moving from 5.1 to 7.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-19-2011, 07:01 PM - Thread Starter
mrwinick's Avatar
I have jamo omega 1's that I bought over 10 years ago. I just bought jamo s606 speakers. I also bought a yamaha v667. So, I can set up both 7.1 surround and also front presence speakers. I'll be using both the old and new speakers. My question is whether I'm better off using the s606's for the surround or rear surround? (where should I put the s606's?)
I'll have the two towers and the new center in front. the old omega 1's will be the 'presence' speakers. I'll be using the old jamo sub too.
Any ideas? Thanks.
mrwinick is offline
post #2 of 3 Old 03-13-2011, 01:03 PM
FunHouse Austin's Avatar
depending on the size of the room and if you want 5.1 or 7.1. what other speakers are in the mix? which Towers are you saying will be in the front?
If you want to know if a product is "good", please tell us your definition of "bad" for an understood point of reference. Do you want subjective opinions or objective facts?
- FunHouse Media
FunHouse Austin is offline
post #3 of 3 Old 04-01-2011, 01:43 PM
still waiting????
- FunHouse Media
Reply Speakers
