Need Advice: best setup for $1k-$1.5k - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-27-2011, 03:26 PM - Thread Starter
adam78332's Avatar
Hey guys,
I have a dedicated home theater room (13.1" X 18.6"). I need advice on whether to upgrade my sound system or not.
My current setup:
Samsung PN63C8000 63-Inch 1080p 3D Plasma HDTV, Black
Onkyo-SR605 receiver
KEF KHT-3005 system
PS3 (blu-ray, games)
My problem:
That TV is new, and has 3D capabilities, but the Onkyo won't pass 3D (only has HDMI 1.3). I don't use 3D too much, but it's annoying to have to bypass my system and just use TV speakers.
I thought I'd get a new receiver to pass HDMI 1.4a, but maybe jsut upgrade the whole system.
What's the best could I get for about $1k-$1.5K?
Are 2 of those KEF's ok to use as my rear's if I replace the front 3? Is that sub still adaquate if I get better fronts/center?
Should I just leave it alone (saying that I can't get much of an upgade for my budget)?
I'm not 'unhappy' with my current setup, but if I could upgrade and really notice a difference, i'd like to.
I've read people on this board saying you're better off treating the room than changing equipment. I just have two rows of seats (back row on a carpeted riser). I know I need to paint it, but didn't really look beond that.
what's the best use of my money?
adam78332 is offline
post #2 of 8 Old 05-27-2011, 04:00 PM
TheGoatLantern's Avatar
Is the ps3 a fatty or is it slim? If a fatty do this:
Start with the basics.
1. Get a new receiver that has HDMI pass through with lossless codecs
2. Get a dedicated 3D Blu ray player that has Dolby HD and DTS HD (can't remember the actual name ATM)
3. Sub
4. Speakers.
5. Configure room to optimize set-up.
Truthfully there are a million different options in that price range, just research and find the best deals (craigslist, ebay, here, amazon) and get what you can for your dollar.
TheGoatLantern is offline
post #3 of 8 Old 05-27-2011, 04:04 PM
jmichaelf's Avatar
Truthfully, "a million" smells a little bit hyperbolic.
jmichaelf is offline
post #4 of 8 Old 05-27-2011, 04:08 PM - Thread Starter
adam78332's Avatar
The PS3 is a slim...
by your sequence, you're saying it is worth upgrading receivers just to get the HDMI 1.4a pass-thru, and that upgrading the sub in that KEF system is neccessary?
If I do upgrade the receiver: can I buy a $1k speaker package that will be noticably better than those KEF's? Or should I just stick with those current speakers and only replace the receiver.
I'd hate to spend $1k on speakers and not notice anything atl all....
I appreciate the help. thanks.
post #5 of 8 Old 05-27-2011, 04:09 PM
Of course it was. I like to exaggerate, but I stand behind my statement there is actually a lot you can get for that money.
post #6 of 8 Old 05-27-2011, 04:13 PM
If you are hapy with the speakers than by all means stick with them, I would. And a dual bass set-up would make it even more enjoyable.
New list:
1. Receiver one with HDMI 1.4a pass through and all current lossless codecs
2. Powered sub
post #7 of 8 Old 05-27-2011, 04:19 PM
Here I did a little searching...
1. Similar receiver with updated specs: http://www.amazon.com/Onkyo-TX-NR609...dp_ob_title_ce
2. Powered sub: http://www.epiksubwoofers.com/legend.html
I just did some light searching and for around 1300 you can do a nice upgrade (dual legends as opposed to a single). But again you can prolly find that stuff for a bit cheaper with a little research.
post #8 of 8 Old 05-27-2011, 09:25 PM
schan1269's Avatar
Don't forget to sell your present 605 on Ebay...
The 605 is currently selling for $125-$150(same basic price as its sister, the Integra DTR 5.8).
There are plenty of people out there that don't care about 3D that only need 2 HDMI and upconversion for a Wii.
Also, instead of dumping the speakers...do 7.1 and just get a pair of iQ KEF for the front.
KEF KHT and iQ match up well.
schan1269 is offline
Reply Speakers
