Cambridge Audio Minx Satellite Speakers and Home Theater Systems Discussion Thread - Page 86 - AVS Forum | Home Theater Discussions And Reviews
 51Likes
post #2551 of 2563 Old 01-17-2016, 10:28 AM - Thread Starter
Perpendicular's Avatar
Quoted: 124 Post(s)
Liked: 46
If it were me (I'm particular), having heard the difference between the Min 21/22, I would install 22's all around because I use my speakers for surround music too. Otherwise and overall, the two models blend well together. Either/or, you could go either way and the system will sound great.
Perpendicular is offline
post #2552 of 2563 Old 01-17-2016, 10:51 AM
Liked: 1
Very nice! Thank you for the advice! I just purchased the Pioneer Elite VSX-45, so I am excited to get started on finally having a home theater setup. I will be pairing the Minx speakers with an old Energy e:XL-S12 subwoofer.
rxgrad09 is offline
post #2553 of 2563 Old 01-17-2016, 11:30 AM - Thread Starter
Quoted: 124 Post(s)
Liked: 46
I can't seem to locate the specs on your Energy Subwoofer. If it can't play up to 150 Hz, you will be creating a gap (hole) in the frequency response. If you still have it, I'd suggest a look in your manual to be sure.
post #2554 of 2563 Old 01-17-2016, 11:35 AM - Thread Starter
Quoted: 124 Post(s)
Liked: 46
I forgot to add that since you will be using a higher crossover setting on your Subwoofer (this is assuming it will play out to 150 Hz), it is a must that you keep it very close to the front three speakers.
post #2555 of 2563 Old 01-17-2016, 11:59 AM
Liked: 1
Thanks, I am a newbie so really appreciate the advice. Based on the manual for the Energy e:XL-S12:
VARIABLE LOW PASS FILTER: 50Hz - 100Hz
INPUT SENSITIVITY:
High Level 250mV
Low Level <100mV - 6V
External Crossover <100mV - 6V
rxgrad09 is offline
post #2556 of 2563 Old 01-17-2016, 12:14 PM - Thread Starter
Quoted: 124 Post(s)
Liked: 46
I'm afraid that subwoofer will not blend properly since it's frequency response is 20-100 Hz.
post #2557 of 2563 Old 01-17-2016, 04:36 PM
GusGus748s's Avatar
Quoted: 336 Post(s)
Liked: 667
Originally Posted by rxgrad09 View Post
Hello,
Hoping I can advice from anyone experienced with the Cambridge Minx Min 21 & 22 satellite speakers. A friend had given me two very good condition Cambridge Minx Min 21 and I would like to set up a 5.1 home theater system. Would it be much better to build my 5.1 setup with all five Cambridge Minx Min 22 satellite speakers? Or can I add three Cambridge Minx Min 22 and the two Cambridge Minx Min 21 speakers? Thanks for your help and advice!
Yes you can use 21 and 22 together. You won't really noticed a difference. However, the 3 front speakers should match so either all 22s or 21s for fronts.
GusGus748s is offline
post #2558 of 2563 Old 01-17-2016, 06:08 PM
Liked: 1
Ahh bummer! I will have to upgrade the subwoofer eventually Thanks.
rxgrad09 is offline
post #2559 of 2563 Old 01-17-2016, 06:10 PM
Liked: 1
Very nice! Thank you. I am planning to have the 22s for the fronts and center and 21s for the rears.
Perpendicular likes this.
rxgrad09 is offline
post #2560 of 2563 Old 01-17-2016, 06:26 PM - Thread Starter
Quoted: 124 Post(s)
Liked: 46
Good choice.
post #2561 of 2563 Old 01-17-2016, 09:47 PM
steveting99's Avatar
Quoted: 1440 Post(s)
Liked: 470
INPUT SENSITIVITY:
High Level 250mV
Agree with Perpendicular on this, the -3dB point for the e:XL-S12 is at 100Hz. So you'll have to look for a better sub to match with the Min22/21.
You might also want to consider a pair of identical subs as it will allow a much higher crossover frequency, smooth out the peaks and null, increase the sweet spot and provide a bit more headroom.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, WDTV Live, Harmony 650 + Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
post #2562 of 2563 Old 01-19-2016, 06:27 PM
Liked: 1
Thanks for all the advices! I wil look into getting the Cambridge X301 subwoofer.
rxgrad09 is offline
post #2563 of 2563 Old 01-19-2016, 07:21 PM
Liked: 470
Most at AVS will recommend one of the Internet Direct (ID) sub companies as the value proposition is far more appealing. The Cambridge X301 sub is not bad, but for the same amount of money one can do much better with one of the ID companies listed below.
(1) Rythmik Audio;
(2) SVS;
(3) HSU;
(4) PSA; and
(5) Reaction Audio.
Lots options and one is spoiled for choose from the ID companies. All offer in home trial period. This is the better than the retail shops where returning a product because one didn't like can be a hassle.
Reply Speakers
Cambridge Audio , Cambridge Audio Minx Min 10 Satellite Speaker Black Each , Cambridge Audio Minx Min 11 Speaker , cambridge audio minx min 21 , cambridge audio minx min 22 , Subwoofers
