7.1 with AVR for $600-700? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 06-05-2011, 11:43 PM - Thread Starter
jonLavs's Avatar
I know this is crazy and I'm trying to help a friend out. Is it possible to buy a 7.1 speaker set plus an AVR for $600-700? I'm trying to see if you can do better than the Onkyo HTIB that sells for $600 on Amazon. What do you guys think?
jonLavs is offline
post #2 of 25 Old 06-05-2011, 11:52 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3093
I wouldn't necessarily go with HTIB. Spend on speakers and get a cheap AVR for now. You could start with 3.1 or 2.1 and expand later. However, I guess you could opt for one of the Jamo home theater speaker packages and a Denon 1612. That should be within your budget. From what I understand, Jamo offers pretty decent sound quality on a budget.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #3 of 25 Old 06-06-2011, 08:22 AM - Thread Starter
jonLavs's Avatar
Unfortunately my friend does not want to do less speakers now and spend more later. It's kinda all or nothing. Would you say Jamo is better than a HTIB?
jonLavs is offline
post #4 of 25 Old 06-06-2011, 08:53 AM
Smigro's Avatar
Quoted: 208 Post(s)
Liked: 220
This could be a good option. I have not heard this, but this seems like a fair price for a THX certified setup. Mind it is factory refurb, but I have had my Onkyo for about six months from this site and have no problems so far.
http://www.accessories4less.com/make...Package/1.html
Xbox GT / PSN ID - Smigro
my blu ray collection - http://www.blu-ray.com/community/col...0&categoryid=7
Smigro is online now
post #5 of 25 Old 06-06-2011, 08:55 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Well a 5.1 set is possible in that budget but 7.1 is a tall order and in fact it's rare that his room can support 7.1 setup.... Most movies are still 5.1 to...
What are the specifics of this guys room?(LxWxH) Does he consider himself an audiophile?
$700 on receiver wont get you much.
Denon avr-591(last years model)
Polk monitor 30's two pairs
Polk CS1 center
Polk psw10 subwoofer
Or the Jamo s606 hcs3 5.0 speaker set from vanns.com with the denon avr-591 he can add a subwoofer later if he chooses
crazyrob425 is offline
post #6 of 25 Old 06-06-2011, 09:07 AM
schan1269's Avatar
With that much budget I'd hit the used market...
http://cgi.ebay.com/Onkyo-TX-SR607-H...item19c61551ad (there is one with an opening bid of $219, if this guys reserve is anything over $225, he's not going to sell it. I personally would never pay more than $200)
If we knew where you were, we could give you some CL advise...
Some gems in my area...
http://chicago.craigslist.org/wcl/ele/2422386703.html
http://chicago.craigslist.org/chc/ele/2422291933.html
http://chicago.craigslist.org/wcl/ele/2422153395.html
There is also a used receiver with the Jamo A340PDD.5(under $250 last I checked) and add another pair of Jamo to make 7.1...
http://cgi.ebay.com/Jamo-660CS-Main-...item2a11278024
schan1269 is offline
post #7 of 25 Old 06-06-2011, 09:15 AM
josh6113's Avatar
Quoted: 16 Post(s)
Liked: 25
I think you nailed it with that system....he should be happy with that...:-) I was searching myself and with his budget that would be the best option
Doing what I do best...LIVIN!
josh6113 is offline
post #8 of 25 Old 06-06-2011, 09:21 AM
aidoroboo's Avatar
Personally, I would go with 5.1. You can spend more on SL/SR speakers taking out SBL/SBR channels. I know some BDs have 7.1 listed but this is usually 5.1 mixed to 7.1 having the SBL/SBR channels the same as SL/SR.
aidoroboo is offline
post #9 of 25 Old 06-06-2011, 09:27 AM
afrogt's Avatar
Quoted: 1054 Post(s)
Liked: 756
does your friend have his room properly setup for 7.1? If his couch is on the back wall you can't implement 7.1 properly. better off to go with a 5.1 setup.
Either way I'd recommend a seperate receiver and then a 5.1 speaker system from someone other than Onkyo. Onkyo speakers have never impressed me.
Afro GT
afrogt is offline
post #10 of 25 Old 06-06-2011, 10:53 AM
Smigro's Avatar
Quoted: 208 Post(s)
Liked: 220
That is a good point as I am pretty sure not everyone understands how 7.1 should actually be set up. I really do not have much experience with Onkyo speakers, but if this is for a beginner I thought I would throw that Onkyo THX system at him.
post #11 of 25 Old 06-06-2011, 12:18 PM
wizard8873's Avatar
It's going to be pretty hard to go with this unless it's HTIB. If he doesn't want HTIB and can save up a bit more, best to look at used or older models. If he can go up to 800, he can get:
Onkyo TX-SR608 - http://www.amazon.com/Onkyo-TX-SR508...7383376&sr=8-6
Polk Audio CS1 - http://www.newegg.com/Product/Produc...-210-_-Product
2 x Polk Audio Monitor 30 sets - http://www.newegg.com/Product/Produc...-200-_-Product
2 x Polk Audio Monitor 50 floorstanding - http://www.newegg.com/Product/Produc...-204-_-Product
And then a BIC America f12 sub for another $260 http://www.amazon.com/BIC-America-F1...7383618&sr=1-2
it would come out to about $1,070 but would be worth it.
Otherwise, the system smigro posted would be the best bet for that price range
Because great sound fills the room, shakes the house, breaks hearts, stirs souls, and always will
wizard8873 is offline
post #12 of 25 Old 06-06-2011, 09:56 PM - Thread Starter
jonLavs's Avatar
So first off my friend is a she and no she is not an audiophile but I am and I'm trying very hard to get her to spend more on the HT but the sound system isn't her priority. That's why her budget is so low. She has already eyed the Onkyo 7300 series HTIB for $600 on Amazon but I was hoping I could get her a better sounding setup than a HTIB. I think for the sub I'd want to go with the $150 Bic as it sounds like a good price vs performance. Btw I don't know the exact size of her room but back of the living room opens to the kitchen and the left opens to the dining room with half walls. If I were to guess it would be at least 23' x 16' only adding the dining room and living room. And the ceiling is probably 9'. As far as hook ups for speakers, it's a new house and I helped her plan the wiring so she has 8 wall hook ups all around the walls for 7.1.
Thanks for all the responses so far. I knew this was going to be very tough but wanted to ask the community what they thought. She definitely will not want to buy used so that's out if the question. I will take a look at all the links you've provided.
jonLavs is offline
post #13 of 25 Old 06-07-2011, 07:14 AM
Robert2011's Avatar
Here's what I did, and I've been very happy with the results:
Denon AVR-1911 $380
Micca M-8S in-wall speakers R/C/L @ $40ea $120
Micca M-6S in-wall speakers S/R @30 ea $120
Bic V-1220 12" sub @$180
As you can see with fairly cheap (Miccas are Polk knock offs) components it still came to $800 and I had to build soffits for the Surrounds and rear channels. HTIB may be a better solution for your friend. Why try to push something on her, because you think she should do better? I'd say she'd be very happy with the Onkyo 7300 series. She could do a lot worse.
Budget Home Theater:
Denon AVR-1911 Receiver, Bic V-1220 Subwoofer, Fronts Pioneer SP-FS52, Center Pioneer SP-C22, Surrounds Micca MB42X, Epson 8350 Projector, Home-made ~90" 16:9 Screen, Berkline 13175
Robert2011 is offline
post #14 of 25 Old 06-07-2011, 10:46 AM
schan1269's Avatar
Well, "we" didn't know she was of the fairer sex when this started...
Anyway...
If used is out of the question, and 7.1 is a must, HTiB is about all there is. Between Yamaha and Onkyo there is one that will fit the budget.
Even this option almost busts the budget...
http://www.amazon.com/Sony-STRDH820-...7464921&sr=1-1 (have not played with a Sony receiver in ages, have no idea how good it is)
http://www.amazon.com/Sony-SS-B1000-...7464993&sr=1-1 (these actually get decent reviews...get 3 pairs)
or get one of the bigger ones for the front and 2 pairs of the 1000
http://www.amazon.com/Sony-SS-B3000-...7464993&sr=1-2 (or)
http://www.amazon.com/Sony-SSF-5000-...7464993&sr=1-6
with
http://www.amazon.com/Sony-SS-CN5000...d_bxgy_e_img_b
and
http://www.amazon.com/BIC-V1020-Down...7465134&sr=1-1 (or its 12" brother)
Tally is about $660 with the V1020 and 3 pairs of B1000.
I would have no qualms with that set-up for a $600 budget. It would embarrass the Onkyo 63/7300
Even if you were to pick a Denon/Yamaha/Onkyo 7.1 receiver...I would still take those Sony speakers over a HTiB.
post #15 of 25 Old 06-07-2011, 04:39 PM - Thread Starter
jonLavs's Avatar
Anyway...
with
and
Sorry, I didn't mean to sound bad with my statement. After I re-read it, it sounded wrong. Just meant to say it's a she and she had different priorities.
I liked the Polk Audio setup and while it was more, I'm trying to talk her into it. How do those Polks sound? I haven't heard them so I don't know.
jonLavs is offline
post #16 of 25 Old 06-07-2011, 05:33 PM
Macstatic's Avatar
I have a Pioneer VSX-920-K and am very satisfied. It's a 7.1 receiver with over 100 watts RMS per channel and it's very affordable. I got mine for $225. After that all you'd need is speakers and you'd have a much bigger sum to work with if you get a cheap but decent receiver, especially if she's not THAT big into speakers
But if there is a strict budget, I'd stick with Smigro's comment and get that Onkyo set. Onkyo doesn't really specialize in speakers as much as receivers, but your friend would still notice a huge difference having a full 7.1 system after apparently not having anything significant in the sound department
For those looking into getting Energy speakers, or upgrading their current Energy setup, here are some reviews I've written that may help:http://www.tempestaudio.blogspot.com  (haven't updated in a while, but include Energy Take Classic 5.1, RC-10, CF-70, and CC-10)
Macstatic is offline
post #17 of 25 Old 06-08-2011, 09:56 AM - Thread Starter
jonLavs's Avatar
Ok, thanks for the input. I'll look into that.
jonLavs is offline
post #18 of 25 Old 06-08-2011, 10:58 AM
schan1269's Avatar
Read this thread...
http://www.avsforum.com/avs-vb/showthread.php?t=1339236
Granted my budget is a LOT higher, the principle remains the same. There is no "wrong" choice in speakers. There is what you like, and the price you are willing to pay.
That is why I suggested the Sony speakers to begin with. They are inexpensive, but they are NOT cheap. At the "low end" of speaker prices you have pretty much three choices(unless you want to go the parts express DIY route)...
Sony SS series.
Polk Monitor(Monitor II is a Newegg exclusive of unknown time frame, could be this year, could be for the next decade) while they are on closeout.
BIC DV series.
After those three, the prices go up in a hurry.
post #19 of 25 Old 06-08-2011, 11:32 AM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
This is just one thought:
Four sets of Energy CB-5's the next time they go on sale. Three sets for the front, and the two sets of surrounds speakers, plus one of the remaining pair for a center.
BIC F-12 Sub.
Refurbed Onkyo 508. The Fourth of July is right around the corner, so ShopOnkyo should have a sale on all their refurbed products.
That is under $700.
bladerunner6 is offline
post #20 of 25 Old 06-08-2011, 12:56 PM - Thread Starter
jonLavs's Avatar
BIC F-12 Sub.
That is under $700.
That's a good suggestion. Thanks.
jonLavs is offline
post #21 of 25 Old 06-08-2011, 01:00 PM - Thread Starter
jonLavs's Avatar
Read this thread...
Sony SS series.
BIC DV series.
How do the Sony speakers stack up? My impression of Sony speakers aren't very high. I do have some cheap (in price) Sony bookshelves I bought a long time ago that I use for my 2nd TV and I'm not really impressed with them. However, I think my tastes are elevated as I've been spoiled with my main HT. I know this $600-700 budget is not much at all, but I was trying to see what people would buy in this range other than HTIBs. But if you guys are saying that the only way to get 7.1 is with HTIB for the price range my friend is looking to spend, then maybe that's just how it is. I was hoping some ID company would be able to best a HTIB for a great price like some of the ID subwoofer companies do.
jonLavs is offline
post #22 of 25 Old 06-08-2011, 02:22 PM
Quoted: 443 Post(s)
Liked: 337
For party music speakers Sony's SS current line do great, They aren't that bad over all but the quality of Sony is no where near speakers them made 1990 and earlier.(I own the Sony SS-TL5 4way and consider them the last latest and greatest from Sony) my fraternity house has the SS-B3000 which were great for parties back ground music with plenty of bass. For close listening I'll take my Polk Monitor 30's Series ii any day. Sony's are great value for money though and don't sound horrendous I just preferred my Monitor 30's with my cheap polk subwoofer over the SS-B3000
post #23 of 25 Old 06-08-2011, 02:57 PM - Thread Starter
jonLavs's Avatar
Ok cool. I was waiting for someone to say something about the Polk Monitors. Sounds like they are a good value.
jonLavs is offline
post #24 of 25 Old 06-08-2011, 05:03 PM
schan1269's Avatar
Honestly, what I'd do(and I did)...
Take a couple of speakers to her place. Take a pair of Monitor 30 and the SS-B1000. Let her decide if the Monitor 30 is worth the "extra" money. To her, if she can't tell a difference...let her buy the Sony.
The Sony is at least $100 less money(over 7 speakers). To you, "$100 bucks is nothing, get the Polk". To her, "The Sony is $100 less money, I can hit the spa twice with the extra money."
post #25 of 25 Old 06-08-2011, 05:11 PM
sploiz's Avatar
I have the polk monitor 40's and 70's and I love them. I have never tested any other speakers in my house, but I am more than happy with my purchases. I know they aren't the same model that people have suggested but I bet I'd be happy with any of the models in this series.
sploiz is offline
Reply Speakers
