Almost got floored by Cambridge S30 - Page 14 - AVS Forum | Home Theater Discussions And Reviews
post #391 of 410 Old 05-09-2014, 08:41 PM
sevenz's Avatar
Quoted: 74 Post(s)
Liked: 51
Originally Posted by DLeague View Post
They are one of the truly small audiophile speakers that are better than any!!! small speaker I've heard, and I've heard most in my position. I've A/B this speakers with the Wharfedale Diamond 10.2 and both are excellent speakers, but the suttle details aren't always found on the Diamond, and I consider it the gold standard of small speakers.
+1 too on the s30. They are my favorite speakers so far though I had to sell them away due to upgrade. Little speakers that wow anyone. Looks elegant too.
I think I will try snagging a used pair of SL30 just for nostalgia sake. Though they still have stock of the s30 in my shops here. smile.gif
sevenz is offline
post #392 of 410 Old 05-09-2014, 09:34 PM
Rob840's Avatar
I have a pair of these in my office set-up and they are delightful. When I first bought them, I tried them in my main rig in my dedicated music room and I was surprised how they filled the room and they were not harsh. They really shine in my office. Keepers for sure!
Music Room: Marantz PM8004, Marantz SA8004, Audioquest ICs, Emotiva speaker cables, Quad 22L2, Pioneer DV610AUK universal player
Family room: Tascam PA-R100 AVR, Panasonic DMP-BDT220, Jamo S606 5.1 system, Dayton speaker cables, Sharp Aquos tv
Office: Teac CRH500NT internet receiver, Cambridge Audio S-30, Jamo 210 sub
Home Theatre Room: (under construction) Oppo 103
Rob840 is offline
post #393 of 410 Old 05-10-2014, 10:02 AM
sdg4vfx's Avatar
Quoted: 118 Post(s)
Liked: 153
Using a pair as my bedroom speakers. Still occasionally surprised by how good they sound and deep they dig, esp. for their price wink.gif
sdg4vfx is offline
post #394 of 410 Old 05-17-2014, 01:33 AM
csgamer's Avatar
Liked: 29
I think I'm really close to pulling the trigger on some s30's. Gonna put them in my workout room, relatively small room, no subwoofer. Should I be worried about bass output?
I'm no crazy basshead, but don't want music to sound too thin. Definitely don't want boomy bass though. Much prefer bass that is more articulate.
csgamer is offline
post #395 of 410 Old 05-17-2014, 09:29 AM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
The S30 gets a ton of attention, but the S70 tower version is rarely mentioned, why is that? Has anyone done a comparison of them?
Benq W1070 projector w/ Chief RSM mount with custom interface bracket
119" Da-Lite Cinema Contour with High-Contrast (gray) Da-Mat screen
Denon X2000 receiver fed by Panasonic DMP-BDT210 Bluray player
Focal Chorus 700-series towers and center, JMLab Tantal 500-series bookshelf rears
Rythmik FV15HP sub
niccolo is offline
post #396 of 410 Old 05-17-2014, 06:17 PM
csgamer's Avatar
Liked: 29
What to power the s30's and play mp3's from usb drive.
Hmm, how should I power these s30's? Get a regular avr or something else like a topping tp-20, http://www.parts-express.com/topping-tp20-mk2-ta2020-class-t-digital-mini-amplifier-25wpc--310-320
If the topping tp-20 is sufficient to power s30's in a small 10x14' room, then I would need something to hook up to play mp3's from usb drive. Dunno what to use for that.
csgamer is offline
post #397 of 410 Old 05-17-2014, 08:30 PM - Thread Starter
zieglj01's Avatar
Quoted: 1530 Post(s)
Liked: 1362
For most of us - the Cambridge has good bass response - and it is not sloppy or boomy
I would aim higher than the topping - think about getting a refurbish AVR
If you still want a amp - then look at something like the Sherbourn (Emotiva)
http://www.accessories4less.com/make-a-store/item/shrbnpa250/sherbourn-pa-2-50-stereo-flex-amplifier/1.html
__________________________________________
Who AM I
Speakers -- Snell K7 > Digital Phase AP-.5 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #398 of 410 Old 05-17-2014, 09:10 PM
csgamer's Avatar
Liked: 29
Yes, the more I read about the s30, the more I want to try it out. Have the popular infinity p163 and p363 already. Tried the pioneer 2nd gen andrew jones, energy rc-10. Nothing much else left in the lower budget range, $250 under, that is interesting enough that I want to audition, unless I'm missing something. I also see the boston a26 at same price range, but not too sure of that, read some negative comments about boomy bass.
I'll probably just go with a regular avr, seems like the best solution, no worry about enough power, flexible, built-in screen. Guess I'll just deal with the extra size. Actually, correction, guess the wife will have to deal with the extra size. It's tougher getting larger size audio purchases wife approved.
csgamer is offline
post #399 of 410 Old 05-17-2014, 10:06 PM
sdg4vfx's Avatar
Quoted: 118 Post(s)
Liked: 153
The S70 towers are $260 a pair - maybe a consideration if you want a bit stronger bass.
sdg4vfx is offline
post #400 of 410 Old 05-17-2014, 10:15 PM
Rob840's Avatar
From what I gather, they were just never a strong seller here in the USA. I have read some good reviews and a few so-so reviews. The so-so reviews were by users who reported that the tweeter can be blown rather easily. For the price of these at Accessories 4 Less, I have been tempted to get them for the heck of it, just to compare them to my S-30s. However, I am also intrigued by the Cambridge Aero 6.
jaeelarr likes this.
Rob840 is offline
post #401 of 410 Old 05-17-2014, 10:35 PM
losservatore's Avatar
Quoted: 2611 Post(s)
Liked: 2393
S70
Sensitivity: 90dB
Frequency Response: 39Hz - 20kHz
Nominal Impedance: 4-8 Ohms
Drive units: Tweeter: 1 x 25mm (1”)
Woofer: 2 x 130mm (5") mid/bass driver
Crossover: 2nd Order 2.5 way
Recommended maximum amplifier power: 120 Watts
Magnetically shielded: Yes
Dimensions (W x H x D) 160 x 938 x 240mm (inc. grill) (6.3 x 36.9 x 9.4”)
Weight 12.4Kg (27.3lbs)
S30
Sensitivity: 90dB
Frequency Response: 55hz - 20kHz
Woofer: 1 x 115mm (4.5") mid/bass driver
Crossover: 1st Order 2 way
Recommended maximum amplifier power: 100 watts
Ported: 1 Rear
Dimensions (W x H x D) 160 x 226 x 235mm (inc. grill) (6.3 x 8.9 x 9.2”)
Weight 3.75Kg (8.3lbs)
losservatore is offline
post #402 of 410 Old 05-17-2014, 10:44 PM
Liked: 2393
About the aero I recommend to read Dennis Murphy review he is the owner of philharmonic speakers.
http://www.avsforum.com/t/1504045/cambridge-aero-2-bookshelf-speaker
post #403 of 410 Old 05-17-2014, 11:53 PM
csgamer's Avatar
Liked: 29
Yeah, i considered the s70. I couldn't find that much info on them as much as the s30. Sometimes, bookshelf turns out better than the floorstanding version. I think it was this way with the 2nd gen pioneer fs52 to bs22. The bs22 is the best of that line in my opinion.
Ah, I'm still confused on what to get. I don't have the luxury of switching out speakers to often due to wifey, so I get speaker analysis paralysis. It's been so long, but I did enjoy the bs22 that i had in a desktop setup. I might have went with the Dennis Murphy modded bs22's but that is not on offer anymore it seems. But it looks like the modded fs52 tower will be offered some time.
I'm wondering which will perform best without a subwoofer: stock bs22 vs modded bs22 (if offered again). Modded bs22 vs modded fs52.
Stock fs52 is a no go, something was up with the tweeters on mine with excessive sibilance, not gonna try that again. S30 vs modded bs22. S70 vs modded fs52.
Hmmm, I still got time to think, also I think the modded fs52 is still not ready yet. Only problem is additional cost and especially tower speakers will be harder to pass wife approval especially since I'm also bugging about buying a new car too.
csgamer is offline
post #404 of 410 Old 05-21-2014, 02:10 PM
jakeroux's Avatar
Originally Posted by VectorLabs View Post
Does anyone know where I can get a hold of 3 of these babies? All the places I found seem to only sell in pairs but need a third for a center channel in a small room. Got a very small system planned out with 3x of these on the front and 2x Infinity 1262W 1.5cf sealed subs.
Why not just pick up Cambridge's center channel speaker, the S50? Shows that they are still in stock at Accessoriesforless.
jakeroux is offline
post #405 of 410 Old 05-22-2014, 07:39 PM
JustAnOldVCR's Avatar
S50 has smaller drivers than s30. S30 are over 5 inches in reality I believe.
4 inches doesn't compensate for much...
JustAnOldVCR is offline
post #406 of 410 Old 07-10-2015, 11:09 AM
Liked: 0
Bump!
Greetings guys!
Wanna upgrade my desktop speakers. Can't choose between Cambridge Audio S30 and Audiorngine P4...
Though Cambridges price is 135$, barely used, mint condition.
Any advice?
Dmitry Kudosh is offline
post #407 of 410 Old 07-10-2015, 02:22 PM - Thread Starter
zieglj01's Avatar
Liked: 1362
Originally Posted by Dmitry Kudosh View Post
Bump!
Greetings guys!
Any advice?
Only you can make that choice - however based on the pass and some reviews,
the Cambridge was favored.
Who AM I
post #408 of 410 Old 07-11-2015, 12:48 AM
Liked: 0
Indeed, but i can't compare those in real life.
But to be sure i just need to know, that Cambridge S30 + amp will be better way to enjoy music, instead of active speakers Vigoole C2128! If better - i gonna upgrade...
post #409 of 410 Old 07-11-2015, 11:54 PM
sdg4vfx's Avatar
Quoted: 118 Post(s)
Liked: 153
3 years ago I auditioned/compared the S30 and the P4 in home. IMHO the high's and upper-mids were nice on both but the S30 was in a different class from lower-mid's on down.
Kept the S30's.
sdg4vfx is offline
post #410 of 410 Old 07-13-2015, 02:55 AM
Liked: 0
Today i visit man, who selling those S30.
I've listened how speakers play music, and it was nice sound.
And when i start to inspect them, before i pay, i've noticed, that one speaker have that silver thing (not sure how it in english - some phase correction ... plug?) in center of speaker not glued, but moving! And even touches coil! Damn, i so much want to get a pair for myself.
I think it's not so good to pay 135$ for defected unit... Maybe if i disassemble speaker i can get to base of that plug and fix it with glue, but i'm not sure...
Reply Speakers
Bookshelf Speakers , Cambridge Audio Bookshelf Speakers S30 , Speaker Systems , Pioneer , Cambridge Speakers S30 N
