Speaker Reccomendations Please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 04-27-2011, 01:58 AM - Thread Starter
rrwesquire's Avatar
Hello Forum World,
As a preface, I'm not an audiophile, just someone trying to get advice on some quality speakers for the money.
I just recently got my dad's old Marantz 510M amp and 3800 pre-amp, that he bought new circa 1977. I need to acquire some speakers for it. I am looking to get a pair of tower loudspeakers without built in subs. My price range is $1000-$1500 for the pair. I listened to a pair of Polk Rti A7's in Fry's and thought they sounded pretty good. A friend of mine gave me a sub that i also intend to use.
I would greatly appreciate some suggestions on speakers and/or thoughts on the Polk speakers mentioned above.
rrwesquire is offline
post #2 of 13 Old 04-27-2011, 04:36 AM
tigerstripe's Avatar
Originally Posted by rrwesquire View Post
Hello Forum World,
Hello if you will be using a sub, why bother to get towers? For the same price level, you can get bookshelf speakers one notch higher than the floorstanders from the same manufacturer if you can sacrifice some bass (which isn't a problem for your case as you will have a sub), but the bookshelf speakers will give you significantly better overall sound quality than the towers.
With this budget you don't need to get Polk speakers as you can get much better speakers from top tier international brand - like the Dynaudio Excite X12s and X16s are worth considering. I suggest you to listen to more famous speaker brands and see if you can tell the difference in sound quality (from Polk and other less famous speakers that are made in China).
tigerstripe is offline
post #3 of 13 Old 04-27-2011, 05:22 AM
Eyleron's Avatar
Quoted: 252 Post(s)
Liked: 143
I agree, that the sub suggests you can get nicer stand mounted speakers.
You may not claim to be an audiophile, but you scored some fantastic gear! Goes for $400 for the 3800 and $800 for the 510m.
Don't know what you're listening to (music, I presume?), or what model subs you have, but that setup will be warm enough that you can pair with brighter speakers.
If this is for casual listening in a living room, you can get less sensitive speakers, because the amp puts out over 250 watts per channel.
The gear is also "decorator friendly" in that it's sexy in the sense of a classic car. I'd display it prominently and pay attention to the wood cabinetry of the speakers you're looking at (among other things, of course).
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is online now
post #4 of 13 Old 04-27-2011, 05:27 AM
zieglj01's Avatar
Quoted: 945 Post(s)
Liked: 847
I would look at the Boston VS260 stand/shelf speakers - and they
are good.
http://www.bostonacoustics.com/-VS-2...aker-P229.aspx
However, for towers - I would look at the PSB GT1 - a very good sound and killer deal
http://www.saturdayaudio.com/picture...b_specials.htm
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
post #5 of 13 Old 04-27-2011, 12:39 PM
Wrager's Avatar
Quoted: 193 Post(s)
Liked: 114
Wrager is offline
post #6 of 13 Old 04-27-2011, 10:12 PM - Thread Starter
rrwesquire's Avatar
Thanks for the advice everyone! I suppose my desire to get tower speakers, even though I have a sub, proves my lack of knowledge in this area! In that regard, I will amend my inquiry to seek advice on what bookshelf speakers I should get in the same price range ($1,000-ish).
Thanks in advance for the help! Also one thing I might add, I live in Las Vegas, and for whatever reason, there doesnt seem to be any higher-end audio store's here. So unfortunately I cant really listen to other equipment than what they have the Fry's here.
post #7 of 13 Old 04-27-2011, 10:23 PM - Thread Starter
rrwesquire's Avatar
I'll add one more thing. My intent is to use the speakers both for music (mostly rock) and also for my tv (movies). It seems like optimally I would have a separate system for each use, however that is not feasible at this time. Would this intended use make the tower speakers make a little more sense? Or do I still want to get the bookshelf speakers on stands since I have the sub?
post #8 of 13 Old 04-27-2011, 10:28 PM
KMFDMvsEnya's Avatar
Quoted: 240 Post(s)
Liked: 402
Floorstanding speakers versus bookshelfs performance is highly dependent on the manufacturer's design decisions.
Both can provide great audio but as decent generalization a great pair of floorstanding speakers will provide better quality in dynamics, bass response, and output.
Best Regards
KvE
Politics is like a corral, no matter where you are you'll always be shoveling it.
KMFDMvsEnya is online now
post #9 of 13 Old 04-27-2011, 10:35 PM
zieglj01's Avatar
Quoted: 945 Post(s)
Liked: 847
As long as you have a good sub - then bookshelf speakers will do the job. You
can use the same speakers for both, music and movies/tv. The speakers that
are reccomended here, to me are better performers than the Polk Rti series.
You will have to decide, between towers and bookshelves. For the most part, I
have not listened to a tower, that sounds as good as a bookshelf, at the same
price. However, you do have to weigh in the cost of stands.
Who AM I
post #10 of 13 Old 04-27-2011, 11:55 PM
If you are new to the hifi world, at your price range I recommend you look for more famous international high end speaker brands, like the Dynaudio Excite X12 speakers - they have got budget component award 2010 from Stereophile and are 100% handcrafted in Europe, and in case you really do not like them for whatever reason, you can sell them at a very little loss since Dynaudio have one of the best resell value in the preowned or used markets around the world. Local US speaker brands like the made-in-China Polk, NHT, etc are good choices but they are not top tier international speaker brands. Getting a more famous brand is a safe bet for a hifi beginner.
Sorry I am not living in the US and do not know any dealer at your region, but you may go to this thread:
http://www.avsforum.com/avs-vb/showthread.php?t=686371
and the US distributor of Dynaudio will give you suggestions and contacts of different Dynaudio dealers for an audition.
post #11 of 13 Old 04-28-2011, 07:58 AM
Eyleron's Avatar
Quoted: 252 Post(s)
Liked: 143
Best Regards
KvE
I do agree with this more refined statement. The question is whether this matters to the OP.
A bookshelf and tower costing the same, by the same company, will have differences. In the bookshelf, the manufacturer could afford to put better technology in, because it has a smaller cabinet and perhaps fewer drivers. The tower, even given the same sensitivity spec, has advantages.
Picture two people who are tasked with the new Olympic sport of Singing-While-Running. One is a more gifted singer with more experience and capability. The other, lesser singer, is a better athlete, who can run while tiring less.
If you ask the two to sing while just loafing, warm up jogging around the starting line, the first, better singer, will be judged to sound better.
While running slow at 10 mph, the first is starting to run out of breath, and it affects his singing. The second, being the better athlete, has no trouble singing.
At 20+ mph, the first is only gasping, and is falling behind. The second is singing as well (or poorly!) as he did at the starting line jogging.
The bookshelf and tower may even have the same rated sensitivity as eachother. But that spec is probably just at 1000 khz. At 400 hz, which is still well above your subwoofer crossover, the bookshelf might have trouble producing the same volume, IF pushed to high volumes, as the tower, with its bigger cabinet, and perhaps bigger and more numerous woofers.
So, if you play at medium volumes (more quiet than at a good professional movie theater), the tower has no advantage, and may sound worse. At high volumes, the tower will produce bass with less distortion.
post #12 of 13 Old 04-28-2011, 04:09 PM
Kini62's Avatar
Quoted: 1425 Post(s)
Liked: 1319
What sub was given to you? If it's not a very good quality sub it will do more harm than good for music, in which case the tower speakers would be a better choice for music.
There are "bookshelf" models in your price range that have plenty of bass for small rooms for most music.
Gene
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is online now
post #13 of 13 Old 04-28-2011, 08:17 PM
Superdavetx's Avatar
I like the idea and suggestion about the PSBs. I have Alphas for my surrounds and was close to getting some PSB Silvers a few years ago.
Later I heard some Seas driven speakers and then decided to try Ascend Acoustic's CMT340s. Smaller but sound great. The PSBs towers will sound good as well.
I like B*W and BA, but you will likely pay more for those.
Dave
Superdavetx is offline
Reply Speakers
