: 138 Post(s)
Liked: 54
Let us know how it sounds!
Sounds good!
AVR: Denon 1913
L/R: Polk RTiA1
Center: Polk CSi3
Sub: Polk PSW505
Reply Speakers
