Looking to upgrade....should I? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-21-2011, 04:32 PM - Thread Starter
kuthedude's Avatar
Hi guys, I am looking to upgrade my center channel. I currently have a Polk Audio CS175. My new Denon I got (after you guys suggested it, and it is amazing btw) pretty much laughed at my center channel, so I think an upgrade is needed. I have been browsing for a couple days and I am looking to spend about 150-200. Maybe over 200 if it is certainly worth it. I found a few on amazon that I am looking at:
http://www.amazon.com/Cerwin-Vega-Cm...652576&sr=8-23
http://www.amazon.com/Klipsch-Synerg...5652624&sr=8-4
http://www.amazon.com/JBL-ES25CBK-Ce...638794&sr=8-15
Any ideas would be very helpful. You guys basically told me what tv to get...love it....what receiver to get....love it....hopefully what center channel to get
Thanks guys!
kuthedude is offline
post #2 of 10 Old 01-21-2011, 04:40 PM
holt7153's Avatar
Quoted: 137 Post(s)
Liked: 221
Thanks guys!
What brand are your front left/right speakers? Ideally your front 3 speakers should be from the same company and specifically from the same "line" so they're timbre matched.
Anything good in life is either illegal, immoral, or fattening.
holt7153 is online now
post #3 of 10 Old 01-21-2011, 04:44 PM - Thread Starter
kuthedude's Avatar
Everything is Polk Audio. Do they really need to be from the same company? Does it make that big of a difference? The two towers are older, as with the center, but still do the trick.
post #4 of 10 Old 01-21-2011, 06:58 PM
holt7153's Avatar
Quoted: 137 Post(s)
Liked: 221
If your existing center is from the same Polk line I wouldn't replace it. If you change your center I would change your mains as well.
post #5 of 10 Old 01-21-2011, 07:14 PM
barryecohen's Avatar
Quoted: 22 Post(s)
I have to agree with Holt.
So much media, so little time...
Oppo BDP-83 > Emotiva UMC-200 > Audio Alchemy OM-150 Dual Mono > Gallo Reference 3.5
_____________________________ > Audio Alchemy OM-150 > Gallo Strada
barryecohen is offline
post #6 of 10 Old 01-21-2011, 07:59 PM - Thread Starter
kuthedude's Avatar
why should they HAVE to be from the same line? just curious
post #7 of 10 Old 01-21-2011, 08:10 PM
Quoted: 22 Post(s)
Because when a sound travels from one side to the other it moves from one speaker to the next. If the speakers don't sound the same, the sound changes as it moves from one speaker to the next. It sounds weird and it's distracting.
post #8 of 10 Old 01-25-2011, 08:44 PM - Thread Starter
kuthedude's Avatar
Ill trust your judgement. Darn, I was kinda hoping for a quick fix, as I can't afford an entire new line.
post #9 of 10 Old 01-25-2011, 08:53 PM
mbyrnes's Avatar
Quoted: 93 Post(s)
Liked: 186
Have you tried bumping the center channel level a few dBs? If the center isn't loud enough it can make the center sound crappy.
You could also look up the line you have and see if they have a larger center then the one you have. Audiogon or ebay may have the larger speaker. You could probably ask in the Polk thread if you can't find the info on your own.
Xbox Live: TheRealMaxPower --- PSN: TheRealMaxPower (no PS4 currently) Panasonic TC-P65VT60    Vienna Acoustic Mozart Grands    Pioneer SC-72   Sony BDP-S790 Xbox One S Astro Mixamp 2013   Soundblaster X7 (Sparkos Op Amps) Schiit Modi Multibit/Magni   LTA MicroZOTL2 AKG K702 65th Anniversary   Fostex TH-X00 Ebony DT990 Pro 250 ohm  Massdrop/Sennheiser HD6XX and PC37X Audio Technica ATH-M50x Antlion ModMic
mbyrnes is offline
post #10 of 10 Old 01-25-2011, 11:17 PM
adamanteus's Avatar
In addition to bumping the db's on the center, try making sure the tweeter is aimed right at your face. You may need to tilt it up or down a bit or move it up or down to ear level. To experiment with tilting you can jam anything like a book under the front or rear to get it angled. If you find it helps, then you can do something nicer like the rubber door stops or some Mono-pads.
adamanteus is offline
Reply Speakers
