Any reason to upgrade 7 year old Klipsch home theater speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 02-25-2011, 04:41 PM - Thread Starter
AndroidAZ's Avatar
I bought the following home theater speaker set in 2004 - all Klipsch brand:
-KSW-12 12" 440 Watt subwoofer
-SC-1 Dual 5.25" 2 way center channel speaker
-SF-3 Floor speakers (2)
-SS-1 5.25" 2 way surround sound speakers (2 are set up, have 2 in boxes still waiting to be deployed as 7.1 instead of the 5.1 I have right now).
I love the speakers and they sound great. Is there any reason to consider upgrading to newer, modern speakers (Klipsch or any other brand) ???
The reason I ask is because I just replaced my Panasonic 32" Tube TV with a 55" Samsung LED LCD, and am evaluating if I need to upgrade the rest of the home theater set up, including AV receiver or the speakers.
I have not kept up with speaker trends or modern speaker technology so please educate me.
Thanks!!
AndroidAZ is offline
post #2 of 22 Old 02-25-2011, 04:49 PM
stevensctt's Avatar
Quoted: 23 Post(s)
Liked: 37
Speakers are fine, since you love the speakers no reason to change/upgrade. You may want to consider an upgrade for your receiver depending on the type connectivity/integration (HDMI, etc.) you will use. If your OK with the connectivity of your current receiver, no need to upgrade.
stevensctt is offline
post #3 of 22 Old 02-25-2011, 04:51 PM - Thread Starter
AndroidAZ's Avatar
Thanks! Have the speaker technology changed lots in the last 7 years? Or do most people buy speakers and then stay with them for decades?
I will probably get a new receiver. The receiver does not have HDMI input/output, so it will need to be upgraded. The trick will be finding a new receiver that will sound good with my Klipsch speakers. I am not sure if that should be easy or hard to do...
post #4 of 22 Old 02-25-2011, 05:05 PM
tdogroeder's Avatar
Quoted: 41 Post(s)
Liked: 81
Ditto, if you love what you already have then why spend money on finding a greater love.
John 14:6 & John 3:16
Yamaha RXV765 & Emotiva LPA-1
Ascend Sierra-2s(LCR), RSS300, Polk R15, SVS PB12 plus
Panasonic S65, Sony S5100, PS4, PS3, XBOX 360
tdogroeder is offline
post #5 of 22 Old 02-25-2011, 05:20 PM
Zen Traveler's Avatar
Quoted: 527 Post(s)
Liked: 530
I would probably still have my original Synergy Home Theater if I didn't find these Forums. That was/is a nice package and run from this place as soon as you get the urge to upgrade something you already love. My 2 cents. ;-)
Zen Traveler is offline
post #6 of 22 Old 02-25-2011, 05:35 PM
stevensctt's Avatar
Quoted: 23 Post(s)
Liked: 37
There may be subtle refinements, but no significant changes in the last 7 years and more. Many speakers do last for decades.
post #7 of 22 Old 02-25-2011, 06:44 PM
WhiteSoxFan's Avatar
I still own the Paradigm 9se pair that I bought in 1991. Like fine wine, they just continue to get better with age....
WhiteSoxFan is offline
post #8 of 22 Old 02-25-2011, 10:09 PM - Thread Starter
AndroidAZ's Avatar
Thanks for the information and saving me some money! I can spend my money on a new receiver and feel good about that.
post #9 of 22 Old 02-26-2011, 02:40 AM
Florida_Gator's Avatar
Are you familiar with DSLR cameras? Speakers are lenses; receivers are the camera body...
Florida_Gator
Florida_Gator is offline
post #10 of 22 Old 02-26-2011, 05:55 AM
Balbolito's Avatar
Quoted: 24 Post(s)
Liked: 30
if you like how they sound just stick to them, most likely u would need a new receiver.
Balbolito is offline
post #11 of 22 Old 02-26-2011, 05:56 AM
coytee's Avatar
Quoted: 158 Post(s)
Liked: 285
As the others have said, there's no reason to upgrade if you're happy with what you have.
I will point out though that if you have the space and budget, if you give a listen to the larger offerings from Klipsch you might find yourself wanting to upgrade. It tends to get better as they (Klipsch) get bigger. You're in a win/win situation.
coytee is offline
post #12 of 22 Old 02-26-2011, 06:28 AM
Grandarf's Avatar
The reason is that there are better speakers out there... There also was better speakers seven years ago too, but I guess you already knew that... Other reasons, you're a compulsive buyer, money is burning a hole through your pocket, you want to keep the economy rolling and help the BestBuy owner/stock holders buy a fourth car, etc etc... There's countless of reasons to upgrade!
What makes you say they're not modern? Are the speakers you'd buy today be significantly different? If so, how?
Grandarf is offline
post #13 of 22 Old 02-26-2011, 06:38 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
My front three Klipsch are from the 1970s.
Don't worry about receivers having a sound signature. Buy the one with the features you want.
The next thing to upgrade after the receiver could be the subwoofer, although its 26 Hz extension isn't bad.
psgcdn is offline
post #14 of 22 Old 02-26-2011, 06:44 AM
tony123's Avatar
Liked: 38
You could upgrade to an older Klipsch! Sorry, couldn't resist. Age is just about irrelevent in the world of speakers. Look at the long manufacturing run of many in the Heritage line. They've been built and sold for half a century and still are at the top of the Klipsch model line. That speaks for itself.
The short and direct response to your question is that you are happy with what you have. That's the end goal. Just don't listen to anything better, it gets expensive. But fun!
The "Twinseltown" Theater
Construction Thread
tony123 is offline
post #15 of 22 Old 02-26-2011, 11:27 AM
Emig5m's Avatar
Capacitors age (crossover filters) and my father who repairs speakers for people I don't know how many he's took apart and the ferro fluid has completely dried or crusted up. Albeit, seven years isn't that much, the speakers where the ferro fluid was dried and crossovers burnt where fifteen years old and where hammered on, but still... things do age over time....
Emig5m is offline
post #16 of 22 Old 02-26-2011, 12:43 PM
Raymond Leggs's Avatar
My favorite speakers are 30 years old and that was the "upgrade"
Raymond Leggs is offline
post #17 of 22 Old 02-26-2011, 01:06 PM
tony123's Avatar
Liked: 38
Same here Raymond!
Emig, the capacitors are about a $30 fix per speaker. If that. I've got to do mine still. Okay, you've motivated me.
Construction Thread
tony123 is offline
post #18 of 22 Old 02-26-2011, 04:15 PM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Yeah, all new caps here too (actually new crossovers in the mains, new caps in the center).
psgcdn is offline
post #19 of 22 Old 07-20-2014, 08:16 AM
bobme23's Avatar
15 year old Klipsch RF-3, RC-3, RS-3 and KSW-15 Speakers
I own Klipsch RF-3, RC-3, RS-3 and KSW-15 Speakers. These were driven by Marantz SR-8000 before and now by Pioneer Elite SC-05 A/V Receiver. I am considering an upgrade and while searching for affect of age on Klipsch's I came across this thread. Someone told me that the surround of the speaker loses it's effectiveness. Is that correct? How do I figure it out? My speaks don't buzz or give out any unintended noise. If there is a recommend age of servicing/repairing the speaker? Anyone else holding on to R*-3 speakers for longer than 15 years?
bobme23 is offline
post #20 of 22 Old 07-20-2014, 08:44 AM
kjfalls's Avatar
Location: Dennison IL, just across the state line from Terre
Quoted: 204 Post(s)
Liked: 65
I still have my Kg4, KV3, RS-3 system I bought mid 80s. I've upgraded the Kg4s with Crites titanium tweeters which made a substantial improvement. I plan to upgrade the xovers with Crites soon.
I like the sound of the older Klipsch' much better than the new. I don't plan to replace them. I have an expensive Legacy system (over 10x the cost) which have a more robust sound, but still love the Klipsch system as well. I also have several 5.1 systems with bookshelf type speakers I purchased used to experiment with (Scandyna minipods, B&W LM1/VM1, Emotiva ERM-1/ERD, PSB Intro, NHT New Wave). All have their favorable characteristics. However the Klipsch and Legacy systems I'll never sell.
kjfalls is offline
post #21 of 22 Old 07-20-2014, 09:07 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
By surrounds, you mean the cone suspension. Those made of foam rot out. Not an issue with the RF-3 I think. My older Klipsch have paper and last decades.
psgcdn is offline
post #22 of 22 Old 07-20-2014, 09:17 AM
bobme23's Avatar
Yes psgcdn, I mean the cone suspension. How about the cone suspension for RS3 and RC3?
bobme23 is offline
Reply Speakers
