Cambridge Audio Minx Satellite Speakers and Home Theater Systems Discussion Thread - Page 68 - AVS | Home Theater Discussions And Reviews
 1Likes
post #2011 of 2019 Old 02-05-2015, 02:33 PM
Bazzy's Avatar
Liked: 30
Originally Posted by Mark McIntosh View Post
I have 5 minx 20 speakers and a Mirage sub. I just got a new Onkyo AVR to replace an old Denon that died. This receiver does not allow the sub's crossover setting to be set by the receiver, so what should I set the crossover to on my Mirage 8" sub? Audyssey set the crossover of the speakers at 150 - does that sound about right? Thanks for the help!
Hi,
May I ask, what is the model no: of the new Onkyo AVR that you have? I ask, as being a new/newer model, I am a little surprised that it does not offer you the option of of setting the sub's crossover on it, especially since it seems to have Audyssey? Maybe others more in the know can chime in in this!
I would set the X/O at the back on the sub at 150 as Audyssey suggests - it seems about right although if the Mirage sub settings go higher, play around between 150 & possibly a little higher if need be.
Bazzy,
Bazzy is online now
post #2012 of 2019 Old 02-05-2015, 04:49 PM
Mark McIntosh's Avatar
It is an Onkyo TX-NR616. It came out in mid 2012 so it is a little older. This is kind of an in-betweener purchase. I wanted to get a receiver that is full 4k ready, like a Denon X4100 but can't justify the cost when there isn't much if anything using this, and I don't have a 4k TV yet. So, I found this one on a closeout and I had been wanting to try an Onkyo, so this receiver fell in my lap. I have to say it's a pretty big step up from the Denon 988 I had in terms of sound and picture quality. Pretty happy with it so far.
Mark McIntosh is online now
post #2013 of 2019 Old 02-15-2015, 04:21 PM - Thread Starter
Perpendicular's Avatar
Quoted: 29 Post(s)
Liked: 38
Huh?! What did I miss? By the look of things, nothing.
OPPO BETA GROUP
Perpendicular is offline
post #2014 of 2019 Unread Today, 12:37 AM
davidahn's Avatar
Onkyo TX-NR616 Crossover Frequency
AVRs have had adjustable crossover frequencies since the 1990s, maybe earlier.
Here's an excerpt from the manual, page En-34: "With the supplied calibrated microphone, Audyssey 2EQ® automatically determines the number of speakers connected, their size for purposes of bass management, optimum crossover frequencies to the subwoofer (if present), and distances from the primary listening position. Audyssey 2EQ then removes the distortion caused by room acoustics by capturing room acoustical problems over the listening area in both the frequency and time domain." If you don't want to do the Audyssey setup, you should be able to set the speaker setup (page En-54), set subwoofer to Yes, and speaker crossover from "full" to 120 or 150 Hz.
davidahn is offline
post #2015 of 2019 Unread Today, 01:41 AM
davidahn's Avatar
The Minx Min 21's (similar to your 20s, though slightly better at the low end) volume drops precipitously below 200 Hz, and by 100 Hz it's down about 12 dB, which is a little less than half the volume, but definitely audible. The smoothest transition would be at 200Hz, but that's not ideal: most subs do poorly that high and the sub's location would be very obvious. A better balanced crossover frequency to 100 or 120 Hz, preferably 100 because at 120 Hz you can localize the subwoofer.
Experts, correct me if I'm wrong but IMO, the combination of the speaker's natural dropoff and the crossover's cut would create a sheer dropoff in the speakers' volume below the crossover frequency, so when I get my Min 11s, I'm planning on setting the speakers to "full" to preserve what bass the speakers produce, and simply set the subwoofer's crossover to 100 or 120. Will I have a valley between 100 and 150? Probably. I'll play with it when I get them.
davidahn is offline
post #2016 of 2019 Unread Today, 07:37 AM
Thanks for that great information! I did run Audyssey and am using those settings. So if Audyssey set the speaker crossover at 150 am I right to set the crossover on the back of the sub to 150 or do I disable the crossover on the sub?
post #2017 of 2019 Unread Today, 03:18 PM
ien2's Avatar
Quoted: 16 Post(s)
Liked: 52
Disable the crossover on the sub if you are using bass management on the AVR.
The F3 of the Min21(20) is actually ~120Hz, the Min11(10) is probably closer to 150Hz. Don't have the speakers set to large/full, you'll probably end up damaging them at moderately high levels, keep them as small.
If Audyssey likes the 150Hz setting I'd say go with it. Mine's set to 120 but I'm getting a bit of a boost from the room, Audyssey for me says 100.
David, it's better to have localization than to have a valley right in the 100's, if you sub can do 150 then you should let it.
ien2 is online now
post #2018 of 2019 Unread Today, 05:08 PM
You guys are so much help and I'm sorry to be dense. So if I ran Audyssey and I'm using the 150 crossover there, does that mean i'm letting the receiver manage the crossover and I should disable the crossover on the sub? I think that's what you're saying but I need it spelled out. Thank you!
post #2019 of 2019 Unread Today, 06:27 PM
ien2's Avatar
Quoted: 16 Post(s)
Liked: 52
Yes, the AVR will handle the sub too so there's no need for the sub to use it's own.
I think I may have misspoke before, now that I think on more I believe CA uses -6dB instead of -3dB for their frequency response...or at least they have on some stuff. I know I've seen 120Hz as the f3 other places for the 20/21 but that may not be correct. Even so, the f3 won't be that much higher.
ien2 is online now
Reply Speakers
Cambridge Audio , Cambridge Audio Minx Min 11 Speaker , Subwoofers , Cambridge Audio Minx Min 10 Satellite Speaker Black Each
