Looking for Bookshelves <$500 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-05-2011, 08:37 PM - Thread Starter
Dagobah11's Avatar
Moved into a new place and no longer have room for my floorstanding wharfdales. Looking to replace them with a bookshelf pair. Room is a bit strange, as it's a large space that shares with the dining area and kitchen, but is sectioned off by islands and sections of the ceiling that come down a few feet. The living room section is roughly 12'x20'.
I've got a entry level onky tx-sr502 receiver, and the ceiling is actually wired for surround sound with wall mounted speakers, but am thinking I'd probably get more bang for my buck with the two bookshelves. No room for a sub. Any recommendations would help me start the search.
Dagobah11 is offline
post #2 of 9 Old 01-05-2011, 08:43 PM
CriPPleR_HD's Avatar
If you can find a pair of Energy RC-10 they should be able to fill that room. http://www.soundstage.com/revequip/energy_rc10.htm
CriPPleR_HD is offline
post #3 of 9 Old 01-05-2011, 09:18 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
If you call or Email them - you may get the price closer to $500 for
the pair. The NHT are good.
http://www.onecall.com/product/NHT/C...aker/_/R-29719
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #4 of 9 Old 01-05-2011, 11:06 PM
karlsaudio's Avatar
Quoted: 138 Post(s)
Liked: 54
For just $100 more, you could get some B&W 685s. One of the best sub $1,000 bookshelves!
Sounds good!
AVR: Denon 1913
L/R: Polk RTiA1
Center: Polk CSi3
Sub: Polk PSW505
karlsaudio is offline
post #5 of 9 Old 01-05-2011, 11:27 PM
bryangreen's Avatar
Originally Posted by karlsaudio View Post
for just $100 more, you could get some b&w 685s. One of the best sub $1,000 bookshelves!
+1
bryangreen is offline
post #6 of 9 Old 01-06-2011, 05:37 AM
Quoted: 73 Post(s)
Liked: 112
There are quite a few bookshelf speakers in that price range. I personally like the Mirage OMD-5. Some others I like are Monitor Audio, PSB, Axiom, Aperion, Ascend, Mordaunt-Short, and Usher.
rnatalli is offline
post #7 of 9 Old 01-06-2011, 05:58 AM
coolsax's Avatar
If you're ok with trying something new, I would look at the Jamo C603
coolsax is offline
post #8 of 9 Old 01-06-2011, 07:37 AM
karlsaudio's Avatar
Quoted: 138 Post(s)
Liked: 54
Go listen to all these brands listed and get the ones you like! And I just saw the "no sub" thing. Get the bookshelf with the lowest bass extension. Some dip down into the low 40 Hz range. Look at there specs for that. But, still listen.
Sounds good!
AVR: Denon 1913
L/R: Polk RTiA1
Center: Polk CSi3
Sub: Polk PSW505
post #9 of 9 Old 01-06-2011, 08:20 AM - Thread Starter
Dagobah11's Avatar
These look rather nice on paper and the reviews I'm reading. Can they be had for under $600 online anywhere?
Reply Speakers
