Official Chase Home Theater Owners Thread - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 170 Old 02-08-2012, 05:02 AM
eljaycanuck's Avatar
Quoted: 1351 Post(s)
Liked: 1964
Originally Posted by Eyleron View Post
To be fair, this doesn't mean they need to be EQ'd, necessarily, but for sure those speakers in your room needed to be EQ'd.
You're right, and I should have been more specific and said "So, IMO, these speakers do need some sort of EQ-ing to sound their best in my HT space."
But it's amazing how differently the SHOs react to my room than do my Paradigm Studio 60s. The S60s, with Audyssey switched off, sound fine. The SHOs, to put it politely, don't.
Anyway, that's neither here nor there. Whether or not they sound good un-EQ'd in my room or someone else's room isn't as important as the fact that, EQ's, they definitely sound very good...and perform very well!
eljaycanuck is offline
post #122 of 170 Old 05-07-2012, 12:01 AM
azula's Avatar
Quoted: 26 Post(s)
Hello CHT owners. what speaker stands are you guys using for the SHO-10's? Also, does it make a difference whether the center channel SHO-10 is placed vertically or horizontally?
azula is offline
post #123 of 170 Old 05-07-2012, 04:46 AM
laugsbach's Avatar
Quoted: 169 Post(s)
Liked: 223
DIY designed for placing my speakers behind an AT screen at ear height...
Just rotate the horn 90 degrees for horizontal placement...
laugsbach is offline
post #124 of 170 Old 05-07-2012, 07:25 AM
Liked: 1964
I had my SHO-10s sitting on 19" tall wood stands. The metal top plate was 6" x 6", but ideally (IMO) it should have been no smaller than 8" (w) x 6" (d).
post #125 of 170 Old 05-07-2012, 08:38 AM
Brad Horstkotte's Avatar
Liked: 73
I wonder if this is required anymore now that the waveguide pattern is 90x90 on the newer models? The waveguide looks different in the vertical and horizontal plane though, so probably good to do anyway.
Brad Horstkotte is offline
post #126 of 170 Old 05-07-2012, 08:58 AM
azula's Avatar
Quoted: 26 Post(s)
thanks for the info guys. is there any kind of noticeable difference placing the center vertically as opposed to horizontally?
Ejay, I have yet to unbox these puppies. I have to purchase one more before I get to play. lol. Thanks again man.
azula is offline
post #127 of 170 Old 05-07-2012, 09:20 AM
mechx's Avatar
Quoted: 41 Post(s)
Liked: 42
I have the newer version as a center horizontally and I did not rotate mine. Both the wife and I are sitting on either side 3-4 feet off axis and it sounds great. Best center I've ever had...FYI
mechx is offline
post #128 of 170 Old 05-07-2012, 09:20 AM
mechx's Avatar
Quoted: 41 Post(s)
Liked: 42
I have tried both ways and could not hear a difference...
mechx is offline
post #129 of 170 Old 05-07-2012, 10:00 AM
Liked: 1964
Eljay, I have yet to unbox these puppies. I have to purchase one more before I get to play. lol. Thanks again man.
Glad to do business with you! Now hurry up and get those speakers - and the rest of your HT - up and running so I can REALLY be jealous...
Kidding aside, I'm curious to read your thoughts on the speakers once you do finally get to give them a good (and broken-in) listen.
post #130 of 170 Old 05-07-2012, 02:33 PM
laugsbach's Avatar
Quoted: 169 Post(s)
Liked: 223
Good point Brad....I would guess not. I have the 60x90 waveguide and would rotate it.
post #131 of 170 Old 06-12-2012, 12:08 PM
colleycol's Avatar
Quoted: 24 Post(s)
Wonder if anyone can give some suggestions,
I will probably get (3) Sho-s up front for all 3 LCRs but I am a little confused on what surrounds.
I cant spend another 1200 bucks on 7.2 surrounds so I need something a little more cost effective. Maybe $600 bucks for (4)??
Any Klipsch/JBL or any other maker that would integrate?
_________________________________________________
JVC RS4810, Screen Excellence 4K 115 inch wide
Lumagen Radiance 2021
Onkyo 818, Emotiva Amp
B&W CT700 Series Speakers, (2) PowerSound Audio XS30s
HTPC running Emby, 12TB Server for storage
colleycol is offline
post #132 of 170 Old 06-12-2012, 01:47 PM
Liked: 73
I eventually went for 7x CHT speakers - but before I did, I was looking at Hsu bookshelves - http://www.hsuresearch.com/speakers.html - they run about $150 each, so right at your budget. They also have an in-wall of similar design.
post #133 of 170 Old 06-12-2012, 02:47 PM
hogues's Avatar
Quoted: 85 Post(s)
Liked: 62
I'm in the same situation. I'm considering bi/dipole for surround. I'm interested to hear what people say.
hogues is offline
post #134 of 170 Old 06-12-2012, 03:25 PM
azula's Avatar
Quoted: 26 Post(s)
I purchased the Polk Fxi A6's to pair with my 3 SHO's. They can be configured either bipole or dipole. I have yet to unbox them so I cannot comment on performance however, they got nothing but good reviews on the boards. Check out the "bipole/dipole" sticky thread in the speaker section if you get a chance. I should be unboxing everything by the end of the month and will definitely give my feedback.
azula is offline
post #135 of 170 Old 06-12-2012, 03:53 PM
JEFFREY GTS's Avatar
Hey guys. This might be the wrong place to ask or maybe I should just post a new thread but I have talked to Craig at CHT, the HSU people and the people that sell Bic Acoustech. It seems that all three of these speakers are similar. I really want to pull the trigger on the CHT SHO's but my only concern is placement of the center channel speaker. Even setting it horizontally, it still is pretty big, that will be okay for now but if I get a bigger TV later on it might ebnd up being a concern. I won't have room in my entertainment stand for the SHO. Are the HSU or Bic Acoustechs on par with the CHT stuff or is the CHT stuff that much better?
I'm your Huckleberry
JEFFREY GTS is offline
post #136 of 170 Old 06-13-2012, 05:40 AM
laugsbach's Avatar
Quoted: 169 Post(s)
Liked: 223
I have the A6 speakers along with 3 PRO 10 speakers and the Polk speakers are great for surround duty...smile.gif
post #137 of 170 Old 06-13-2012, 08:51 AM
azula's Avatar
Quoted: 26 Post(s)
definitely reassuring! did yours come with a wall mounting kit? i ordered but the sales rep didn't know if they were included or not and i haven't opened the box yet (i refuse to until i'm ready to use them, mental thing). tongue.gif
azula is offline
post #138 of 170 Old 06-13-2012, 09:55 AM
slippery44's Avatar
Quoted: 37 Post(s)
Liked: 30
Hey Jeff I ended up getting a TV riser for my entertainment stand. Sat the TV on that, and the Sho-10 in front of it, if I have time I'll snap a picture of it and post but that worked out well for me.
I used this one, because my stand had legs that matched, wored out well for me, have a 59 inch plasma sitting on it.
http://www.amazon.com/Convenience-Concepts-Designs-2-Go-2-Tier-Swivel/dp/B000W9TVJ0/ref=sr_1_3?ie=UTF8&qid=1339606414&sr=8-3&keywords=tv+riser
slippery44 is offline
post #139 of 170 Old 06-13-2012, 11:27 AM
laugsbach's Avatar
Quoted: 169 Post(s)
Liked: 223
Hi azula, Yes, my A6 speakers came with a simple mount for mounting on your wall...
post #140 of 170 Old 07-03-2012, 05:59 PM
dannylsgr8's Avatar
i was wondering what is the thinking on surround speakers. monopole , or dipole/bipole ? i have a 7.1 system. i have dipole/bipole sides and monopole rear speakers . i want to upgrade the rear speakers . the side speakers could go to the rear ,to be the 7.1 ones, and the side 5.1 ones, should they be monopole or dipole/bipole ? i was thinking of kef Q300c for side 5.1. i am using pioneer elite sc37.
dannylsgr8 is offline
post #141 of 170 Old 07-03-2012, 06:05 PM
Carnut12's Avatar
I would say go with 5 for now and add 2 more when you can. I have 5 SHO-10's and it is Outstanding. Talk to Craig, they are coming out with a smaller speaker that might work also.
Carnut12 is offline
post #142 of 170 Old 07-03-2012, 06:07 PM
Carnut12's Avatar
I am not an expert by any means, but absolutely everything I have researched told me to do everything you can to have all your speakers match, that is why I bought the same exact rears, fronts, and center.
Carnut12 is offline
post #143 of 170 Old 07-03-2012, 08:07 PM
beezar's Avatar
Are you able to post a pic of your setup by chance? I had the same question about the size of the SHO-10 as a center, and your solution seems like it might work.
beezar is offline
post #144 of 170 Old 07-04-2012, 07:40 AM
hogues's Avatar
Quoted: 85 Post(s)
Liked: 62
My understanding is that it's imperative for the front, but less so for the rears. The sho-10's are probably too big for rears in my room so I was thinking of adding the Mirage OMD-5's. People in the surround thread seem to love them.
hogues is offline
post #145 of 170 Old 07-05-2012, 10:15 AM
Carnut12's Avatar
I guess that would make sense, the sound coming out of them is minimal compared to the other speakers. With that said if I end up going with a 7.2 I am going to add 2 more SHO-10's. Maybe next year, we will see.
Carnut12 is offline
post #146 of 170 Old 07-05-2012, 10:13 PM
Eyleron's Avatar
Quoted: 267 Post(s)
Liked: 168
...CHT, the HSU people and the people that sell Bic Acoustech. It seems that all three of these speakers are similar. I really want to pull the trigger on the CHT SHO's... Are the HSU or Bic Acoustechs on par with the CHT stuff or is the CHT stuff that much better?
The Bic's need to show testing of how they achieve mid bass sensitivity, IMO. The Hsu, while respected, its in a whole different (lower) class of sensitivity. You should find out why you would care able that based in your goals and amps.
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is offline
post #147 of 170 Old 08-22-2012, 10:32 AM
hogues's Avatar
Quoted: 85 Post(s)
Liked: 62
Just out of curosity, does anyone have a sho/pro-10 setup with front wides or heights? I'm considering a 9.1 or 11.1 setup and would like to hear from CHT owners who have tried it.
hogues is offline
post #148 of 170 Old 10-24-2012, 10:13 PM
colleycol's Avatar
Quoted: 24 Post(s)
Has anyone mounted the PRO or SHOs on the wall? I decided to go CHT all round but need to wall mount the surrounds.
I found these: http://www.ebay.com/itm/Pair-of-Steel-Large-Bookshelf-Speaker-Side-Clamping-Wall-Mount-Brackets-Black-/310405008416?pt=US_Speaker_Mounts_Stands&hash=item4845948c20
But they are 11 inches wide and the speakers are 11.5 in wide.
post #149 of 170 Old 10-25-2012, 02:52 AM
Rijax's Avatar
There is a thread over at the Chase Home Theater forum entitled "Success wall mounting SHO-10." If you'll stop by there and do a search for it, it might prove helpful.
Jack
Rijax is offline
post #150 of 170 Old 12-03-2012, 05:43 AM
busbeepbeep's Avatar
Did you ever pair your SHOs with the Mirage OMD-5?
I just ordered 3 PRO-10s and I currently have a pair of OMD-5s. I nearly pulled the trigger several times on the rest of a Mirage OMD system, but looks like the I missed the window at Vanns. Anyway, I plan to use the PROs as my front stage and put the Mirage in the rear.
People who have a combination of PRO and SHO speakers, should I buy a Eminence Delta driver to replace the PRO woofer in my center channel? Why do people recommend using a SHO as a center? (CHT was sold out of SHO-10s)
busbeepbeep is offline
Reply Speakers
