Cambridge Audio Minx Satellite Speakers and Home Theater Systems Discussion Thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 53Likes
post #181 of 2677 Old 11-15-2011, 03:15 PM
JimWilson's Avatar
Quoted: 1559 Post(s)
Liked: 2083
Originally Posted by LPCorriveau View Post
If we're talking about the 2 subs setup, I was wondering if 2 x200 would sound better than one x300. Do I need 2 x300? What about one x200 and one x300. So one sub for the lower frequencies and one to fill the gap with the Mins?
Frankly, I wouldn't consider the x200 at all. It only has a 6.5" driver, and even though it has a passive radiator that's simply not going to cut it. Not for HT, anyway.
You said your room is 16x17, but didn't mention the ceiling height. That's critical when deciding on a subwoofer, because it's the total cubic volume of space that comes into play. Just one foot difference -- say 8 feet vs 9 feet high -- makes a volume difference of about 12%. That's significant. How high are the ceilings?
In general, dual subs are better than a single one. That configuration is more capable of mitigating "room modes", which are a whole other topic. Suffice it to say, it's not something you want. That being said... when running duals you need to consider the quality of what you buy very carefully. Depending upon the circumstances (budget mostly), it might actually be better to get a single good sub than 2 mediocre ones.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
post #182 of 2677 Old 11-15-2011, 03:19 PM
JimWilson's Avatar
Liked: 2083
With 2 sub is it essential to go with a 7.2 AVR or 7.1 with "y" cable is ok
No, 7.2 is not necessary - a Y cable works just fine.
post #183 of 2677 Old 11-15-2011, 10:40 PM - Thread Starter
Quoted: 219 Post(s)
Liked: 105
I think I will have to try the min 20 and min10 setup to see what I like more...
You mean you're ordering both a pair of 20's and 10's to try out?
Or, a whole surround system of each model?
I'm with Jim. Stick with, at least, a X300 or X500 model. If you go double, do two X300's. I went with two Mirage MM-8's just to save some money (half the cost of one X300. I see no reason why you couldn't do the same. Unless, of course, you have the funds burning a hole in your pocket. Oh, the Minx Subs allow daisy chaining so you can stick with one LFE (Sub out) output on your AVR.
Either way is fine. I use neither. Well, sort of a "Y" cable. It's an adapter (no wires) that's essentially one male to two female connections.
Perpendicular is offline
post #184 of 2677 Old 11-16-2011, 05:50 AM
LPCorriveau's Avatar
I'll try to demo them first at the dealer... To keep thing simple, I'll probably go with either S315 or S325. Since I never owned any HT system, I guess it will be quite an improvement over the sound of my TV!! I'm not short of money but I have to buy a flat-screan tv, some furniture and pay for renovation, so I have to cut somewhere!
The problem with another brand of sub is that I don't have any idea what is a good price or what is overprice for what I get. Being in Canada, availability is also a problem. Price are higher cause there less competition... With Cambridge at least, I know I get a good one...
I'll probably go with Denon 2112ci even if I'm not 100% sure between 2112 ad 2312...
Jim, my ceiling is 7'9"
Thanks you all for those precious informations!
LPCorriveau is offline
post #185 of 2677 Old 11-16-2011, 09:07 AM - Thread Starter
Quoted: 219 Post(s)
Liked: 105
Please, let us know how the demo goes. I'd be curious if you could listen to separate systems with both Min 10 & 20. I've been talking to a Dealer out in AZ who's listened to both, and can't seem yet able to describe to me what he heard, which has been frustrating. I would say, the heck with it, and purchase a set of Min 20's to compare. Only trouble is, the speakers are not returnable. The closest dealer to me is in the Northern part of California (Bay Area) and I don't intend to drive that far. I have no clue why I live in the second largest city in the United States and they don't have any Cambridge Audio Minx dealers here. The American distributor for Cambridge Audio is up in Canada. This may explain why you have a dealer and I don't. It boggles my mind who is in charge over at Cambridge Audio in England when it comes to this discrepancy. I mean, I'd really like to hear these on Demo.
post #186 of 2677 Old 11-16-2011, 10:19 AM
Well, after a quick research, I have 3 dealers in Quebec City and surrouding area (10-15 min drive). If I'm willing to do a 2.5 hour drive, I have 20!!! As for price, listed price on one web site is 1499can$ for S325. Maybe I can get that down a bit...
post #187 of 2677 Old 11-16-2011, 04:54 PM
yellolab's Avatar
Shou
D Santa bring me pair of the 10s for Xmas......they wou
D be for front height speakers adding to 5.1 system used just for movies
Kevin
yellolab is offline
post #188 of 2677 Old 11-17-2011, 03:02 PM
andy782's Avatar
Thanks for a great thread.
I'm looking at getting the minx 215 or 315 for my living room (13' x 11' x 11'ceilings). I'd be using them 80% for music, 20% movies.
Just about everything I read says "they're good for their size" or "good compared to Bose".
As owners, how compromised do you feel? Especially with music. Do you feel like you're getting about a 7 or 8/10 for music? (I'm worried the sound will be a bit thin)
And with a room my size, would I get away with the x200? Does the x300 blend better with the speakers? or just push more air?
andy782 is offline
post #189 of 2677 Old 11-17-2011, 11:42 PM - Thread Starter
Quoted: 219 Post(s)
Liked: 105
That's a small room. Call me Einstein.
For the record, they are way better than any Bose system.
Personally, I don't feel compromised at all, and I'm about 75% music. I just get the upgrade itch and think I'd get better sound by upgrading to the bigger Min 20's. Yesterday, my testing proved that the Min 10 does suffice, even for the center channel in my living room. Somewhere within this Thread, I think I mentioned that these are the best satellite speakers I've either owned or demoed. So, no, for me, they don't sound thin at all. Unless you remove the Subwoofer.
I don't have any experience with the smaller X200 Sub but feel that it would be plenty for your size room. If you think you'll ever move your system into a bigger room, I would go for the bigger X300.
post #190 of 2677 Old 11-18-2011, 06:00 AM
Elihawk's Avatar
Quoted: 1339 Post(s)
Liked: 1169
So there are some folks who own the minx system? Was wondering about the BMR drivers in those speakers, the CA advertising seems to be a bit like Bose in its claims "Full range sound from a small driver"...
Sorry, I didn't read every post in this thread...can someone give me a pretty good review of the minx system(s)? Range, volume, music vs HT, on vs off axis, etc. Thanks
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #191 of 2677 Old 11-18-2011, 06:08 AM
Mark McIntosh's Avatar
Quoted: 46 Post(s)
Hey Elihawk. Welcome to the thread. If you go to page 1 of this thread and read the first two or three posts you'll get an extensive review by Perpendicular and links to all the "professional" reviews he's run across. I don't think any of us can come close to the review he's already done. I love mine!!
Mark McIntosh is offline
post #192 of 2677 Old 11-18-2011, 06:16 AM
Elihawk's Avatar
Liked: 1169
yea, just quit being lazy and read the first page of this thread...excellent review!
Elihawk is offline
post #193 of 2677 Old 11-18-2011, 06:20 AM
Quoted: 46 Post(s)
Sorry, maybe you misunderstood me. I thought I was helping to point you in the direction of an excellent, detailed, time-consuming review by someone who seems to be the most knowledgeable contributor in this thread. Any review I could offer would not come close to the one that's already been done. I apologize for the confusion and wish you well in your search.
post #194 of 2677 Old 11-18-2011, 06:46 AM
Elihawk's Avatar
Liked: 1169
Mark...sorry...that came out wrong...I meant I quit being lazy and looked at the first page of the thread. good information there!
Elihawk is offline
post #195 of 2677 Old 11-18-2011, 06:57 AM
Quoted: 46 Post(s)
Oh man that's too funny!! This is what I try to tell my kids about chatting and IM, and here I do the same thing!! Thanks for setting me straight.
post #196 of 2677 Old 11-18-2011, 08:11 AM - Thread Starter
Quoted: 219 Post(s)
Liked: 105
I just ordered another pair of Min 10's off of Amazon that should be here tomorrow to go from my current 3.2 to 5.2 speaker system.
post #197 of 2677 Old 11-18-2011, 08:31 AM - Thread Starter
Quoted: 219 Post(s)
Liked: 105
Please, do not use the name "Bose" in this Thread. Oops, I just did.
If you plan to listen "Off-Axis" (not in the sweet spot 100% of the time), these speakers are meant for you.
I'm glad to hear that you found some use from the first Post of this Thread. Welcome, and let us know if you have any further questions!
post #198 of 2677 Old 11-18-2011, 10:48 AM
JimWilson's Avatar
Liked: 2083
Gee, now there's a surprise...
post #199 of 2677 Old 11-18-2011, 11:23 AM - Thread Starter
Quoted: 219 Post(s)
Liked: 105
No, I have another one. I just cancelled my order for the two Min 10's and re-ordered one 10 and one 20.
So much for talking myself out of thinking I wanted a Min 20. Next month, I will purchase two more Min 20's for the front three.
post #200 of 2677 Old 11-18-2011, 12:06 PM
JimWilson's Avatar
Liked: 2083
OK, now that's the Jeff I know; never made a decision that didn't require deciding if it was the right decision...
I'd bet money the 1.5 design will turn out fine. My guess is you'll be smiling big time when you have it setup that way.
post #201 of 2677 Old 11-18-2011, 12:23 PM
Quoted: 40 Post(s)
just wondering if any previous users of orb had any opportunity to use orb super 8 with the minx speakers?
rsmt2000 is offline
post #202 of 2677 Old 11-18-2011, 12:47 PM - Thread Starter
Quoted: 219 Post(s)
Liked: 105
I have zero experience with a Super 8 but would say you can use it only if there's a Subwoofer upgrade in mind in your future. One really needs the right Sub (DSP controlled) to mesh with the Mins properly.
post #203 of 2677 Old 11-18-2011, 01:48 PM
markiedee's Avatar
Liked: 24
Congrats perpendicular on purchasing a min20 there is a significant difference between the min10 and 20, the shop where i demoed mine had both the min10s and min20s and you could switch between the two, to compare. The min20 had a little more volume in comparison to the min10s.
The good folks at cambridge audio sent me my horizontal speaker grille the other day in the post, all i need to do now is pick up another min20 for center duties and a table top stand to make my setup 3.1.
markiedee is offline
post #204 of 2677 Old 11-18-2011, 09:33 PM
taichi4's Avatar
Quoted: 356 Post(s)
Liked: 170
To echo an earlier poster, it is frustrating that there is nowhere to demo the Minx in Southern California.
taichi4 is offline
post #205 of 2677 Old 11-18-2011, 10:00 PM
Elihawk's Avatar
Liked: 1169
With the concern over MtM arrangement of conventional center channel speakers in the horizontal configuration...how does that change with the minx center channel? Since there is not midrange-tweeter-midrange configuration, does that center channel have the same off axis issues as the usual horizontal center channel?
Elihawk is offline
post #206 of 2677 Old 11-18-2011, 10:27 PM - Thread Starter
Quoted: 219 Post(s)
Liked: 105
That be me.
It doesn't count. You need midrange-tweeter-midrange drivers in order to have the off-axis issue. The Min 20 has two of the same drivers while one out of the two rolls off the upper frequencies via a resistor.
post #207 of 2677 Old 11-18-2011, 10:37 PM - Thread Starter
Quoted: 219 Post(s)
Liked: 105
A little while ago, I starting thinking that maybe I should have just added three Min 20's now instead of getting just the one. Even though they won't be fully broken-in, I plan on comparing both the new 10 & 20 with some Mono material when they arrive tomorrow.
I don't understand why this isn't an option at purchase. Or, they could throw in two grills for the price they charge for the 20 over the 10. Heck, I'd settle for no emblem on the grill. I'd be surprised if you didn't pay extra for your horizontal grill.
post #208 of 2677 Old 11-19-2011, 10:38 AM
taichi4's Avatar
Quoted: 356 Post(s)
Liked: 170
It was good of you to take the plunge, on faith, and get the Minxes, sight unseen (or hearing unheard). There should be a demo of these somewhere in Los Angeles or San Diego... ridiculous. There is a putative Cambridge Audio dealer in Long Beach, I seem to recall, but he didn't have them, hadn't heard them, and wasn't enthusiastic about selling them... all the more surprising since he hadn't heard them! You have to taste the pudding!
The interesting thing about these speakers, which you discovered early on, is that they need a break in period. Many good things have break in periods, including musical instruments, and no one would drive a good engine flat out in the first thousands of miles. Yet these speakers are reviewed right out-of-the-box, 90% of the time, and they still do very well. But it's the wrong time to do the review.
I definitely want to hear them, and they intrigue me conceptually.
taichi4 is offline
post #209 of 2677 Old 11-19-2011, 02:01 PM - Thread Starter
Quoted: 219 Post(s)
Liked: 105
The closest dealer to us is in the Bay Area. This is what the Dealer Locator states on the Audio Plus Service (North American Dist.) Website. Though, it makes one wonder if they even have any on Demo.
Personally, I feel the best thorough review of a Minx system (Min 20 + S300) is the AV Guide one. It's the closest one that defines what I'm hearing. Actually, the three listed below by Chris Martens are the most comprehensive I've yet seen on the Minx.
http://www.avguide.com/article/cambr...he-minx?page=1
http://www.avguide.com/blog/radical-...fferent-better
http://www.avguide.com/review/cambri...system-tpv-102
On another note: I received my extra Min 10 & 20 today. I was reluctant to add the Min 20 based on looks alone because, by the photos, I felt the Min 10 was the better looking of the two. Now that I've seen the Min 20 up close, it's strikingly handsome and looks better than the Min 10. I'm definitely adding the other two Min 20's to the front stage soon. I'm off now to compare both speakers and will Post soon.
post #210 of 2677 Old 11-19-2011, 02:21 PM
taichi4's Avatar
Quoted: 356 Post(s)
Liked: 170
...On another note: I received my extra Min 10 & 20 today. I was reluctant to add the Min 20 based on looks alone because, by the photos, I felt the Min 10 was the better looking of the two. Now that I've seen the Min 20 up close, it's strikingly handsome and looks better than the Min 10. I'm definitely adding the other two Min 20's to the front stage soon. I'm off now to compare both speakers and will Post soon.
I'll be very interested in what you think, as I am attracted to the 325s setup.
taichi4 is offline
Reply Speakers
Cambridge Audio , Cambridge Audio Minx Min 10 Satellite Speaker Black Each , Cambridge Audio Minx Min 11 Speaker , cambridge audio minx min 21 , cambridge audio minx min 22 , Subwoofers
