The Official Procella Audio Speakers Owners thread - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 25Likes
post #331 of 352 Old 10-30-2015, 02:37 AM
jolt72's Avatar
Liked: 3
From Procellas Facebook page.
"First look at the new P28 (2016 model), with it's smaller cabinet, better finish quality. Same audio quality, which is basically double the power of the P8! Unleash your inner beast with the new P28!"
jolt72 is offline
post #332 of 352 Old 11-02-2015, 08:24 AM
jolt72's Avatar
Liked: 3
This New version of Procella P28 is made by outsourcing some of Procellas production to SEAS in Norway.
http://www.seas.no/index.php?option=...ews&Itemid=194
Maybe all drivers in Procella speakers will be SEAS drivers soon?
jolt72 is offline
post #333 of 352 Old 11-02-2015, 08:24 AM
jolt72's Avatar
Liked: 3
EDIT.. Dubble post
jolt72 is offline
post #334 of 352 Old 11-02-2015, 12:07 PM
splotten's Avatar
Quoted: 217 Post(s)
Liked: 91
At least some of the models have SICA compression drivers. You can see which model if you look closely at some of the P6internal pics found on google. To my knowledge SEAS does not manufacture compression drivers.
splotten is online now
post #335 of 352 Old 11-02-2015, 12:42 PM
TMcG's Avatar
Quoted: 878 Post(s)
Liked: 679
Will be posting a classified very soon, but I will be selling on my two brand new in the box P10Si balancing subwoofers. I have 6 other larger subs going into my room and these balancing subs are no longer needed. PM if interested.
TMcG is offline
post #336 of 352 Old 11-03-2015, 03:49 AM
jolt72's Avatar
Liked: 3
Yes, the compression drivers has been SICA for som time now. . .But if SEAS is building the new P28 maybe SEAS has started too build a compression driver after Procellas spec.
jolt72 is offline
post #337 of 352 Old 11-11-2015, 04:12 AM
jolt72's Avatar
Liked: 3
New install with the not-so-tiny Procella P860 as LCR . . . .nice
https://www.facebook.com/procellaaudio/?fref=ts
jolt72 is offline
post #338 of 352 Old 11-14-2015, 09:02 AM
jolt72's Avatar
Liked: 3
Just had Pär Hörnell from TIWIA.se here to calibrate my new P610/DA-05 speakers/amps
I live in an apartment and the room is just 20m2. . but the P610/P15 still kicks in this small room
jolt72 is offline
post #339 of 352 Old 11-14-2015, 09:02 AM
jolt72's Avatar
Liked: 3
EDIT..dubble post
jolt72 is offline
post #340 of 352 Old 11-14-2015, 09:32 PM
lovingdvd's Avatar
Quoted: 1344 Post(s)
Liked: 241
How do you like the sound? That is some setup for an apartment!
Any idea why the dB starts to drop around 1.5 kHz? Was this an off-axis measurement perhaps? Just curious.
lovingdvd is offline
post #341 of 352 Old 11-15-2015, 02:30 AM
jolt72's Avatar
Liked: 3
It sounds absolutely great . . The P610 driven by DA-05 is a killer combo
The measurement is done with four mics at different hight and distance simultaneously.
The slight drop above 1,5KHz i belive is the target curve Pär was aming for. . that curve sounded best in my room
jolt72 is offline
post #342 of 352 Old 11-22-2015, 10:45 AM
jolt72's Avatar
Liked: 3
Got confirmation that Procella P28 has a SEAS mid driver, so does P6 and later models of P8
The P28, P6 and soon P6V are är assembled by SEAS in Norway
jolt72 is offline
post #343 of 352 Old 12-22-2015, 10:02 AM
Claesson's Avatar
Installed a Procella DA-06 yesterday, which I connected to my P15-FP. Earlier I powered my P15-FP with the DA-05. I loaded the "wall" preset for the P15-FP in the DA-06 and when I set the levels I happened to see how "limiter" is set in my DA-06, it has exactly the same values ​​as the DA-05 has.
V pk = 69
Ohm = 4
Watts = 597
dBu = 36
According to the specs for the DA-06, I think it should be:
V pk = 99
Ohm = 4
Watts = 1197
dBu = 39
I´ve also tried to load a presets for P18-FP, thought that it ought to have the right values ​​if it is so that the limiter is to protect the elements of the P15-FP. But even if I load a P18 preset, I have the same values ​​of the limiter.
Top of it all I somehow overwrote the preset for P18 Baffle
May as well add that the software doed not allow me to change any of this values.
Feels like someone did a misstake a Procella and loaded my DA-06 with DA-05 presets?
Sincerely
Claesson
Claesson is offline
post #344 of 352 Old 01-13-2016, 09:47 AM
jolt72's Avatar
Liked: 3
Press release from Procella about the new PRO line speakers and the 30.5.20 build i tallin
The C124 and C22 speakers:
" Procella C124 tri-amplified three-way speakers that use a high-frequency compression driver and an 8 inch midrange speaker mounted on proprietary waveguides. Low frequencies are handled by four 12 inch woofers in a ‘W’ configuration. The C22 overhead and surround speakers use the same high-frequency compression driver and waveguide with a 12 inch woofer. "
http://files.ctctcdn.com/82683fcb001...4942ea3457.pdf
jolt72 is offline
post #345 of 352 Old 02-04-2016, 08:36 AM
KNKKNK's Avatar
Quoted: 38 Post(s)
Liked: 101
Just for Fun
No particular reason for this post other than to "Spread the Love"
(I did smash the *@*% out of a finger getting one of the 18's into the baffle)
dormie1360, lpnaz480 and TMcG like this.
KNKKNK is offline
post #346 of 352 Old 02-07-2016, 03:41 AM
jolt72's Avatar
Liked: 3
If you are in Amsterdam don´t miss Procellas 11.4.11 demo att ISE 2016, listen to ATMOS, DTS:X and AURO 3D and Watch HDR content in the same system.
jolt72 is offline
post #347 of 352 Old 02-07-2016, 09:31 AM
jolt72's Avatar
Liked: 3
Teaser of a new speaker from Procellas P5 series..up to the right on the Picture
jolt72 is offline
post #348 of 352 Old 02-09-2016, 04:06 AM
jolt72's Avatar
Liked: 3
Closeup of the new Procella P5 Slimline
jolt72 is offline
post #349 of 352 Old 02-09-2016, 01:35 PM
tangcoma's Avatar
Can I have the dimensions pls! Thx
tangcoma is online now
post #350 of 352 Old 02-09-2016, 11:36 PM
jolt72's Avatar
Liked: 3
I only know the depth and it´s 10,5cm . . i don´t know the exakt hight and with, but looking att the Pictures i would guess it´s as wide as a normal P5, 19cm and as high as a P6V, 47cm
jolt72 is offline
post #351 of 352 Old Yesterday, 11:22 AM
jedi1982's Avatar
Hey all,
I've been an Aperion owner for the past 8 years. I started out with Hybrid 5T 5.1 and upgraded 2 years ago to the Verus Grand system and use dual Rythmik FV15HP subs. I have been very pleased with the system even with no external amplifier and use a Marantz SR-7008 to power it.
My question is, honestly, what would the difference in sound quality be going from the Verus Grands to something like Procella p815? I realize posting this in Procella forum might warrant a little bias feedback but I am wanting honesty. My current home theater in the basement is about 3500 cu ft with the left side completely open to the other side of the basement (another 3000 cu ft area). Because it's in the basement and is not a dedicated home theater room, I can never turn up the system very loud because of rattling and vibrations throughout the rest of the house. In a new house my wife and I are considering building, if I were to have a company professionally construct a home cinema room keeping it around 3500 cu ft and treat it acoustically, (and this might be a really dumb question) how would the Verus Grands paired with an external amp like Emotiva XPA3 perform vs a speaker like Procella p815 for LCR?
Another note, while I currently own only a 5.2, in the new home cinema I would be adding additional speakers essentially making 11.2.4 or 7.2.4.
jedi1982 is online now
post #352 of 352 Old Today, 08:52 AM
tangcoma's Avatar
Thx a lot !
Reply Speakers
Procella P6
