Paradigm Millenia One 2.0 mini review - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 39 Old 05-30-2011, 12:12 PM - Thread Starter
warpdrive's Avatar
Liked: 48
Originally Posted by magic12kenneth View Post
That is pretty impressive that the Audioengine N22 amp with 22w can power it with good sound. Just what I needed to know. I need a desktop speaker soon.
yes it does and I really like the N22 because it has a pre-out which goes into the sub (a sub is necessary with these tiny speakers)
Certified Ultra Professional AVS Special Member Class A
warpdrive is offline
post #32 of 39 Old 06-03-2011, 09:59 AM
FerretHunter's Avatar
Quoted: 27 Post(s)
Liked: 32
I'm seriously considering the MilleniaOne 2.0 and MilleniaSub to be the foundation for my computer sound system setup.
I'm curious how the sub connects to the Audioengine N22 amp.
And how are you getting sound in to the Audioengine from your computer?
I'm also considering a small/mini a/v receiver that I could use in place of the Audioengine. Any suggestions?
Ridding the world of ferrets, one stinking critter at a time.
My Ferret-Free Setup
FerretHunter is offline
post #33 of 39 Old 06-03-2011, 12:29 PM - Thread Starter
warpdrive's Avatar
Liked: 48
as my post above....The N22 has volume controlled line level output jacks that you can use to output to the sub.
To get sound into the computer, I have an external DAC but you can plug the Audioengine amp directly into the analog output from your onboard soundcard.
As for a small AV receiver, the one I would buy is the Marantz 1402 http://us.marantz.com/us/Products/Pa...oductId=NR1402. That would be my first choice. It will have bass management so you can choose an ideal 100-120hz crossover
post #34 of 39 Old 06-03-2011, 03:01 PM
Quoted: 27 Post(s)
Liked: 32
What is the DAC you are using?
post #35 of 39 Old 06-03-2011, 03:31 PM - Thread Starter
warpdrive's Avatar
Liked: 48
Headroom Micro DAC which is part of my headphone listening rig.
I would advise something like a NuForce uDAC2 would give you good sound quality for the money.
post #36 of 39 Old 07-17-2011, 12:17 PM
renton007's Avatar
heres a pic of my millenia ones. i just got them and so far they sound great.
i know it takes a month for them to break in
renton007 is offline
post #37 of 39 Old 01-08-2012, 01:41 PM
CHASLS2's Avatar
Quoted: 354 Post(s)
Liked: 125
I plan to buy this setup for 5.1 to replace my Klipsch RF7's RC7 and RS7's. I just sold my 50" Kuro for a bigger 65VT30 and plan to wall mount it and get some much smaller speakers as this is a bedroom setup. I already have a Sunfire True Singnature Sub so i hope it works good with these speakers.
Panny 60VT60 Acurus 200x3
OPPO 83 &103
Pioneer Elite DV 59AVI
Paradigm 490cc B&W 685 S2's
Pioneer Elite SC61 SVS SB13Ultra
2 S-VHS VCR's B&W CM10 S2's
CHASLS2 is offline
post #38 of 39 Old 01-06-2013, 08:12 AM
Sandy Scott's Avatar
Interestingly, the small size notwithstanding, and using a pedestal TV, I currently have two placement options: 1) the left speaker atop a 22" high unused subwoofer on the left and 31" component rack on the right, or 2) On either side of the TV pedestal which is virtually floor level. Will either of these work acoustically? The alternative would be to use speaker stands. Assuming the non-feasibilty of the two choices mentioned, does anyone know of speaker stands that would be appropriate for these small units? Thanks.
Sandy Scott is offline
post #39 of 39 Old 09-10-2013, 07:04 AM
Ricoflashback's Avatar
Quoted: 649 Post(s)
Liked: 349
I picked up the Millenia One (2.0) to be used as back surrounds on my 7.1 theater setup. After break-in, I'm extremely pleased - - great sound. Matches very well with my FL/FR Studio 60's V.2, Center CC-690 and Side Surrounds - Paradigm ADP-590.
I was spaced challenged for rear, back speakers and the Millenia One's wall mounted very nicely. Same tweeter construction as the bigger speakers - - so the timbre matches beautifully and sounds great for movie soundtracks and SACD's.
Home Theater Setup
Samsung UN65ES8000 LCD/LED & BenQ W1080ST & Vizio M43C1
Pioneer SC65 (Pre-Amp) & Emotive XPA-3, 200 WPC
OPPO 103, Comcast Infinity X1, Darbee Darblet
ALL Paradigm - 7.1 - Studio 60's, V.2 (FL/FR) CC-690, V.5 (C)
ADP 590 V.5 (SS), MilleniaOne 2.0 (BS) - Velodyne 810 Sub
Ricoflashback is online now
Reply Speakers
Audioengine N22 Premium Desktop Audio Amplifier
