The Official Procella Audio Speakers Owners thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 63Likes
post #271 of 467 Old 03-15-2015, 11:44 PM
lovingdvd's Avatar
Quoted: 2402 Post(s)
Liked: 403
I'm building a room essentially 18' x 28' x 7.75'. Details here:
What do you guys think about the suitability of the P18 sub is for this room? I am thinking about one or two of them (if two is needed?) behind the AT screen. How would this sub compare to using the HSU VTF-15H (multiples) which are rated down to 16 dB? What other high power subs should I consider?
Also how does the Procella LCRs sound/compare to the Triad Gold Monitors or LCRs?
lovingdvd is online now
post #272 of 467 Old 03-16-2015, 12:53 AM - Thread Starter
gamelover360's Avatar
I have a P15 in a 535 sq. ft room and it does excellent. Zero complaints about bass. A P18 is called for in a room with my volume for ideal outcome, but since I really only care about the MLP for sound quality the P 15 works. Most importantly A P18 didn't fit in my budget. . Have you considered 2 passive P 15's? They are equal to one P 18 in terms of output but will give more even bass response that one P 18. That would free up money to have better LCR and power it all (subs and speakers) with the procella amp.
I have the P 610 LCR, and cannot speak high enough about them. Have never heard the Triad but their reputation is very good.
gamelover360 is offline
post #273 of 467 Old 03-16-2015, 06:01 PM
Gerben Van Duyl's Avatar
Quoted: 18 Post(s)
Liked: 35
Hi, for your room size, the P18 would only be required if you wish to reach the very lowest of bass frequencies (-3dB @ 18Hz from 133dB@50Hz, so 130dB@18Hz!!), all the way down to below 10Hz! The P18 can play these low frequencies at SPL as required for much larger rooms than yours, so you will be over-specced from an SPL point of view. Based only on your room size, I would begin with 1 x P18-FP placed below or behind the screen, powered using our new rack-mount amp, the DA-06 (2 x 1200W) and plan to add a few P10-FP as balancing subs, distributed throughout the room, if required. But before we continue, we need to know what materials your room is made of: timber bats/sheet?, brick?, concrete?
We don't comment on other products. The Procella loudspeakers all use studio-quality, Italian-made compression drivers (HF), mounted on our proprietary wave guides. This gives them much greater SPL than dome-tweetered loudspeakers, with much lower distortion, greater clarity and much better dispersion characteristics. All our loudspeakers are designed to be timbre matched, allowing you to use P28(P860), P8(15), P6(10) and P5 in any combination (LCR, surrounds) as required for your room, whilst maintaining our Identical Voices(TM) principle throughout.
Hope this helps!
Gerben Van Duyl is offline
post #274 of 467 Old 03-21-2015, 06:43 PM
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 53
got my p8s in the baffle wall and the p6v in my columns, cant wait to see the p6iw for my atmos setup.
My theater build : Roll-In Reels Cinema (7.2.4 atmos theater)
lpnaz480 is offline
post #275 of 467 Old 03-22-2015, 12:34 AM - Thread Starter
Looks beautiful! You must be excited.
post #276 of 467 Old 03-22-2015, 09:55 AM
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 53
very, cant wait. the room is almost completed, though the p6iw wont be here until early may
lpnaz480 is offline
post #277 of 467 Old 04-18-2015, 08:48 AM
Tin_Can's Avatar
Quoted: 271 Post(s)
Liked: 62
So, how low does the p15 go? I was told the p18 would be needed to dig really deep, but the p15 must at least be noticeable around 10hz, right? This is for a 2600 foot cubed room.
Plus, my other speakers are domes, so I probably can't quite hit reference level, anyway. I'm just worried that the extra headroom of the p18 would never be realized.
Tin_Can is offline
post #278 of 467 Old 04-18-2015, 02:12 PM - Thread Starter
You can never have too much headroom. In all seriousness the P15 does awesome in my room, which is a big room. With the money you save by going with a P15 use it towards the ultimate Procella setup!
Dolby Atmos 11.4.6. Oh, how I wish I would happen to be in Amsterdam for a front row seat for this demo. All I can picture is the iconic Pioneer advertisement.
https://iconicphotos.files.wordpress...maninchair.jpg
post #279 of 467 Old 04-18-2015, 03:22 PM
lovingdvd's Avatar
Liked: 403
Hey guys - I am very interested in the Procella speakers and as such spent a while going through this thread head to toe - great information in here. Below are some questions and thoughts on things I found as I went through the thread.
Does anyone have an updated list of MSRP for the Procella loudspeakers and subs? There were a few posts listing them throughout this thread, but the numbers changed in each and those were from a few years ago, so looking for updated info.
Little update after living with the P610 for a couple months: What an amazing upgrade going from the P6 to the P610 has been in my opinion. The P610 is an extremely authoritative and robust speaker that brings a whole new weight and depth to the entire front soundstage. It is truly awesome to have those extra sources of bass across the front. Highly recommended!
The more time I spend with them with a variety of material the more impressed I become.
Originally Posted by Peter M View Post
Couldn't agree more !
Due to a DSP failure I was briefly unable to bi-amp my 610's and was left with only P6's up front. It still sounded good but the P610 is in another league !!
Cheers,
Great to here and glad you loved the upgrade. In my case I am wondering if I would get anything from the P610 that I wouldn't get from the P6. My room is 17W X 30L x 7.75H. My front row is 12.5 ft. I do NOT have any requirement (or any interest really) to play at reference volume. In fact I would never do it - hurts my ears. With the fronts normally xo at 80 Hz, what would be the advantage, if any, of using a P610 instead of a P6 behind my AT screen?
Originally Posted by KNKKNK View Post
...I am very interested in hearing others opinions for using a full range speaker in this scenerio...
[quote=TMcG;24148985]Quote:Originally Posted by KNKKNK
Did you eventually get the P6iw? How do you like them?
For my setup I am thinking of using P6 for the front 3 channels, P5's for the rest of the 7.1 system and Wides, and two P15 subs, possibly 7 P6iw for Atmos ceiling speakers (two top front, two top middle, one VOG as I am planning ahead for DTS future needs, and two top rears), along with some Procella balancing subs or other such (shallower) subs. However I am a little concerned that the P5's are only rated down to 90 Hz. Since my subs xo will be 80, I wonder if this will leave a big of a "hole" near the xo by using these speakers instead of P6's which go to 70 Hz. Certainly if there's little to no difference in the Wides and surrounds in the P5 vs P6 I'd like to go with the P5 as they are half the cost and we are talking about 6 speakers so this difference adds up real quick!
post #280 of 467 Old 04-18-2015, 03:47 PM
lovingdvd's Avatar
Liked: 403
Sorry for the delay in responding - I missed your reply at the time, and only saw it after rereading this thread last night from top to bottom...
I think some mode simulations and desired smooth frequency response over two rows will wind up dictating at least two subwoofers on the front wall. In that case which sub would you recommend that I could use two of on the front wall (behind the screen wall, AT screen)? Seems like that would provide perhaps smoother FR in the room compared to say a P18?
Hope this helps!
Thanks. In my case, I do not need reference levels, so the advantage of being able to play super clean at very loud volumes is a bit lost on me. I usually listen at say -20 dB to -15 dB on the MV. What I do want, however, is super clean and clear sound that is very well balanced. I love the fact that the Procella line shares the same voice and that the P6iw *appears* to be a good choice for 3D audio ceiling speakers, which is more than I can say compared to how other manufacturers are behind in this area.
My main concern at this point about the Procella speakers is that I really cannot imagine what a horn-based system like this sounds like. I've always had soft-dome tweeters. I have very sensitive ears (in a bad way). Loud noises, like a sudden hard clap of the hands, will make me reach for my ears to cover them quite quickly. So if horn-based speakers tend to be a bit more shrill or sharp than the types of speakers I've been used to having, I wonder if that sonic signature would appeal to me. That said I have no idea if the Procella even sound like that - I just have this preconceived notion that horn speakers may be like this - and that notion is likely wrong. But that's what is weighing on my mind. With no great way to audition the speakers, short of getting on a long plane ride, I'm not sure how to proceed.
post #281 of 467 Old 04-18-2015, 04:43 PM
Tin_Can's Avatar
Quoted: 271 Post(s)
Liked: 62
Thanks. The entire headroom thing is what's hanging me up right now. So far, everyone has said the p15 will be adequate, but then they will always follow it with a "but". It's just difficult making a decision without hearing it.
I'm with ya on procella all around, but it's tough when building an entire room from scratch. Adds up fast. I've contemplated doing procella for the front three, but matching the dome surrounds might not be the best idea.
Tin_Can is offline
post #282 of 467 Old 04-18-2015, 11:04 PM - Thread Starter
I think the idea with one P18 to start and balancing subs added as needed is that the P18 will power the room and dig deep......then you only add balancing if/as necessary. But if you want 2 subs up front then get 2 P15's......as they are equa to one P18.
I listen about -15 MV and the thing I like about the P610 is that I do not need buttkickers in the room.
post #283 of 467 Old 04-18-2015, 11:08 PM - Thread Starter
See if P6 up front, P5 for surround, and a P15 would fit your budget. I am certain you would be VERY HAPPY.
post #284 of 467 Old 04-18-2015, 11:26 PM
lovingdvd's Avatar
Liked: 403
Interesting. Is it possible to mount the P610 so that the top section (essentially the P6 part) is under the larger part? If I did go with the P610 I'd want to do that because it would better align the tweeter with the ear level of the first row (the only row I really care about), and because it would give about an extra 33% of separation between the front mains that the heights I am thinking of putting at the top of the screen (for future DTS / 3D audio compatibility).
Well, it sounds like the P610's can be separated into two pieces, so that means technically speaking they could be mounted reversed like this. So the real question is whether it would sound perfectly find to do so? Seems like it - but who knows, maybe the speaker is designed to be oriented in this way and messing with it could cause things to sound weird?
post #285 of 467 Old 04-18-2015, 11:52 PM - Thread Starter
I don't see why you couldn't have the P6 module below the P10. But I don't know for sure.
post #286 of 467 Old 04-18-2015, 11:54 PM - Thread Starter
I updated the first post in this thread. I fixed the links as Procella Audio now has a brand-new beautiful website. Well, new to me anyway! I also added a link so you can follow them on Twitter.
Gerben Van Duyl likes this.
post #287 of 467 Old 04-19-2015, 08:54 AM
Tin_Can's Avatar
Quoted: 271 Post(s)
Liked: 62
The bigger issue is actually Atmos. My ceiling isn't high enough to properly use direct radiators in the ceiling, necessitating the use of another brand of reflecting speakers.
Tin_Can is offline
post #288 of 467 Old 04-19-2015, 09:17 AM
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 53
they havent arrived yet. i believe they'll be shipping towards the end of april.
lpnaz480 is offline
post #289 of 467 Old 04-19-2015, 11:16 PM
Quoted: 18 Post(s)
Liked: 35
Interesting, It sounds like you are in fact sensitive to distortion, as caused when dome tweeter systems reach their max SPL and start to distort, as caused by sudden sharp peaks. The good news is that the Procella speakers will not have such distortion as they are capable of much greater dynamic range ("SPL") without distorting. So you do not need to play at very loud volumes to get the benefits of a controlled dispersion system (we use wave guides, not horns!) with high dynamic range drivers. In fact, you could play at lower volume levels, and still get the dynamics coming through correctly and as such enjoy your listening experience more.
post #290 of 467 Old 04-19-2015, 11:55 PM
Quoted: 18 Post(s)
Liked: 35
Yes, you can mount the P6 below the P10SI, as long as you keep them close together, as to not create a 'gap' between them in the mid-bass range. That would work fine from a loudspeaker perspective.
However, the movie you are watching is mixed according to industry standards, such as described in THX standards, in which the Acoustic Centre (A/C) of the speaker is placed at 5/8 of the Height of the Image. This is where mouths are in close-ups, where most the audio action takes place in the overall image. As per our Handbook, the A/C of the P6 is between the wave guide and the woofer, and that point should be at that 5/8 of image height, to comply with these cinema industry standards. Lowering this A/C for the screen speakers is not a good idea. Neither is lowering the surrounds below head level.
I personally believe that the best way to place 3D audio loudspeakers for all 3D formats is as follows, provided your processor can do loudspeaker mapping:
The loudspeaker mapping will allow your processor to create very believable phantom images anywhere(!) between these loudspeaker positions, including in the Auro positions.
post #291 of 467 Old 05-17-2015, 11:43 AM
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 53
was hoping to have the p6iw by end of april - mid may, looks like the backorder is now 6 weeks.
in the meantime i have thoroughly enjoyed the p8s and p6s for the 7.1!
lpnaz480 is offline
post #292 of 467 Old 05-17-2015, 02:41 PM - Thread Starter
So happy to have my HT back up and running! I had a nightmare 5 month ordeal getting my a Sherbourne amplifier fixed. I will say on the positive side of things absence makes the heart grow fonder, and I have never been happier to watch movies in my beloved HT. Another positive note is that when I recalibrated I stumbled upon a great result......the best calibration yet. Thor the Dark World was a truly AWESOME experience. I think it should be illegal to watch Thor movies on anything other than a dedicated HT. His hammer is simply not the same without the sound of his hammer! Also watched the amazing Spiderman with my two boys. Probably the most enjoyable movie I have ever watched up there(mostly just to see them wide eyed for 2 hours and having them by my side for the first time through a whole superhero movie). They don't know how spoiled they are!
Still amazed at how the P15 does such an incredible job in a 50 square meter room!
post #293 of 467 Old 06-26-2015, 09:52 AM
turls's Avatar
Quoted: 466 Post(s)
Liked: 197
I'm looking at adding a sub to my setup. I have a P18 in the front, and small Triad balancing subs on the side.
I want to connect the additional sub in the front. The P18 is offset to the right, and I have room for another P18 or P15 to the left of the center line of the room.
Is there any reason I should rule out using a P15 for the additional sub? These are behind a acoustically transparent false wall, so I'm not concerned about looks.
Thanks for any input.
Matt
UMR on HDR vs 4K: The benefit of greater saturation and luminance capability is...not very evident in all images unlike more pixels which can be seen in every scene.
turls is offline
post #294 of 467 Old 07-06-2015, 11:55 AM
turls's Avatar
Quoted: 466 Post(s)
Liked: 197
Anyone have any input on this? Mix P18 and P15 within a few feet of each other? Again my main intention would be to balance but will I cause more problems than it is worth?
Matt
turls is offline
post #295 of 467 Old 07-06-2015, 12:39 PM
Tin_Can's Avatar
Quoted: 271 Post(s)
Liked: 62
I think three subs can actually cause problems, so you might need to add another triad as well as another Procella. I'm sure a talented calibrator could make a p18 and p15 play nice together, along with two Triads.
My advice would be to talk to whoever is going to do the calibration.
Tin_Can is offline
post #296 of 467 Old 07-06-2015, 12:51 PM
turls's Avatar
Quoted: 466 Post(s)
Liked: 197
I've actually got 4 Triads. All in the columns to the left and right of the first and second row.
Matt
turls is offline
post #297 of 467 Old 07-06-2015, 02:15 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 942
Maybe........maybe not. I know of a highly regarded AVS member who uses three Seaton Submersives........two upfront and one 1/3 side wall. I've seen his FR graphs........stellar!
I still have a hard time with balancing subs smoothing FR from 5-80 Hz..................20-80 Hz yeah, but not down to ULF's. Guess software comes in handy but is not fool proof with predictions.
doublewing11 is offline
post #298 of 467 Old 07-06-2015, 02:28 PM
Tin_Can's Avatar
Quoted: 271 Post(s)
Liked: 62
I think we agree, hence the "can". I'm sure anything is possible but I bet it's room dependant.
Personally, I'm not too worried about subsonic response. Well, at least my butt cheeks aren't
Tin_Can is offline
post #299 of 467 Old 07-06-2015, 07:07 PM
Quoted: 229 Post(s)
Liked: 942
Once you experienced 5 Hz at 115 db's.......there's no going back!!!
post #300 of 467 Old 07-06-2015, 07:46 PM
Tin_Can's Avatar
Quoted: 271 Post(s)
Liked: 62
No, I mean I don't care if stuff that low is flat. My butt probably can't tell the difference between 115 db and 95 db at 10 hz.
Tin_Can is offline
Reply Speakers
Procella P6
