You've gotta admit they sure do make these cables sound good on paper!!!! I love the colourful language!!! And what a STEAL at only $2799.99 for a pair of 8ft cables!!! LOL
HARMONIC TECH - MAGIC TWEETER 8FT SPEAKER WIRE PR
Harmonic Tech’s goal was to create loudspeaker cables that would deliver unrivaled system performance - unleashing all the MAGIC within your system and allowing your speakers to perform to their fullest and previously unattainable potential.
Using a unique blend of Harmonic Technology’s famous 7N (99.99997%) high purity single crystal silver and 6N (99.9997%) high purity single crystal copper conductors, the Magic Tweeter represent the finest in signal transfer between your amplifier and loudspeakers. With completely new technology, it utilizes tremendous quantities of multi gauges, individually insulated conductors with un-compromised construction.
Each individual run contains 10-gauge or higher conduits.
Whichever you choose, these colossal MAGIC runs provide a speaker interface with an unmatched balance of transparency, detail and harmonic balance.
Listening Impression:
• Designed completely from the ground up with nothing but the finest performance in mind, the MAGIC Speaker Cable offers the highest level of transparency, detail and lowest noise floor you can possess today.
• MAGIC Cables deliver optimal performance from your loudspeakers and are the most uncolored and articulate speaker cables that can be built.
• Low bass is both blindingly fast and extremely controlled, offering a synergy of speed and pitch definition that brings music to life.
• Midrange is deliciously rendered, with a vibrancy and truthfulness of timbre that breathes life into the human voice as well as those of the piano, violin and other demanding instruments.
• Treble is extended, smooth and detailed, without the 'edge' and aggressiveness so often found in other cables that provide an artificial sense of detail.
• The cables recreate the upper harmonics of instruments with a sense of detail and ease, yet none of the glare that so often causes listening fatigue.
• Sense of space is both enormous and focused.
• The ability to get both macro, and the more intimate micro, dynamic shadings is breathtaking.
• Shielding from radiated noise allows the cables to push the noise floor to levels that previously have only been imagined.
The result is a stunning level of performance in transparency, timbre, precise imaging, micro and macro dynamic freedom, bass detail and articulation previously unprecedented from any other speaker cable in production today.
