how to use my old speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 05-15-2011, 03:58 AM - Thread Starter
gajodharbhaiya1's Avatar
have 5 speakers from my old panasonic SB-AK-87 system (fronts 6 ohms- 160W). The player and amp are unserviceable. need help to put them to use. Can I buy an onkyo or yamaha receiver and put them to use (Will it match?)
gajodharbhaiya1 is offline
post #2 of 14 Old 05-15-2011, 04:16 AM
ifor's Avatar
Quoted: 59 Post(s)
Liked: 72
any surround receiver should be able to power your speakers if they are 6 ohms. I cant find anything on your model though.
ifor is offline
post #3 of 14 Old 05-15-2011, 09:55 AM
schan1269's Avatar
All speakers(low ohm load is the sole exception) work with all audio amplifiers ever made...
6ohm is not considered a low ohm load.
schan1269 is offline
post #4 of 14 Old 06-02-2011, 11:51 AM - Thread Starter
thanks schan1269 and ifor. am going to look for some. any suggestions?
post #5 of 14 Old 07-04-2012, 01:58 PM
Elena Moiseeva's Avatar
Hi! I'm having a problem with finding a suitable receiver for my 6 ohm speakers. If you could answer, I'd be very grateful))
Panasonic SB-PM41, 2 speakers. Each speaker has 4 cords (+ high frequency, - high freq, + low freq, - low freq). But! All receivers I checked have no outs for that (yamaha crx-550, for example, has 4 outs, R+ R- L+ L-). Guys in e-markets say they don't know that sort of ancient speakers =)
Can I do anything about that? Is there any suitable receiver? Or maybe I have to buy an amplifier and a media-player? Maybe I can let the wires modify, can I?
Elena Moiseeva is offline
post #6 of 14 Old 07-05-2012, 05:22 AM
barryecohen's Avatar
Quoted: 21 Post(s)
You need either a bi-wire speaker cable, or a set of jumpers to go from the low to high speaker binding posts.
P.S. Examples of both can be seen here...
http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=bi-wire+speaker+cable&_sacat=0
Please see my later post below...
So much media, so little time...
Oppo BDP-83 > Emotiva UMC-200 > Audio Alchemy OM-150 Dual Mono > Gallo Reference 3.5
_____________________________ > Audio Alchemy OM-150 > Gallo Strada
barryecohen is offline
post #7 of 14 Old 07-05-2012, 06:21 AM
Bill Fitzmaurice's Avatar
Liked: 4630
Perhaps, perhaps not. If the speakers are wired for bi-amping, as opposed to bi-wiring, they would not contain crossovers, and directly wiring the HF drivers to an amp would result in magic smoke. The OP needs to get a manual for them to be sure.
Bill Fitzmaurice is offline
post #8 of 14 Old 07-05-2012, 12:43 PM
Quoted: 21 Post(s)
Maybe, but I doubt it...
http://www.crutchfield.com/S-ESG0IDKpQWo/p_133SCPM41/Panasonic-SC-PM41.html
P.S. I stand corrected, found the owners manual, via google, on the Panasonic website, the speakers do require an external crossover...
http://service.us.panasonic.com/OPERMANPDF/SAPM41.PDF
post #9 of 14 Old 07-09-2012, 07:01 AM
So, my speakers are bi-amp speakers, and they require an external crossover or an amplifyer that already contains it. Did I get it right?
Thanks a lot for your answers!
post #10 of 14 Old 07-09-2012, 07:09 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
It's extremely unlikely that speakers would require an external crossover; that is extremely rare! Yours definitely do not!
You have two options. One is to just tie the two pairs of terminals on each speaker together with short jumper wires and run a single pair of wires to each speaker. The other is to run two pairs of wires to the speaker from each pair of amplifier terminals (bi-wiring").
I would not bother with bi-wiring unless you are running more than 15 feet (5 meters) of wire to the speakers. Just use #14 wire.
(do you mean "SP-BS41" ??)
commsysman is offline
post #11 of 14 Old 07-09-2012, 08:00 AM
Liked: 4630
It does appear that way, since they are dedicated to that system, the system uses a bi-amped amplifier output, and the speaker input connection instructions contain this warning:
Cords with white and blue tags are for high frequency.
Cords with red and black tags are for low frequency.
Incorrect connection can damage the unit.
post #12 of 14 Old 07-14-2012, 03:28 PM
Hi! No! I mean Panasonic SB-PM41. They are speakers from an old stereo system.
Unfortunately, they don't provide any possibility to use another wires.
Anyway thank you! Now I know my speakers do have a crossover (looked into specification))
post #13 of 14 Old 07-14-2012, 03:53 PM
Thank you all for direction!
Looked into specification. It is said, crossover's frequency is 1khz and 10khz. I guess that means it exists. And bi-amp amplifier existed too.
I'm totally lost:) I thought I could find an alternative for that unit and use the speakers I liked and considered quite good. I started to think they are not that good to make a hi fi system -)
post #14 of 14 Old 07-14-2012, 07:50 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I would really play it safe, and start over with a new receiver and speakers. There are better
choices out there.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
Reply Speakers
