Recommendations for Better Setup then this? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-04-2011, 05:31 PM - Thread Starter
packattak's Avatar
I just bought a Denon 1912 Receiver, and was hoping to put together a 5.0 system together and worry about the sub when i have the money.
Does anyone have a better suggestion then starting with
4 x Energy cb-5
and a Energy cc-10 center?
They seem to get consistently get good reviews.
My budget is 700, and I'd probably be listening to movies 60% of the time and music the other 40%.
I'd be greatly appreciative of any suggestions that someone could offer.
packattak is offline
post #2 of 9 Old 06-04-2011, 05:39 PM
skally's Avatar
Are you looking for a 5.0 system with toweres or keep it samall with bookselfs?
skally is offline
post #3 of 9 Old 06-04-2011, 05:51 PM - Thread Starter
packattak's Avatar
Just trying to keep it small with a bookshelf setup. In reading through most of the posts here, I've come to understand that a bookshelf setup will be much better then any 5.1 box system i would find out there.
post #4 of 9 Old 06-04-2011, 05:59 PM
Smigro's Avatar
Quoted: 237 Post(s)
Liked: 221
Check out www.newegg.com and look into some Polk Monitors. They are very affordable starter speakers, and do a good job with movies and gaming.
Ed
Panasonic VIERA TC-P60ST60 Plasma, Onkyo TX-NR1008 receiver, OPPO BDP-83 region free, Xbox One, PS4, eD[c]12 LCR, Klipsch R-14M surrounds, Rythmik FV15HP sub
Xbox GT / PSN ID - Smigro
BD collection http://www.blu-ray.com/community/col...0&categoryid=7
Smigro is offline
post #5 of 9 Old 06-04-2011, 07:25 PM
postrokfan's Avatar
Quoted: 611 Post(s)
Liked: 3718
Two suggestions (both from internet stores):
I don't have a problem with Polk or Energy but I think the budget suggestions below would provide better sound.
Ascend Acoustics setup (internet only, no middle-man CA based company-all products made in USA with parts occasionally sourced from other countries)
2xCBM-170SE Front R/L
1xCBM-170C Center
2xHTM-200SE Rear R/L
$668+$68shipping=$738 (Just above your budget but worth it I think)
You could opt for 2xCBM-170SEs for rears that would increase total to $764.
www.ascendacoustics.com
30-day satisfaction guarantee which is great since you can't listen to them in a store.
Infinity setup from Harman Audio
2xPrimus 163s Front R/L $278
1xPrimus 251 CC $200 or 351 for $275
2xPrimus 143s Rear R/L $200
Total $678 or $753 + shipping.
I would recommend the 3-way 351 CC over the 251
www.harmanaudio.com
Eastern Shore Audio Collective-E.S.A.C. Member, www.esac.club
postrokfan is offline
post #6 of 9 Old 06-04-2011, 07:35 PM
jjl4004's Avatar
I've got both the cb-5's and cc-10. They are nice, but if your budget for a 5.0 is $700, you could do better. You can get 2 cb-5's for $100 on Amazon right now (they can be had for around $80 on sale) and you can find the cc-10 for $200 or less if you catch them on sale. That puts you at $400. It's a good set up, but if you want to stay with Energy and upgraded your fronts to cb-10's or cb-20's, it would most likely sound better...but they are larger bookshelfs. I haven't heard either the 10's or 20's, but I assume they sound better than the cb-5's and would still match your cc-10.
jjl4004 is offline
post #7 of 9 Old 06-04-2011, 08:13 PM
MikeBiker's Avatar
Quoted: 14 Post(s)
I suggest that you start with a 3.0 system and add a sub before the surrounds. Surrounds are nice for sound effects but contribute little to most material. The sub would add enjoyment to all material.
MikeBiker is offline
post #8 of 9 Old 06-04-2011, 08:23 PM
ack_bk's Avatar
Quoted: 613 Post(s)
Liked: 695
Definitely agree. You could even go 2.1 and use the left and right as a phantom center and get a nice sub.
HSU has their HB-1 MK2 speakers on sale for $129 and the STF-2 sub for $329. With shipping this will be within your $700 budget and you can add the center and surrounds as you can.
The Ascend speakers mentioned above are a wise choice as well.
Another option is the SVS-SCS02 speakers on sale:
http://svsound.com/products-spks-scs01.cfm
Your three main speakers for $448+shipping and you can add the SBS-02 surrounds and easily be within your $700 budget shipped for a 5.0 setup. But you will definitely need a good dedicated subwoofer no matter the setup.
ack_bk is offline
post #9 of 9 Old 06-04-2011, 11:28 PM
sholling's Avatar
1xCBM-170C Center
+1, this would be an outstanding setup except that they no longer sell the 170C unless you can get Dave to sell a single 170 as a center and it's worth asking. But they for sure need the help of a sub.
Another big +1. If it were me I'd go with P163/PC251/P153 instead to in order to get the surround's crossover point down to 80hz.
In either case I'd start with 2.1 or 3.1 and add the surrounds later. 2.1 will be a heck of a lot more enjoyable than 5.0.
sholling is offline
Reply Speakers
