Speaker recommendations for Denon 1911 please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 34 Old 04-06-2011, 04:08 PM - Thread Starter
srikkanth.m's Avatar
Quoted: 46 Post(s)
Hi all,
I am new to this forum and also to this whole HT world. After some research, I decided to buy the Denon 1911 receiver. Now, I am looking for a nice 5.1 speaker set up. 1911 is going for about $370 on amazon. My budget for speakers is about $800. My room is about 20'x10' with an opening into kitchen on the left side while facing the TV.
Any suggestions are appreciated.
I am leaning towards the Energy Take Classic 5.1.
I am open for any suggestions as long as the speakers set up falls with in $800 tops.
Srikanth
srikkanth.m is offline
post #2 of 34 Old 04-06-2011, 04:54 PM
afrogt's Avatar
Quoted: 1440 Post(s)
Liked: 983
Must you have satellite speakers? If not I'd recommend some towers, bookshelf speakers or a combination of both.
Jamo s606 5.0 system, $399
http://www.vanns.com/shop/servlet/it..._c=site_search
Emotiva sub10, $329
http://emotiva.com/ultra_sub10.shtm
You'd be much happier with this system than with little Energy satellites which won't do nearly as good a job filling up your 20' x 10' room.
Another option if you don't want cherry/dark apple colored speakers would be one the of the Jamo/Denon bundles and the same Emotiva subwoofer.
http://6ave.com/shop/product.aspx?sku=CESAVR1911JAMO
$626 including speakers and Denon 1911 receiver. Emotiva sub at $329 will bring total to $955 for speakers, sub and receiver which is a pretty good deal.
Afro GT
afrogt is offline
post #3 of 34 Old 04-06-2011, 05:15 PM
ack_bk's Avatar
Quoted: 616 Post(s)
Liked: 697
Emotiva sub10, $329
I agree. The Jamo system seems like a much better deal. I would not spend that much on a receiver for that size room for smaller speakers that are made more for a bedroom or smaller room.
To get you into the Jamo/Emo setup you may also consider saving some money by going with the Denon 591 since it is cheaper and offers almost the same features but it is not 7.1 it is 5.1??
ack_bk is offline
post #4 of 34 Old 04-06-2011, 05:45 PM
afrogt's Avatar
Liked: 983
Yep, the 591 is only a 5.1 receiver. I have one.
The 791/1911 has some added features such as more power, USB iPod input, 1080p upscaling/processing of analog sources, etc. The extra features may or may not matter to you.
Afro GT
afrogt is offline
post #5 of 34 Old 04-06-2011, 08:32 PM - Thread Starter
Quoted: 46 Post(s)
Thanks for the suggestion. I will look into it. Also do you know what is the difference between the 606 and 426?
post #6 of 34 Old 04-06-2011, 08:41 PM
ack_bk's Avatar
Quoted: 616 Post(s)
Liked: 697
The 606 has larger woofers (8 inch) vs the 426 (5.25") and looks to have a better overall fit and finish. One can only assume the 606 may have slightly better components and would most likely sound better.
ack_bk is offline
post #7 of 34 Old 04-06-2011, 08:45 PM - Thread Starter
Quoted: 46 Post(s)
Great. In general how does Jamo sound? I am making this because I don't really have a way to get a demo any where near to me. The spec looks good. Also the sub you suggested is of a different make. Would that be a problem?
post #8 of 34 Old 04-06-2011, 09:00 PM
ack_bk's Avatar
Quoted: 616 Post(s)
Liked: 697
Jamo as a brand name is much more popular outside of the US, I have heard a few Jamo speakers over the years, but not the two you are considering. I thought they were good speakers and these seem to come recommended by folks who have bought them. For what you are paying, you seem to be getting a lot. I know for me I would take this Jamo 606 package anyday over a HTIB package with small satellite speakers for mains.
As far as matching speaker it is important to match your front 3 main speakers (left, right, center) for timbre matching. It is nice to match the surrounds as well. The subwoofer is not something you need to worry about matching and you can usually get much more bang for the buck by buying an Internet Direct subwoofer.
ack_bk is offline
post #9 of 34 Old 04-06-2011, 09:00 PM
afrogt's Avatar
Liked: 983
A different make sub is definitely not a problem. Buying a sub from a dedicated subwoofer company will give you more bang for the buck.
Jamo is neutral sounding to me. No emphasized treble/high frequencies like Polk and Klipsch seem to do. Just a good balanced speaker.
Afro GT
afrogt is offline
post #10 of 34 Old 04-07-2011, 08:45 AM - Thread Starter
Quoted: 46 Post(s)
Thanks for all the suggestions. Do you have any other brands that I can actually take a demo? I trust the reviews here but I like to listen to the speakers before I pull the trigger. It's ok if the budget goes a little over to say $900 just for the speakers.
post #11 of 34 Old 04-07-2011, 08:50 AM - Thread Starter
Quoted: 46 Post(s)
Also, what do you think about the Jamo sub here: http://www.vanns.com/shop/servlet/it...res/549114852/
post #12 of 34 Old 04-07-2011, 08:56 AM
ack_bk's Avatar
Quoted: 616 Post(s)
Liked: 697
I would not go with an 8" sub personally. If you look in the sub forum most people recommend the BIC F12 in the $180-200 price range. For slightly more people like the BIC PL-200 and the Premier Accoustics PA-120.
If you want to spend $300-420 you have lots more options. The F12 is probably a good starting point. Can usually find it for $180-185 shipped (have seen it lower from time to time).
ack_bk is offline
post #13 of 34 Old 04-07-2011, 10:45 AM - Thread Starter
Quoted: 46 Post(s)
Ok. After reading all the reviews and suggestions I am almost convinced with the Denon 1911 + Jamo S606 + BIC F12 set up. I will order those babies today. What kind of wiring. plugs do I need to set these up?
I am totally new to this and I am really excited to do this myself
post #14 of 34 Old 04-07-2011, 10:47 AM - Thread Starter
Quoted: 46 Post(s)
Also do you have any good suggestions for stands for rear speakers? I don't like them on my wall.
post #15 of 34 Old 04-07-2011, 11:30 AM
afrogt's Avatar
Liked: 983
You need speaker wire, banana plugs, subwoofer cable and probably a few HDMI cables. Without knowledge of your other devices, we don't know for sure.
What else are you connecting to this sysystem?
I buy all my cables at monoprice.com and am very happy with their performance.
14ga speaker wire
Banana Plugs, 1pr for each speaker and 1pr for each channel on the receiver. Highly recommend them for the receiver as it keeps things clean. Not as critical for the speakers but I like using them there too.
others like these Nakamichi plugs on ebay.
http://cgi.ebay.com/24-100-Nakamichi...item518e78f24d
Subwoofer cable, get whatever length you need.
HDMI cables
http://www.monoprice.com/products/su...02&cp_id=10240
Lots of HDMI to choose from, get whatever color, length, style you want.
Afro GT
afrogt is offline
post #16 of 34 Old 04-07-2011, 11:33 AM
afrogt's Avatar
Liked: 983
Sanus makes good inexpensive stands anywhere from 24"-31" inches. So does Wood Technology as they go as tall as 35".
Check racksandstands.com or standsandmounts.com as well as amazon.com. You'll have to decide what's best for your budget and appearance,.
Afro GT
afrogt is offline
post #17 of 34 Old 04-07-2011, 12:41 PM - Thread Starter
Quoted: 46 Post(s)
14ga speaker wire
HDMI cables
Awesome. I will be connecting my PS3 and bluray player with HDMI
post #18 of 34 Old 04-07-2011, 01:30 PM
ack_bk's Avatar
Quoted: 616 Post(s)
Liked: 697
You cannot go wrong with Monprice. I do recommend spending a few dollars more and getting their higher rated HDMI cables.
I have never had an issue with Monoprice. Great service, fast shipping, great prices.
ack_bk is offline
post #19 of 34 Old 04-07-2011, 03:34 PM
dbergs's Avatar
Please be sure to report back to this post with how you like your set up! Your room size and budget are very close to what I have. And I'm new to this home theater thing too.
dbergs is offline
post #20 of 34 Old 04-07-2011, 04:52 PM - Thread Starter
Quoted: 46 Post(s)
I just visited a local store and that was offering Atlantic technology 2200 system for $999. I got a demo and they sounded awesome. My only concern is they are an open box item that the store has had on display for about a year and a half and the system itself came out sometime in 2007. Do you think its worth the money?
post #21 of 34 Old 04-07-2011, 05:08 PM
zieglj01's Avatar
Quoted: 1714 Post(s)
Liked: 1632
They sold for around $2200 - it is your decision.
I wish a lot of people could here, Atlantic Technology systems.
Even with music - the sound will draw you in.
If they are not beat up - I would lean towards it.
Hard to find something for $1000, that can beat that sound.
http://www.hometheaterhifi.com/volum...06-part-1.html
__________________________________________
Who AM I
Speakers -- Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is offline
post #22 of 34 Old 04-07-2011, 05:52 PM
afrogt's Avatar
Liked: 983
Originally Posted by zieglj01 View Post
They sold for around $22000 - it is your decision.
I think you've got one too many zeroes there buddy!
from your link...
Well, they came very close with their System 2200. This package delivers an impressive experience, while ranging in price from $2,000-$2,600 depending on configuration.
Afro GT
afrogt is offline
post #23 of 34 Old 04-07-2011, 06:17 PM
zieglj01's Avatar
Liked: 1632
from your link...
I corrected my post.
It has been a rough month - thanks for looking out - you do good stuff.
I have owned Atlantic speakers, and they are serious sounding.
Who AM I
zieglj01 is offline
post #24 of 34 Old 04-12-2011, 03:34 PM - Thread Starter
Quoted: 46 Post(s)
Hi,
Sorry for the late updates. I was caught up in work last week. So I finally ordered the 1911+Jamo s606 HCS3+BIC F12
I also ordered cables and 12 pairs of banana plugs(Hope they are enough?) from monoprice.
The items are on their way. I will keep you posted with my setup and how i feel about it.
Thanks again.
post #25 of 34 Old 04-18-2011, 09:14 AM - Thread Starter
Quoted: 46 Post(s)
Received my order just now. I will assemble everything today. I am excited!
post #26 of 34 Old 04-18-2011, 09:48 AM
amarshonarbangla's Avatar
Quoted: 30 Post(s)
Liked: 43
Be sure post pictures after you are done setting it up. Where did you order your speakers from btw? 6ave?
amarshonarbangla is offline
post #27 of 34 Old 04-19-2011, 09:07 AM - Thread Starter
Quoted: 46 Post(s)
Hi guys I set up my first HT system ever yesterday and watched iron man 2. The entire set up was awesome!
The Jamos along with the Bic F12 rocked. Absolute delight!
Thanks for all your suggestions. I placed my entire order via amazon sold by http://www.acousticsounddesign.com/
I got my Jamo s606 HCS3 for $399 shipped and the BIC F12 for $168 shipped. The Denon 1911 was from Vanns for $399 shipped.
Thanks for all your suggestions and advice.
You guys rock.
I need to clean the mess from my set up. I will post some pics after that.
Thanks again.
post #28 of 34 Old 04-19-2011, 09:08 AM - Thread Starter
Quoted: 46 Post(s)
This set up is AWESOME! and the price can't be beat! Go for it! Worth every Penny.
post #29 of 34 Old 04-19-2011, 10:23 AM
Quoted: 30 Post(s)
Liked: 43
You guys rock.
Thanks again.
Wow $168 for the f12? That's an amazing price. I have never seen the price go lower than $185 on amazon for that sub. Lucky you.
post #30 of 34 Old 04-19-2011, 10:26 AM
afrogt's Avatar
Liked: 983
You guys rock.
Thanks again.
I thought Vanns was the only one who sold the S606 for that price. Did you get Dark Apple?
Afro GT
afrogt is offline
Reply Speakers
