Have a look at these Beauties!!!! How to make your OWN "High End" Cables!!! - Page 131 - AVS Forum | Home Theater Discussions And Reviews
 134Likes
post #3901 of 3905 Old 09-06-2016, 09:52 PM
kyzer soze's Avatar
Quoted: 48 Post(s)
Originally Posted by bluewizard View Post
https://www.youtube.com/watch?v=6ih-94RfMmo
There are several others on YouTube. Really you are not so much making cable as dressing them up.
You can find an assortment of TechFlex wire jackets at Parts Express and on Ebay. Ebay probably has a greater assortment of colors.
Speaker Pants from Parts Express or KnuKoncepts or very common on Ebay and possibly Amazon.
Heat Shrink, which is handy, can be purchased just about anywhere. However, Parts Express (and others) has Heat Shrink in an assortment of colors -
http://www.parts-express.com/nte-hea...0-pcs--080-730
Then simply purchase the wire terminations (Bananas, Spades, Others) to suit your needs and your budget.
Then it is simply a matter of putting it all together.
Most of the Wire Jacket covers a range of sizes. For example, this is Nominal 1/4", but if you stretch it, it shrinks down to 1/8" and if you compress it, it expands to 7/16". Though stretched it is longer, and compressed it is shorter, so remember this when you order the Wire Jackets to make sure you get the right length.
http://www.parts-express.com/techfle...black--082-316
I think I would order on the smaller size and expand it to fit, that way I'm assured of a reasonably tight fit in the Jacket. For example, this 1/8" nominal, has a range of 3/32" to 1/4".
http://www.parts-express.com/techfle...black--082-300
However, the MOGAMI wire has a considerable diameter of about 0.472". 1/4" will expand to 0.4375", that's 0.035" difference, I think I could make it work.
http://www.parts-express.com/mogami-...1-ft--103-1023
Or as an alternative, thin covering In-Wall wire of the same 12ga, is only 0.252" in diameter. Which means the 1/8" would be just 0.002" short, but again, I think I could make it work.
Just a few rambling thoughts.
Steve/bluewizard
I know what i'm doing over the weekend . Thank you so much!!!
kyzer soze is online now
post #3902 of 3905 Old 09-07-2016, 08:26 AM
dashpuppy's Avatar
Quoted: 369 Post(s)
Liked: 192
It's pretty easy, take your time. IMO don't use a lighter go buy a heat gun they are DIRT cheap. AND MEASURE MEASURE MEASURE before cutting Good luck and make sure you post pictures of your end result
dashpuppy is offline
post #3903 of 3905 Old 09-07-2016, 09:02 AM
KenM10759's Avatar
Quoted: 732 Post(s)
Liked: 416
Agreed. I'll never regret picking up my $30 Porter Cable heat gun off Amazon, though you could cheap out for limited use and probably get one for $10 at Harbor Fright.
dashpuppy likes this.
System includes KEF R500 floor standing, R200C center, R100 surrounds, SVS SB2000 subwoofer, NAD T758 receiver, Pro-Ject RPM1 turntable w/ Sumiko Pearl cartridge, Bluesound Vault, Sony BDP-S480 BlueRay player, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer, MCS System cassette deck. The last 2 items are dust collectors but will work if asked.
KenM10759 is online now
post #3904 of 3905 Old 09-07-2016, 09:07 AM
dashpuppy's Avatar
Quoted: 369 Post(s)
Liked: 192
My 12 year old black and Decker was 15$ worked till my kid dropped it now i'll be replacing it with another cheap one
post #3905 of 3905 Old 09-07-2016, 09:41 AM
KenM10759's Avatar
Quoted: 732 Post(s)
Liked: 416
$14.99 ones at Harbor Freight. I've dropped my Porter Cable PC1500HG twice, no noticeable ill effect though it wasn't 4 ft to a concrete floor.
Reply Speakers
Monoprice , Harmon Kardon , Cables Interconnects
