Infinity Speakers w/Pioneer VSX-1120-K - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-13-2011, 03:11 PM - Thread Starter
shoobe's Avatar
Hi
I have a brand new Pioneer VSX-1120-K AVR. I am in the process of buying new speakers with a budget of around $1,000. I have a small apartment 18x12 and I am looking for a small footprint for speakers.
I am looking at the following, I would like to know if my AVR will be enough for these speakers:
Infinity P162 for fronts and surrounds (4).
Infinity PC250 Center...
Infinity PS212 Subwoofer
I this sub too much for the size of the room? Should I get something smaller?
Please give me a recommendation...on the speakers or something similar..
Thanks for your time.
shoobe is offline
post #2 of 7 Old 02-13-2011, 03:29 PM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
Originally Posted by shoobe View Post
Hi
I use a VSX-920-K and the P162's and it fills my room as loud as you can want. It is about 11 by 17, so you should be absolutely fine.
As for the sub, I don't know a lot about it.
I do like my upgrade of a PC350 center though.
But you will really like the P162's.
bladerunner6 is offline
post #3 of 7 Old 02-13-2011, 03:41 PM - Thread Starter
shoobe's Avatar
Hi
Thanks for responding to my question.
The PC 350 Center is really big and I am not sure if I am going to have enough room on my table.
Do you recommend any specific speaker stands for the P162's?
shoobe is offline
post #4 of 7 Old 02-13-2011, 04:15 PM
Quoted: 20 Post(s)
Liked: 59
Hi
There are lots you could buy, but these are what I bought:
http://cgi.ebay.com/universal-satell...#ht_6597wt_892
They aren't the most elegant speaker stands, but they do work.
As for the PC350, I put mine on top of the tv using this:
http://www.crutchfield.com/p_769CSB1...h=Center+Stage
post #5 of 7 Old 02-13-2011, 05:46 PM
zieglj01's Avatar
Quoted: 939 Post(s)
Liked: 846
Hi
I would look at this sub. The 1120 AVR will be fine.
http://www.hsuresearch.com/products/stf-2.html
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
post #6 of 7 Old 02-13-2011, 06:02 PM - Thread Starter
shoobe's Avatar
Hi
I really like the Infinity PC350 but its really big. I am mot likely going to purchase the Infinity P162's 4 of them. Can you recommend a similar center channel like the PC350 that is smaller in width? I will check out the hsu sub that you posted....also I have wood floors do you they make anything that I can put under the sub to absorb the sound?
shoobe is offline
post #7 of 7 Old 02-13-2011, 06:12 PM
zieglj01's Avatar
Quoted: 939 Post(s)
Liked: 846
Hi
The Infinity PC250 should be fine.
HSU reccomends you put a throw rug under the STF-2 sub
"Your subwoofer was designed to fire downward onto carpet. If you have hardwood flooring, use a
throw rug under the subwoofer."
Look at this for the subwoofers
http://www.amazon.com/Auralex-Subwoo...pr_product_top
And this
http://www.amazon.com/SubDude-HD-Sub...ref=pd_cp_MI_1
Who AM I
Reply Speakers
