3.5mm remote controlled switch - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-22-2011, 12:30 PM - Thread Starter
Carmant's Avatar
Hi
I have a seemingly simple problem for my low-end (temporary) setup, but can't seem to work out exactly what I need.
I have two audio sources
TV- RCA (red/white) out to 3.5mm cable
Airport Express - 3.5mm to 3.5mm cable
So I essentially have 2 x 3.5mm cables which I want to connect to my measly 2.1 speakers, which only have one 3.5mm input.
Ideally, I don't want have to get up and press a switch, because if I am doing that, I might as well just stick with what I have and swap over the cables.
I looked a Y cables (two 3.5mm female to one 3.5mm male), but it seems that there might be issues in overloading the speakers and damaging them?
So I guess I would have to use a switch, but I would like one that can be controlled remotely if they exist. If they don't, are there any manual switches that are recommended?
Thanks for your time,
Carmant is offline
post #2 of 3 Old 02-22-2011, 12:44 PM
greggie's Avatar
I don't have any experience with a remote control audio switch, but a search for just that turns up a number of choices.
For a manual switch I can recommend the Sony SB-V40S A/V Selector.
greggie is offline
post #3 of 3 Old 02-22-2011, 02:13 PM
walbert's Avatar
there do exist remote switches, they're usually in the $40 to $60 range, and you'll probably have to convert that 3.5mm to RCA to use such a device (at least what I'm thinking of); something like this: http://www.amazon.com/RCA-VH915-Sour...8409208&sr=8-9
walbert is offline
Reply Speakers
