Energy RC Micro -- Sound very thin - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 02-25-2011, 02:51 PM - Thread Starter
gsingal's Avatar
Hey guys,
I just bought an Energy RC-Micro 5.1 for my apartment living room (14'x17' with open entryway into kitchen). The speakers sound a lot less rich/full than I expected, which I suspect is due to their size and limited range of the satellites in a reasonably large room.
I'm thinking of upgrading the fronts to CB-10s or CB-20s. RC Minis would be nice but tough to find, and I can get a pair of CB-20s new for 260 or CB-10s for 180. I'm also probably going to keep the Micro center for now even though I know it should probably be upgraded too, mostly because of budget constraints. Any thoughts on that move / suggestions for other upgrades? Would CB-5's be much of an upgrade?
Thanks in advance for your help!
gsingal
gsingal is offline
post #2 of 14 Old 02-25-2011, 03:05 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Replacing the Front left and right and keeping the micro center would still sound thin
Newegg currently has 25% sale on Energy speakers and you could get CB-5's which will be an upgrade overr the RC-micro's.
You can get a pair of CB-5 for $75 which will sound great
crazyrob425 is offline
post #3 of 14 Old 02-25-2011, 11:38 PM
lennath's Avatar
Have you tried setting the crossover setting to 125 or 150 Hz? Most receivers default to 80 Hz therefore you would be missing alot of mid bass therefore the speakers will sound thin.
lennath is offline
post #4 of 14 Old 03-22-2012, 03:32 AM
1C3M4Nz's Avatar
I have the RC Micro 5.1 paired with Yamaha RX-V671.. Great in my current 10'x12' room.. Will be moving to a bigger room 15'x20' soon.. Looking to expand to a 7.1 setup.. Which would be good floorstanders/bookshelves for fronts ? Preferably want to maintain the current center and satellites.. If i get a powerful FS like veritas ones will i have to replace my center to match them? Suggest the best FS/BS which match my current setup.. Need great sound/bass from my fronts..
1C3M4Nz is offline
post #5 of 14 Old 03-22-2012, 05:00 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
You'll definitely need to replace the center if you upgrade the front speakers. In a bigger room the Micros will not sound as good. They'll be fine for surrounds but if you're getting Veritas front speakers then get the Veritas matching center too.
The other problem is I believe the Yamaha 671 uses a single crossover point for bass management, The Micros need to be crossed over at 150hz while the Veritas speakers would be best at 80hz or below.
If you want great bass, get a better subwoofer too.
Afro GT
afrogt is offline
post #6 of 14 Old 03-22-2012, 05:22 AM
1C3M4Nz's Avatar
What are my other options. As i mentioned above i do not want to have to replace center let alone the sub too.. Budget constraints.
Forget the Veritas line i just used it as an example. What other speakers go well with my setup ? Should i just forget about the towers like CF-30/CF-50 or RC series ones too..
Are the Bookshelves more compatible with my setup then.. RC-10/CB-10/CB-5..
1C3M4Nz is offline
post #7 of 14 Old 03-28-2012, 12:38 PM
afrogt's Avatar
Liked: 755
What is your real budget? The RC Micro center will only work well with RC Micro satellites. It is too small to match well with anything else whether they are bookshelf speakers or towers.
Afro GT
afrogt is offline
post #8 of 14 Old 03-28-2012, 01:22 PM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
I would think running a pair of RC-10s without a center would sound better than using the RC-Micro center with them. Then add the center when you can.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #9 of 14 Old 03-28-2012, 01:23 PM
pokekevin's Avatar
Liked: 102
Originally Posted by cel4145 View Post
i would think running a pair of rc-10s without a center would sound better than using the rc-micro center with them. Then add the center when you can.
+1
pokekevin is offline
post #10 of 14 Old 03-28-2012, 01:26 PM
afrogt's Avatar
Liked: 755
Yep, it would a better solution than forcing the RC Micro center into the mix. And the RC-10 is on sale for $250/pr shipped right now. Go for it!
http://www.vanns.com/shop/servlet/it...res/542469405/
Afro GT
afrogt is offline
post #11 of 14 Old 03-28-2012, 02:46 PM
Carl Lee's Avatar
Personally, I would upgrade the Micro center before the L/R speakers. I have the Micros also and thought it sounded the same. I upgraded the center to a V-Mini-C and dropped the X-over down to 80htz and its much better. I do plan to change out the front L/R to the V-Minis in the future and keeping the Micros as the surrounds. Most of your sound comes from the center anyway.
Carl Lee is offline
post #12 of 14 Old 03-28-2012, 03:49 PM
buzzy_'s Avatar
Quoted: 66 Post(s)
Liked: 89
Upgrading the center is a decent option if it's primarily for HT rather than music.
Or consider selling the set and starting over with something suitable for the space and your needs.
buzzy_ is offline
post #13 of 14 Old 12-02-2012, 12:30 PM
pghflyer's Avatar
Carl Lee - did you ever do this and how did it turn out?
I am thinking of picking up an RC-mico set for $140....selling the micro-center, making the Micros be my SR, SL, RSL, and RSR.....and then using a veritas Mini for FR, FL ($100 each)..with veritas Mini center ($180)...and ESW-C8 ($190).
Whole new set of WAF Energy for $710 less what I get for reselling the micro-center.
pghflyer is offline
post #14 of 14 Old 12-02-2012, 08:33 PM
tongr's Avatar
I've owned the RC micro system (along with a Def Tech Suercube 2) setup for about a year now. I was originally pleased with them but, after a while, the system started to sound "thin". I ultimately decided that the problem was the center channel speaker as this speaker is responsible for so much when it comes to home theater, most especially dialogue. I didn't want to spend a lot on a fix because we may be moving soon and I don't know what the new house will require. I ended up buying a CC5 just to try. Hooked it up, re-calibrated and it sounds great- much more capable than the micro center and I have not noticed any problems matching with the other speakers.
tongr is offline
Reply Speakers
