Have a look at these Beauties!!!! How to make your OWN "High End" Cables!!! - Page 126 - AVS Forum | Home Theater Discussions And Reviews
 76Likes
post #3751 of 3752 Old 02-01-2016, 07:23 PM
Augerhandle's Avatar
Quoted: 612 Post(s)
Liked: 507
Originally Posted by notacos4u View Post
...I need to also know what the outlet diameter is for the 12 gauge wire with the 1/8" techflex on them so I know what size to order...
The 1/8" on my Belden 12 gauge measures 5mm, but I'd recommend 1/4" Tech flex, because the 1/8" expands too much and shows the wire underneath (unless that's the look you're going for). Ssince shipping won't change much, it might be worth it to get both sizes of Techflex when you order.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_________________________________________________
Augerhandle is offline
post #3752 of 3752 Old Today, 01:44 PM
Liked: 0
14\4 into PE 10 Guage Pants
Originally Posted by nezff View Post
Quote: Originally Posted by enthusiast8
Heres the monoprice cable being used in the braid.
So basically 2 of those wires braided (which is 4 wires in total) together.
I made this real quick for you. It is 12/4 with 10 gauge pants. Fits double 12 gauge in the pants fine. The banana plug is a tad tight, but will work. Another option is to use a skirt and twist the pairs and heatshrink.
How did you get both wires into the pant legs? Am using 14\4 Monoprice
gsp3 is online now
Reply Speakers
Monoprice , Harmon Kardon , Cables Interconnects
