need help on speakers for large room, 4-5k budget - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-08-2011, 11:08 PM - Thread Starter
macmd's Avatar
complete newbie who currently has been using logitech 5.1 computer speakers with their included subwoofer for large great room who finally has the budget to upgrade substantially to better system
great room is 20x25ft with 16 ft high ceilings open to the kitchen in the back and open to one side to the foyer
primary use is home theater, watching movies and TV. being able to hear dialogue is key although my wife and I also like to listen to music.
my budget is 4-5k for the Front left/front right/center/and rears (which would need to be ceiling speakers). the fronts and centers cannot be floor standing because of the way the room is set up and would need to be bookshelfs.
if you could be specific in your recommendations since I am completely new to this with:
1)brand
2)model
3)estimated price
*also can anybody suggest other than this forum a magazine or website for newbies like me where I can do research for speaker/receiver/sub reviews*
macmd is offline
post #2 of 8 Old 03-08-2011, 11:16 PM
khellandros66's Avatar
Magazines hardly give bad ratings, most ofv them are as bad as consumer report.
$4-5k I would look at a combination of
Onkyo TX-NR3008
Paradim Monitor 11, cc390, and adp's surrounds dsp3400
Also check out hsu vtf-15
SVS MT Series and subs.
You can get em used the Definitive BP7002 towers and CLR3000.
Bobby
khellandros66 is offline
post #3 of 8 Old 03-10-2011, 06:08 AM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
JTR Triple 8s
http://jtrspeakers.com/home-audio/triple-8ht/
There are a few threads in this forum that discuss them.
For rear surrounds, individuals recommend ceiling speakers from SpeakerCraft and Triad.
At some point, you will consider a subwoofer (or two)
There are five very good (~$1000) subwoofers in
http://www.avsforum.com/avs-vb/showthread.php?t=1313176
If you need to move down in price on the speakers, the Pro-10 and Sho-10 speakers (~$1200 for L/C/R) from Chase Home Theater are considered very good.
http://www.avsforum.com/avs-vb/showthread.php?t=1264258
wwinkler is offline
post #4 of 8 Old 03-10-2011, 06:58 AM
jaball77's Avatar
I'd second JTR speakers. That's a huge room to fill so high efficiency speakers would be helpful. I'd recommend the Single 8 HT though. It fits your "bookshelf" requirement, it's easier to drive (8 ohm instead of 4 ohm), and it's cheaper. JTR also makes a wall mounted surround speaker called the Slanted 8.
jaball77 is offline
post #5 of 8 Old 03-10-2011, 03:15 PM
Gooddoc's Avatar
Quoted: 2672 Post(s)
Liked: 1845
Good choice, but the JTR's require subs, which puts them significantly out of budget for the OP. As mentioned, a 5.2 CHT system is within budget and is an excellent choice for that size room.
Gooddoc is offline
post #6 of 8 Old 03-10-2011, 05:03 PM
audio0947's Avatar
Quoted: 27 Post(s)
Liked: 47
Actually three S8's across the front from JTR would only be 2.4k which would leave him 2.6k for in-ceiling rears (cht system dont have) he specified and a sub or two. Maybe look at getting 2 Ed A7S-450 subs for 1.6k delivered and an in-ceiling product from Triad or Paradigm or Definitive Technology or... well you get the point.
Close your eyes and hear the truth!
audio0947 is offline
post #7 of 8 Old 03-10-2011, 05:38 PM
jaball77's Avatar
The original post said $4-5k for 5 speakers. I assumed the sub budget was separate. Even so... Five Single 8's is 4 grand, that leaves a grand for a sub.
jaball77 is offline
post #8 of 8 Old 03-11-2011, 02:02 AM
Gooddoc's Avatar
Liked: 1845
Oh, I thought the 8's were a grand a piece...sorry
Gooddoc is offline
Reply Speakers
