Have a look at these Beauties!!!! How to make your OWN "High End" Cables!!! - Page 121 - AVS | Home Theater Discussions And Reviews
 24Likes
post #3601 of 3614 Old 03-08-2015, 12:54 PM
Augerhandle's Avatar
Quoted: 181 Post(s)
Liked: 124
Originally Posted by darthray View Post
Wow!!!
This almost look like a welding cable, personally I would Never use that since it would be not workable and the strands are too big.
Also, the jumpers look like 24awg, so what is the use of a main with 2awg?
Ray
Wire resistance is a function of wire size AND length. The longer the run, the bigger the wire needed, and vice versa. Plus most of the power goes to the low frequencies, which is why the larger cable is on the bottom terminals.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_________________________________________________
Augerhandle is offline
post #3602 of 3614 Old Yesterday, 01:39 PM
Retspin's Avatar
Just got a new Denon AVR-X4000 last month, and it inspired me to make up some new cables. I ended up making both speaker and power cables. For the speaker cables, I used Belden 12 AWG from Blue Jeans Cable, GLS banana plugs, KnuKonceptz cable pants, and Techflex from Furryletters on eBay. For the power cables I bought a 25 ft reel of Southwire 12/3 AWG from Lowes, red Techflex and mixture of Cooper heavy duty power plugs that I had on hand and power plugs ordered on eBay.The longer power cables enabled me to rearrange my entertainment center without having to add another surge suppressor.
ID:	634025   Click image for larger version
ID:	634033   Click image for larger version
ID:	634041   Click image for larger version
ID:	634049   Click image for larger version
ID:	634065   Click image for larger version
Retspin is offline
post #3603 of 3614 Old Yesterday, 02:09 PM
kamouflage's Avatar
Quoted: 70 Post(s)
Liked: 60
Excellent job! I'm thiiiiissssss close to going nuts and making cables for all of my equipment.
Retspin likes this.
PSN ID: javant86
kamouflage is offline
post #3604 of 3614 Old Yesterday, 02:43 PM
Liked: 8
Originally Posted by luma View Post
Quote:Originally Posted by N8DOGG
The Nak plugs with the regular banana ends fit much better IMO :
My last speaker wire project used these plugs and I can't stand them. The plug part is OK, but the housing simply refused to stay screwed tight. I'd prefer not to have to threadlok every single wire I make and will be looking at the GLS options for my next project. Also, the opening for the wire entrance is made for something like 4GA wire (an estimate, not certain), and anything else hangs loosely in the middle of them.
Lets see... 4 year old topic, probably already answered multiple times in the follow 120 pages, but what the heck!?
I keep those pesky housings in place with a drop or two of blue locktite.
Nice tight and secure, but will come apart if you need it to.
darthray likes this.
darknite9099 is offline
post #3605 of 3614 Old Yesterday, 03:59 PM
darthray's Avatar
Quoted: 288 Post(s)
Liked: 263
Good recommendation
I use the red one since it was all I had available and this made the job permanent, so if I want to do any changes, I will need to get new banana plugs.
Ray
darthray is offline
post #3606 of 3614 Old Yesterday, 05:00 PM
Liked: 8
Good recommendation
Ray
I know the original poster said he didn't want to thread lock each one, but seriously, its a drop of loctite and you are screwing them together anyway, so I don't mind using it.
Red should work, its not like we are planning on taking them apart once they are together anyway, right?
post #3607 of 3614 Old Yesterday, 05:09 PM
nezff's Avatar
Quoted: 38 Post(s)
Liked: 34
Not sure why you would need to use loctite on plugs? Ive never had a single issue with mine coming loose. Im assuming anything made in bulk will have its flaws.
nezff is online now
post #3608 of 3614 Old Yesterday, 05:11 PM
nezff's Avatar
Quoted: 38 Post(s)
Liked: 34
You can get that logo off the side of the pants with just a little bit of nail polish remover and Qtip.
Retspin and darknite9099 like this.
nezff is online now
post #3609 of 3614 Old Yesterday, 08:09 PM
Retspin's Avatar
I had fun making mine and I'm sure you will too! It had been 4 years since I made my last set, about the same amount of time that this thread has been around. This thread is what got me started in the first place. I hope to reclaim my man cave in a few years and do it again!
Retspin is offline
post #3610 of 3614 Old Yesterday, 08:10 PM
Retspin's Avatar
Thanks for the suggestion.
Retspin is offline
post #3611 of 3614 Unread Today, 07:35 AM
Quoted: 181 Post(s)
Liked: 124
OR one can buy a different brand of plug and same time and money on the Locktite fix. Seriously, if they come loose, they are defective, why waste more money to fix them? The whole point is to be able to take it apart to change plugs, cables, otherwise one would just solder the wire into the connector.
post #3612 of 3614 Unread Today, 07:37 AM
Quoted: 181 Post(s)
Liked: 124
Funny, we never seemed to assume that until they were stamped "Made in China". Well, unless they were stamped "Made in USA" and made on a Friday.
post #3613 of 3614 Unread Today, 07:46 AM
badgerpilot's Avatar
Quoted: 53 Post(s)
Liked: 33
I love the power chords! I will have to do that some time.
badgerpilot is online now
post #3614 of 3614 Unread Today, 08:07 AM
nezff's Avatar
Quoted: 38 Post(s)
Liked: 34
+1
nezff is online now
Reply Speakers
Monoprice , Harmon Kardon , Cables Interconnects
