Have a look at these Beauties!!!! How to make your OWN "High End" Cables!!! - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 188Likes
post #631 of 4019 Old 03-05-2011, 09:22 AM
new04quest's Avatar
Originally Posted by nezff View Post
http://forum.blu-ray.com/home-theater-construction/
maybe this one
I skimmed through this thread (Speaker cable sleeving DIY). The guy has the wire stripper, but he stripped the wire with razor blade. The guy have wood floor, but he placed the heat gun directly on the carpet rug. With all that said, I gave him a lot of credit for sharing his work.
new04quest is offline
post #632 of 4019 Old 03-05-2011, 09:28 AM
new04quest's Avatar
Oh, one other note. I read a lot of posts that some posters had problem when they connects their new newly built speaker cable on their A/V component.
Do any of you check your new cable with multimeter, NWA (this over the top), etc before install it in your expensive A/V component? It'll save time and minimize damaging the expensive A/V component.
post #633 of 4019 Old 03-05-2011, 09:37 AM
nezff's Avatar
Quoted: 153 Post(s)
Liked: 75
I definately dont like the clear heatshrink he used.
what problems? Meaning they could have hooked them up wrong etc..?
nezff is offline
post #634 of 4019 Old 03-05-2011, 09:45 AM
OhioLefty's Avatar
O, I thought you said you found it. sorry.
Did you eat the crawfish?
I'll keep looking, thanks guys for trying to help me find it...
Didn't do the crawfish, they weren't "in season" and they wanted me to have fresh. Maybe next time down. I did have boudin, gumbo, jambalaya and shrimp etouffee.
OhioLefty is offline
post #635 of 4019 Old 03-05-2011, 10:03 AM
nezff's Avatar
Quoted: 153 Post(s)
Liked: 75
O, fried boudin balls are awesome. gumbo I eat all the time, crawfish etouffee is great!
nezff is offline
post #636 of 4019 Old 03-05-2011, 12:06 PM
new04quest's Avatar
It is mostly operator error type of issues, because they don't tight conductor snugly in the banana plug. It ends up falling out or getting inconsistent sounds when it vibrated.
For me, I verified all my homemade cables. I connected each end of the cable with banana clip. While testing the continuity, I shake each end to mimic the vibration to make sure it is tightly snug in the banana plug. Sometime, I went the extra mile on some cables. I use the NWA (it is unnecessary) to verify it during coffee time.
post #637 of 4019 Old 03-05-2011, 12:40 PM
nezff's Avatar
Quoted: 153 Post(s)
Liked: 75
Ok. I figured that. I feel real good about my cables. I have never had a single problem (knocking on wood). I usually strip back enough wire to go inside the first screw head on the banana plug. The second screw is mainly for extra hold.
nezff is offline
post #638 of 4019 Old 03-05-2011, 12:46 PM
EndersShadow's Avatar
Quoted: 580 Post(s)
Liked: 906
If your using the GLS locking ones the first screw is to make contact w/ the wire, the second is to hold onto the insulation part of the wire....
My Setup | FS: Nothing right now
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is offline
post #639 of 4019 Old 03-05-2011, 12:48 PM
nezff's Avatar
Quoted: 153 Post(s)
Liked: 75
yes, I know. Ive been working with GLS locking bananas for quite sometime now.
nezff is offline
post #640 of 4019 Old 03-06-2011, 10:33 AM
OhioLefty's Avatar
@nezff
I really like the look of your speaker connections. What size O.D. speaker cable did you use and what size MM pants did you end up using? I know you said that the Tech flex was 3/8" and the heat shrink was 1/2". One other thing, where did you find the really colorful Tech Flex you used in your earlier DIY power cords?
Thanks...
post #641 of 4019 Old 03-06-2011, 04:17 PM
nezff's Avatar
Quoted: 153 Post(s)
Liked: 75
@nezff
Thanks...
I use monoprice 12 AWG cable. Cable pants are 9mm. I ordered 8mm to see if the pants part is longer. The other stuff is made by ViaBlue. Avoutlet has it. I still have a bunch of it from three years ago.
nezff is offline
post #642 of 4019 Old 03-08-2011, 05:12 AM
nezff's Avatar
Quoted: 153 Post(s)
Liked: 75
I confimed this morning that the logo on the KnuKoncept cable pants does come off rather easily. I actually rubbed some of it off with my fingernail.
nezff is offline
post #643 of 4019 Old 03-08-2011, 07:20 AM
Hamilcar Barca's Avatar
Mud bugs! We used to stop at the roadside stands on the way home from work.
The trappers would throw whatever you bought from them in a big pot of boiling
water -- with tabasco if we dared -- and we'd get home five minutes later with
a fresh(!) hot(!!) meal.
And even red beans and rice, when I could get away with sleeping at work.
Hamilcar Barca is offline
post #644 of 4019 Old 03-08-2011, 07:43 AM
nezff's Avatar
Quoted: 153 Post(s)
Liked: 75
Gotta get you some louisiana hot sauce to go with them, and of course BEER!
nezff is offline
post #645 of 4019 Old 03-08-2011, 07:56 AM
And in Monroe, Johnny's "Sweep the Swamp" Pizza, with andouille sausage,
crayfish, and itty-bitty slices of tabasco peppers. What a greasy, disgusting,
delicious mess.
Damn it! Three more hours until lunch and no cajun food for hundreds of miles.
DIY cables don't usually make me hungry.
post #646 of 4019 Old 03-08-2011, 08:00 AM
nezff's Avatar
Quoted: 153 Post(s)
Liked: 75
delicious mess.
you are making me hungry, I think Im going down the road and get some boudin!
nezff is offline
post #647 of 4019 Old 03-08-2011, 09:45 AM
I'm going to do the same except around here boudin is spelled 'chorizo'.
Every place worth living has something delicious to recommend it.
Thanks for the memories of the good food I last had 15 years ago.
I apologize for the dethreading time I spent in reminiscing.
post #648 of 4019 Old 03-08-2011, 12:06 PM
new04quest's Avatar
Jesus Christ..! It is turning into food thread now. Louisiana crawfish/ beer is making me hungry too.
post #649 of 4019 Old 03-08-2011, 12:36 PM - Thread Starter
Pure-Evil's Avatar
Liked: 152
well you can only say so much about cables after all.
cableguy301 likes this.
Pure-Evil is offline
post #650 of 4019 Old 03-08-2011, 01:19 PM
OhioLefty's Avatar
Since I was the one that got it started in the wrong direction (cajun cuisine), let me get it back on track by asking if anybody has measured the KnuKonceptz cable pants in MM for comparison to other manufacture's specs?
KnuKonceptz list their sizes by cable guage and not MM (at least the ones I looked at).
Thanks...
post #651 of 4019 Old 03-08-2011, 01:44 PM
nezff's Avatar
Quoted: 153 Post(s)
Liked: 75
I did get my sample from knukoncept I ordered this morning. Not sure of the size, but it seems too fit tight. The logo does rub off easily.
nezff is offline
post #652 of 4019 Old 03-08-2011, 04:28 PM
OhioLefty's Avatar
What size (gauge) did you order?
post #653 of 4019 Old 03-08-2011, 05:34 PM
nezff's Avatar
Quoted: 153 Post(s)
Liked: 75
Originally Posted by ohiolefty View Post
what size (gauge) did you order?
12
nezff is offline
post #654 of 4019 Old 03-09-2011, 07:15 AM - Thread Starter
Pure-Evil's Avatar
Liked: 152
12
the Knukonceptz pants fit perfectly on 12gwg cables with the white jacketing from monoprice. not sure what you're talking about. they are an absolute perfect fit.
post #655 of 4019 Old 03-09-2011, 08:02 AM
nezff's Avatar
Quoted: 153 Post(s)
Liked: 75
And I have no idea what you are talking about either. I never stated that the pants didn't fit. I actually said that they DID fit tight and the logo does rub off easy.
SandstormGT likes this.
nezff is offline
post #656 of 4019 Old 03-09-2011, 08:40 AM
off easy.
Personally, I misinterpreted your original remark. When you wrote,
but it seems too fit tight I read fit too tight.
post #657 of 4019 Old 03-09-2011, 09:12 AM
OhioLefty's Avatar
Is that with or without Tech Flex?
post #658 of 4019 Old 03-09-2011, 09:40 AM
shiarua's Avatar
^ Thats with the Techflex. In fact, I put electrical tape over the techflex to hold it in place, then put the wire pants on.
shiarua is offline
post #659 of 4019 Old 03-09-2011, 10:31 AM
MattPutt's Avatar
I ordered the cable pants from Knokonceptz last week. Got around to putting one on last night. Ugh!! What a pain that was and my finger tips are in pain right now. I have the regular monoprice 12awg speaker wire and I had to trim quite a bit of the pant just to get the wire somewhat in. (Yes it was the 12 gauge pant) Do you guys have that problem with the in wall wiring? If not I may just to say the hell with what I've done so far and go ahead and order the in wall 12awg and re do my wiring. Luckily I've only ordered enough for my front three and have done techflex to just those three. But if its that much easier to get that mess in there I will definitely be buying the in wall.
MattPutt is offline
post #660 of 4019 Old 03-09-2011, 11:12 AM
nezff's Avatar
Quoted: 153 Post(s)
Liked: 75
I didn't have a problem at all.
nezff is offline
Reply Speakers
Monoprice , Harmon Kardon , Cables Interconnects
