Please help me decide between these speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-23-2010, 07:21 PM - Thread Starter
Flipangle's Avatar
After reading the helpful posts in the forum, I've narrowed my choices a little bit. However, I still don't know which set of speakers to buy. Here are my choices:
Energy Take Classic 5.1
Klipsch HD 500
Boston Acoustics speakers that come with the Denon DHT-591BA combo.
I also ran into the Mirage MX 5.1. What am I getting for the additional money?
I will be using these speakers primarily for movies and only rarely music. My family room is at least 12' x 17' with 9' ceilings. Thanks! It's so hard to buy speakers when you can't hear them for yourself first!
Flipangle is offline
post #2 of 4 Old 01-19-2011, 03:54 PM
FunHouse Austin's Avatar
Energy is generally more power hungry than Klipsch , but I like the way they sound..
If you want to know if a product is "good", please tell us your definition of "bad" for an understood point of reference. Do you want subjective opinions or objective facts?
- FunHouse Media
FunHouse Austin is offline
post #3 of 4 Old 01-20-2011, 09:26 AM
karlsaudio's Avatar
Quoted: 138 Post(s)
Liked: 54
That room size is borderline for the size of those speakers.
My opinion: 1 Boston
2 Klipsch
3 Energy
I have not heard the specific models you listed but, this is the order of the brands I like here.
Sounds good!
AVR: Denon 1913
L/R: Polk RTiA1
Center: Polk CSi3
Sub: Polk PSW505
karlsaudio is offline
post #4 of 4 Old 01-20-2011, 09:43 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
The energy take classic is the set to get they are the highest rated...
And the energy aren't power hungry at all
Here is a review of that set up
http://www.audioholics.com/reviews/s...classic-review
The bostons have a weak subwoofer, the klipsch struggled in a 15x15 listening room when I tried them
The energy are by far the best out of the ones you wanted
crazyrob425 is offline
Reply Speakers
