RCA to Speaker Wire? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 05-08-2011, 11:30 AM - Thread Starter
Canute13's Avatar
Alright, so I have these Bose speakers that only have inputs via RCA. I want to hook them up to my amp though with speaker wire. I stripped them and I found the wires that I needed. Just a couple questions about that...is this a good idea? I have heard that it can blow your speakers and that the sound quality is terrible. Also, is the prong of the RCA positive or negative? I'm pretty sure it's negative I've just heard both...thanks for the help in advance.
Canute13 is offline
post #2 of 12 Old 05-08-2011, 11:35 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Those Bose speakers should only be plugged into the bass module, not directly to your receiver terminals. You can try it if you want though.
Afro GT
afrogt is offline
post #3 of 12 Old 05-08-2011, 12:49 PM - Thread Starter
Canute13's Avatar
Bass module? I am just plugging them into a basic amp with inputs for two sets of speakers. They are meant to be plugged in like that except that the amp only has inputs for regular speaker wire.
Canute13 is offline
post #4 of 12 Old 05-08-2011, 02:15 PM
RicardoJoa's Avatar
Quoted: 23 Post(s)
Liked: 24
I never heard rca to speaker cable connections. The signal between the two are even the same. Maybe you can tell what bose speakers you have.
RicardoJoa is offline
post #5 of 12 Old 05-08-2011, 02:51 PM
dbx123's Avatar
The prong should be negative and the outside wire should be positive. It should work fine. Keep in mind, we don't know which Bose spkrs you're referring to. If they were meant to be used with a bass module, then you may risk having the proper coils (crossover) to prevent excessive low signal from damaging these. If they're just ancient Bose with RCA terminals (like lots of speakers from back in the day)...you should be fine. Make sure you know which .
dbx123 is offline
post #6 of 12 Old 05-08-2011, 03:15 PM
bighick's Avatar
I always thought pin was positive and ring is negative. Otherwise you would random shorts when digging around behind a device. But hey whoever designed them could have been schmuck like the guy who decided which was ring and tip for phones.
bighick is offline
post #7 of 12 Old 05-08-2011, 04:19 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
It doesn't matter if you wire the speakers up out of polarity, it won't hurt anything. You'll just hear less bas if you wire it backwards. Try it both ways and see which sounds better.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #8 of 12 Old 05-08-2011, 04:57 PM
afrogt's Avatar
Liked: 755
What Bose speakers do you have? You never did mention the model. I haven't seen speakers that use an RCA input in a log while except on computer speakers.
Afro GT
afrogt is offline
post #9 of 12 Old 05-09-2011, 06:43 AM
Ratman's Avatar
Quoted: 1271 Post(s)
Liked: 1022
You are correct.
Ratman is online now
post #10 of 12 Old 05-10-2011, 11:27 AM - Thread Starter
Canute13's Avatar
Thanks for all the replies. The speakers are Bose Roommate II, and they are just ancient I think, the inputs are RCA. That's all, they are kind of all in one speakers I believe. And I was also asking this question because I was going to hook up some speakers that have speaker wire terminals but my amp only has RCA outputs (weird, I know).
Canute13 is offline
post #11 of 12 Old 05-10-2011, 11:45 AM
Pugnax555's Avatar
Aren't the Bose Roommate speakers powered? If so, that explains why they have RCA terminals -- they're designed to take a line level signal for input. I'm not sure I want to know what happens when you hook speaker wires to a line level input.
Pugnax555 is offline
post #12 of 12 Old 05-12-2011, 06:27 AM
Ratman's Avatar
Liked: 1022
Those speakers are not intended for "speaker" level outputs. They are for "line" level output (portable CD players) and recommended to be connected to a "headphone" output of the device.
What is the make/model of the receiver? If it has a headphone jack, you can use it for the Bose speakers.
Reply Speakers
